Question about Kenmore 52672 / 52674 / 52679 Side by Side Refrigerator
Have a Kenmore side by side that is not cooling any more. 5 yrs old. sounds like the compressor is trying to kick in, but doesn't tries again every minute or so. Any suggestions?
    President:
  • 1,218 Answers
Good day,
Yes, You have a 5 year warranty on the compressor.
If you are right there, I would call the selling dealer and see what they can do for you. They have a little wiggle room so it's worth the effort.
Your compressor cannot start. There are start components on the body of the compressor that could have failed, or the compressor itself could have itself failed.
You can remove the start components off the body of the compressor and take them to an appliance parts house for testing. Under the cover on the side of the compressor, is a relay, overload protector, and on some models a run capacitor.
The components could have failed on their own, or burned out because the compressor grounded out.
It is safer to have a trained tech check the machine.
He has a starting device that can run the compressor independent of the unit, and see if it warrants replacing start components.
Posted on Feb 05, 2010
For the second time in the 4 or 5 years that I have owned my Kenmore 16.7 upright it quit cooling altogether again -- the first time I cooled the compressor with a damp (to wet) towel and a fan, being...
If the compressor is overheating I would check the condensor fan and make sure it's turning. Sounds like you wouldn't have noticed this already though. Also, if the compressor is turning on for 5 or 10 seconds and then clicking off then your start relay is probably bad. Pull the relay off the compressor and shake it. If something is loose inside then it's bad. That is, if it's a whirlpool made kenmore. Kenmore doesn't make appliances they only brand them. The refrigerator could have been made by Whirlpool, Frigidaire, GE, LG, Maytag, Amana, or other. So, it's depenant on who made it.
Nov 24, 2010 | Kenmore 16.7 cu. ft. / 473 liter Upright...
I have a 10+ year old Kenmore side by side that quit cooling
the starter unit of the compressor can be bad EZ fix if it is that...its the element conected to the compressor :)
Dec 29, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore refrigerator stopped cooling 6 days ago and started working again 2 days later but not very cold.Stopped cooling again 2 days ago.Now it is frosted up in the back of the freezer,What could cause...
There are several things that could be causing this. Your compressor could be going bad. Your freon is low. Think of your refrigerator as a air conditioner. Pull it out and vacuum all the dust from your filters, make sure the water is draining properly and not clogged up. Is your unit still under warranty. How old is your unit. Try this. Unplug the unit for about 5-10 minutes, this will give it enough time for the compressor to cool down. Plug it back in and listen for the compressor to kick on. That's the big black round thing at the bottom in the back of your refrigerator. Listen to it and what the sound is, does it click when it turns on, does it shudder when it turns on. Let me know the sound. By unplugging the unit and doing this the compressor should kick on in 1-3 minutes after plugging it back in. If your unit is over 8 years old you might consider another one. Check out craigslist, as you can get some great deals. Let me know if I can help you further.
JimmyC
Sep 26, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Whirlpool refridg side by side
This sounds like the compressor is bad. The clicking sound is the start relay trying to start the compressor and cannot. You stated that it was only four years old. Check the warranty for your frig. Most carry a five year warranty on the compressor.
Nov 10, 2008 | Whirlpool ED5FHEXMQ Side by Side...
FRIDGE NOT COOLING
sounds like the starting device for the compressor clicking on/off not always starting, hopefully under 5 years old cause sounds like a bad compressor(full 5 yr warr on on that)
Mar 14, 2008 | Frigidaire FRS26R4C Side by Side...
Kenmore Fridge 4 yrs old side by side model not cooling
Hi. Your refrigerator is under 5 years and the compressor is still under full warranty. Call Sears and get it fixed parts and labor included. There should be no charge to you whatsoever. Make sure they understand that on the phone when you set up the appointment. You would be better off having a different technician from Sears come out to your house, as the one that came was not honest with you. Good luck, Mack
Jan 06, 2008 | Refrigerators
Fridge stopped working suddenly
Sounds like the relay (start device) on the compressor has failed.  This is a very common problem especially for models that are 3-5 yrs old.  I would replace that first.
Oct 22, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Fan runs but no cool air on both freezer side and cold side
If you hear the compressor try to start then click off, you probably have a bad compressor or a bad relay. If it is less than 5 yrs old the compressor is still covered by warranty and will be replaced free of charge. The relay is only covered for a year. With it being a Maytag, I bet it is compressor. There have been a few models with control board problems that have caused this symptom, but that's not likely to be your problem.
Oct 06, 2007 | Maytag MSD2756GES Side by Side...
Kenmore chest freezer not working
Remove the panel covering the compressor. Remove the relay plugged on the side of the compressor and shake it. If it rattles or has any burned spots it is shorted out. Try replacing it first. Make sure you replace it with the correct replacement, not a fit-all. If this is not the problem you will need to replace the compressor. If it is less than 5 yrs old the compressor should still be in warranty. If so call Sears, it will be repaired free of charge. If it is out of warranty buy a new freezer.
Sep 25, 2007 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Kenmore 52672 / 52674 / 52679 Side by Side Refrigerator Logo
85 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
