Question about Rockford Fosgate Punch 301X Car Audio Amplifier
Rockford fosgate amp 301X- trouble with wiring remote
Im having trouble wiring my remote wire to my amp... when i make conection the subwoofer keeps hitting crazy.... and not with the beat of the song... when i turn up the volume then it starts corresponding with the song... Can anyone help?
  • 631 Answers
You may have open shields on the head unit. You need to check continuity between the shield and the case of the head unit. The following page shows you how to do it.
Shield Ground Repair
Posted on Feb 20, 2008
How to wire a dual 4 ohm speaker
if im not mistaken the speaker should have a +, - terminal on each side. route a wire from one positive to the other positive and then run another wire to the amp. on the negative terminal do the same, connect the negative to the negative then route a wire to the amp that way it hits a hell of a lot harder than your average sub
Jan 15, 2012 | Rockford Fosgate Punch HX2 RFD1210 Car...
I have a rockford fosgate punch P325.1 subwoofer mono amp that blows a fuse every time i start the car. I have a second pioneer amp but that works with no problems. How can i fix this?
Is it the correct size fuse ? Is it the power fuse or remote ? Either way check your connections going into the amp . Try this hook your other amp to the set of wires for the rockford if that amp has a problem its a wireing problem if not chances are its an interal problem on the rockford . Hope this helps !
Aug 19, 2010 | Rockford Fosgate Punch P325.1 Subwoofer...
I need to wire up a rockford fosgate punch hx2 12" subwoofer to a 500 watt single channel amp and i need to know how to wire the dual voice coil properly ??
Wire it in a series. One wire from amp positive to one positive speaker terminal. One wire from amp negative to negative speaker terminal. This should leave one positive and one negative termianl on the sub. Use one additonal wire to connect these two, this wire should not be connected to anything else other than the two remaining terminals. This will allow you to have the music up louder with higher amp settings without having to worry about blowing the speaker as easily.
Jun 24, 2010 | Rockford Fosgate Punch HX2 RFD1212 Car...
Rockford Fosgate Punch P325.1 Amp keeps blowing fuses every time I start the car. What is going on?
well if the amp works with the car off and when you start it the fuse blows then you may have alternator issues use a volt meter to check battery voltage is not above 14.5 volts
if the fuse blows when the amp turns on then most likely you have a shorted output section in the amp.
Mar 18, 2010 | Rockford Fosgate Punch P325.1 Subwoofer...
Rockford Fosgate Punch 301X not runing
You should verify some other way (with a multimeter or another amp/device) that your 12V is working at the amp. Then to troubleshoot the Remote wire, take a short lead of scrap wire and run it from the 12V power input of the amp over to the Remote input like a jumper. If the amp still doesn't power up, then look for and check the fuse on the amp. If there's good power at the amp, the remote input has good power, and the amp doesn't turn on, and the fuse isn't blown, then the amp is probably toast. Good luck!
Jun 17, 2009 | Rockford Fosgate Punch 301X Car Audio...
Im having trouble i keep blowing fuses on my amp?
you have you gain and freq knobs turned up too far, try turning them down and turn down subb level from deck
Apr 13, 2009 | Rockford Fosgate P3001 Car Audio Amplifier
Rockford Punch HE2 wiring question.
if your sub will handle it, bridging it will give you more power. The best thing to do is to find out how much power the amp puts out ( RMS ) and if it is in your power handling range bridge it. It sounds better and gives you a harder punch because of more power.
Feb 05, 2009 | Rockford Fosgate HE2 RFP4212 Car Subwoofer
301x amplifier
Good luck. Rockford Fosgate does not sell or release any service parts/diagrams AT ALL. They want you to buy a new one or send it in to them to be repaired at an exhorbitant price. Also, from my experience, most RF amps are unrepaairable due to their construction design. the outputs are case soldered and cannot be removed individually. Time to upgrade.
Sep 07, 2007 | Rockford Fosgate Punch 301X Car Audio...
Rockford Fosgate 501bd question
that amp should work fine with those speakers,just make sure that they(speakers)are wired for 2 ohms.at 500-600watts coming from amp, you should be getting 250-300 watts per speaker,just dont crank your gain too high on the amp.
Aug 29, 2007 | Rockford Fosgate Power 501BD Car Audio...
Rockford Fosgate Punch 301X Car Audio Amplifier Logo
115 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
hoyzee1
Robert Rankin
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
