Question about Vacuums
Hoover Z-400 - Hepa Filter
We have a Hoover Z-400, purchased approximately one year ago. I have noted throughout the time I've used this machine that there seems to be a lot of dust in the Hepa filter area. Please note that I am meticulous about cleaning the dust/dirt collection part of the machine EVERY time I use it. Approximately one month ago, the Hepa filter stopped turning. I took it in for service and the Hepa filter unit was taken apart and cleaned thoroughly. It contained a lot of dirt; otherwise, it appeared to be in working area. Now, one month later, the Hepa filter has stopped turning again.
Is the Hepa filter defective, or am I not doing something I should be doing, and what can I do to eliminate and fix this problem?
  • 1 more comment
  • saintbernard Feb 21, 2008
    Thank you very much, "reddevil6"! We'll give that a try! Funny, the manual doesn't say anything about replacing the Hepa filter once a year. It seems logical to me, though.
    Thanks again!
  • reillyraider Feb 23, 2008
    Loss of suction. Made sure wands and hoses were clear. Manually turned hepa filter , which seems to have been jammed, manually turned filter and quite a bit of clumps and dirt fell out from behind the filter.
    Cleaned all of other filters. Reassembled, still no suction and filter doesn't turn. What makes the filter turn, could something be burned out?
    Any ideas?
  • Anonymous Dec 07, 2008
    hepa filter is not turning in my z700
This vacuum has been scrapped bye hoover i am an x hoover employee and theese machine came in bye the bunches the parts are not availible and the filter are lifetime not annually !!! my advice bye a new vac!!!!!
Posted on Jun 03, 2009
    President:
  • 1,673 Answers
These filters should be changed at least once a year, they get clogged up and won't clean out. So I would try a new filter and go from there, make sure there are no clogs in the hose and down below where the dirt inlet is.
Posted on Feb 21, 2008
Top filter keeps clogging up??
Just make sure the rubber gasket is secure at the bottom of the dirt cup if it rides up the dirt will go straight up to the filters
here is the hepa that should be change when it is dirty
Hepa Filter Hoover U5780 WindTunnel Bagless 93002360
Dec 07, 2015 | Hoover U5780900 Bagless Upright Cyclonic...
MAINTAINING A EUREKA BAGLESS VACUUM
Helo Reader,
You can purchase replacement parts directly from Govacuum with an exclusive 11% discount coupon only for Fixya.com readers, use code: FIXYA11 at checkout to avail the offer. We also offer free shipping over $35.
Eureka Style U Belt - https://www.govacuum.com/products/eureka-u-extended-life-belt-set-of-2
Eureka HF7 Filter https://www.govacuum.com/products/genuine-eureka-premium-hf-7-hepa-filter-with-arm-hammer-61850c-1-filter
Hoover parts - https://www.govacuum.com/collections/hoover
Jeethu
Govacuum Team
https://www.govacuum.com9_17_2017_3_49_04_pm.jpg
Oct 04, 2014 | Eureka Altima Upright Vacuum Model 2996AVS...
How do I clean and with what,a Hoover elite lifetime hepa filter?
Hello! Please follow the instructions below to clean the lifetime Hepa filter on your Elite Rewind.
1. Press on the tab located on the side of the filter cover to remove.
2. Remove the HEPA filter and brush with the combination tool to clean or tap side of filter against a trash receptacle. Return the HEPA filter into the filter cavity.
3. Align tab on filter cover with slot. Press cover closed until you hear a snap.
Hope this was helpful!
Jun 09, 2014 | Hoover U5507900 Elite Rewind Bagless...
Burning smell coming from vacuum
use a penny to turn the 2 screws on top a quater turn then fold down the vacuum and lift up the cover and you will have access to the belt. Clean the small hepa filter with soapy water. their may be 2 of them. The cannnister filters need to be shaken but not washed. Good luck.
Apr 09, 2009 | Hoover U5753-900 WindTunnel Bagless...
Filter in Hoover Wind Tunnel Vacuum
Definitely not. Do not use water or any liquids to clean it. Te normal use life is 2-3 years keeping it maintained. You can clean it dry with the dust brush from your vac attachments. place in a plastic bag and tap it some folks even us an air compressor to blow out the impacted dirt. you will only want to use the Hoover brand, other generic brands dont fit as well.
Jan 17, 2009 | Hoover U6630-900 WindTunnel Bagless...
Dust blowing out of hoover
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618781&thid=617336
Dust blowing out of Hoover
Posted by Lunagus on May 23, 2008
When I start up my year old Electrolux Loopie Petlover vacuum a large amount of dust comes out of where the HEPA filter is - can you suggest reasons?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Oreck Upright 014T XL Pro 14 Upr Vac
In answer to your question, if the HEPA filter is leaking then you should replace it because it has lost it’s filtration – but my question is – is it on the Oreck, Hoover or Electrolux --- all three have HEPA filters and needs replacing and to make sure that the HEPS filter is installed correctly or other wise the filter will leak and if that happens then contact your local vac dealer in your neighborhood. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
http://www.oreck.com/ Customer Service 1-800-989-3535
Monday thru Friday Hours are: 7:00 am to 7:00 pm CST
Saturday and Sunday Hours Are; 8:00 am to 4:30 pm CST
http://electrolux.com/ Customer Service 1-800-896-9756
Electrolux Home Care Products – North America
P.O. Box 3900 Peoria, IL 61612
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 23, 2008 | Oreck UPR014T XL Pro 14 Upright Vaccum...
My hoover wind tunnel vaccum has a hepa filter that is supposed to be self cleaning but continues to plug up. it is not easy to get to and takes forever to clean it out so the suction is strong again.
do you have the SELF-CLEANING, rotating HEPA filter?
I just fixed my HEPA filter not rotating!!
It involves taking apart the vacuum HEPA area. All screws are the same size. There are a LOT of 'em. Really straightforward putting it back together too.
ok, once you take the HEPA canister area off the vacuum, careful with the wires! Unplug them from the controller board. You open up the HEPA chamber by removing more screws until you see where the motor that turns the filter is mounted on the side. Remove motor from the green chamber. Note where the washer goes. Once the motor is off, you'll see that the center hub that drives the HEPA filter is rounded out. What I did was jam little bits of aluminum from a pop can into the space between the circle and the square to force the walls back to square. I started by folding a little piece of aluminum over and over so it was about three layers thick. Jammed that in. That wasn't quite enough thickness so I shoved another piece with it. If you can find something that is about 4 times the thickness of a pop can aluminum, that'd probably work too. Slight wedge shape on the tip would help. Any sort of tiny shim.
To test your work, just put a couple of holder screws into the HEPA cannister housing, plug in the cover/switch, plug in the HEPA moter. Turn it on for a few seconds to make sure the filter turns. Then you can add more thickness to the hub or put things back together.
Apr 29, 2008 | Hoover U5444-900 5100 Wind Tunnel 15 Inch...
How often should I change a hoover empower filter?
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=545652
Generic problem for all Vacuums
How often should I change?
Posted by jdl185 on Apr 25, 2008
How often should I change a Hoover Empower filter?
Depending on what type of filter it is, the suggested change for a filter is every 6 months to one year if it is a cartridge filter or HEPA filter, if it is a filter that can be vacuumed off or it might be a washable filter – you can clean it that way until the filter starts to fall apart – then @ that time you would want to replace it @ that time. Please check with you local vac dealer. Filters
It's important to replace your vacuum filter or HEPA filter regularly to keep your Hoover vacuum working best. Not only will this increase the life of your vacuum, it will also keep unwanted dust, dirt and allergens out of the air. Keep your home Hoover clean with genuine Hoover filters.
So If you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
8 a.m. - 7 p.m. EST
www.A-1Vacuum.com 1-800-657-1874 If you cannot find a local dealer near you they can ship you the parts UPS.
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Apr 25, 2008 | Vacuums
HEPA Filter
It maybe that the filter is in need of replacement. They need to be changed once a year.
Sep 13, 2007 | Hoover U8311900 WindTunnel 2 Vacuum
Hoover u5720-900 quits running and restarts again after some time
There is one more filter under where the collection tank & Hepa filter sits -- there is one screw that holds the cover down - remove that filter and clean it that will help. I also find I need to vacuum the hepa filter as well- it is too expensive to replace all the time. The Hepa filter can be placed inside a plastic bag and shaken really good to get the dust off of it
Jul 27, 2007 | Hoover U5720-900 WindTunnel Upright Vacuum
Vacuums Logo
389 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
