Question about Kodak EasyShare 8" LCD Wi-Fi Digital Photo Frame
My Frame is blank with all the little lights around the edge lit up. I have tried un plugging and holding down the power button.... But actually....as soon as I plug it in...it goes to that status with the edges lit up....????
Where light is for controller port four its flashind red and xbox will noy work?
hi, this is what that code is telling you, also do you have a code on the screen when switched on let me know if you do if you dont ill tell you at the end of this post how to get an error code so i can tell you exactly what the problems is.
Section 4 is flashing red
- Hardware Failure
The Specific Type of hardware failure can be determined by the error code displayed on the screen.
If the screen is blank or you would like additional information follow the instructions for determining the secondary error code in the section below
here is how to get the secondary code for me.
The specific type of hardware failure can be determined by a "hidden" error code
* Turn the xbox 360 on, and wait till the 1 red lights are flashing.
* Press and hold the sync up button (the small white one), while holding that button press the eject button.
* The LEDs will now blink the first number in the code ( so 1 red light may be lit so write this down).
* Release the eject button and press it again.( it will then change the red lights and maybe 2 will be lit up write this down also)
* The LEDs will now blink the second number of the code.
* The LEDs will now blink the third number of the code.
* The LEDs will now blink the forth number of the code.
* The LEDs will go back to the 1 red flashing lights.
so what you need to do is this, when the 1 red light comes on hold down the little white sync button and keep holding it down all the time, now whilst your holding that little white button down on the front of xbox press the eject button but keep holding the white button down now write how many lights are lit up and this is the 1st number in the code, so keep holding the white button down dont let go of this white button then press and let go of the eject button again and write how many lights are lit up whilst still holding the white button down, now do this 4 times all together and you will end up with something like this written down
4402
once you have this four digit code send me a message back with the code then i can tell you exactly what the problem is and what you can do to try and solve the problem
let me know how you get on or if you need further assistance ok
Dec 12, 2010 | Microsoft Xbox 360 Console
Theres a ring around the disc
the ring is from the console being moved when the system was on you can resurface the disk or theres a disk replacement program but with that ring it most likely will not work
Nov 29, 2010 | Microsoft Xbox 360 Console
How to replace ink waste absorber
  • Open the printer as though you were going to install new ink cartridges, letting the cartridge cradle move to the center of the printing unit. Unplug the printer so that the cartridges will remain in their position.
  • Locate the waste ink absorbers in their black rubber frame. They will likely be on the right side of your printer, and will be located underneath the area where the ink cartridges rest when the printer is in standby mode.
  • Use a paper napkin or other disposable and absorbent material to soak up any excess ink that may be in the pads by pressing it down onto the top of the frame.
  • Pull the rubber frame free from the printer, wearing gloves to keep your hands clean. Carefully remove the ink absorber pad or pads from the rubber frame.
  • Insert new ink absorber pads firmly into the rubber frame. Replace the rubber frame in its original position and close the printer.
  • Hold down the power button, then plug the printer back in. Continue holding the power button down until the printer begins to reset itself and come online.
  • Wait for the green power light to turn off, then press and release the power button again. It should blink for two to three seconds, then stay lit; this will indicate that the printer has been reset and is ready to print again without errors.
  • Nov 02, 2010 | Canon PIXMA iP5000 InkJet Photo Printer
    My problem is a weird one. My family has had a Photosmart 3310 All-In-One printer for a while now (I'd say about 3-4 years), and it's worked fine until recently. Now, the light is on around the on button,...
    Hi, I suggest you do a full system reset on the printer and see if that fixes anything. Please do the following. Come back and check with me if it doesn't work.
    Performing a semi-full reset of the All-in-One
    1. Use the Power button to turn on the product.
    2. Unplug the power cord from the back of the product.
    3. Press and hold the # button and the 6 button.
    4. While holding the buttons down, plug the power cord into the back of the product.
    5. Continue to hold the buttons down until the control panel display goes blank.
    6. Release the buttons, and then use the Power button to turn on the product. The reset information appears on the control panel display.
    Aug 12, 2010 | HP Photosmart 3310 Printer
    Press power, buttons light up and thats it
    Try pressing the clean cell now button & check pre filter button at the same time hold buttons down at the same time for about 5 seconds with the air cleaner turned of and blue screen lit
    Jan 30, 2010 | Kenmore AC2044-1 Air Purifier
    I have a 2 yr. old C6180. It will not turn on as of yesterday. Power is coming from the socket as the little green lights on the plug are lighted. I have unplugged all cords and plugged them back in but...
    try unplugging power cord and holding #6while your plugginmg in the power cord hold the button down until you see the display lights turning on and release if you are printing wirelessly you will have to do the wireless setup wizard again.
    if that doesn't work try plugging it directly to the wall
    if all else fails it may be the printer
    Jul 14, 2009 | HP Photosmart C6180 All-In-One InkJet...
    Monitor goes blank
    I was thinking about your problem, I just had a similar issue and the problem is that the inverter or the power supply with an embedded inverter had gone bad.
    The reason it goes black is because the inverter fails to provide power to the LCD Display.
    The only way to fix this is to open up the FPD:
    *note these are instructions for the most popular FPD 1730*
    1.there should be four screws on the back --> plus two large screws that hold the FPD stand and the Monitor together.
    2.Open the back by pulling the cover off
    Remove 7 screws holding the frame and the power button for the LCD
    3.Remove two screws through holding a silver cover and remove cables.(pinkwhite) (blackwhite)
    Please note where they belong before removal**
    4.On the edges left and right are two screws 4 total ---> remove and remove LCD off of frame**becareful because the backlight Damaging can cause severe damage to your LCD panel.
    5.Choose your model
    Your FPD has 3 boards (power, inverter(backlights) Logic Video)
    replace the inverter with well known good one
    Your FPD has 2 boards(Power with inverter on edges, Logic Video)
    replace the power board with a well known good one
    6.Then do steps 1-5 in reverse order(putting your FPD back together.
    I hope this is significant help
    Sep 11, 2008 | Gateway FPD 1730 17" Flat Panel LCD...
    How to Factory reset Firebox X20e edge
    To set the Firebox X Edge e-Series to the factory default settings:
    1. Disconnect the power supply.
    2. Hold down the Reset button on the back of the Edge.
    3. Continue to hold down the Reset button, and connect the power supply.
    4. Hold down the Reset button. When the yellow Attn light stays lit, the Edge was successfully restored to the factory default settings.
      This process can take 45 seconds or more.
    5. Release the Reset button.
    Do not try to connect to the Edge at this time. Before you can connect to the Edge, you must start it one more time. If you do not, when you try to connect to the Edge a web page appears with this message: Your WatchGuard Firebox X Edge is running from a backup copy of firmware. You could also see this message if the Reset button is stuck in the depressed position. If you continue to see this page, check the Reset button, and start the Edge again.
    2. Connect the power supply again.
      The Power Indicator lights and your Edge is reset.
    Sep 02, 2008 | Computers & Internet
    Kodak EasyShare 8" LCD Wi-Fi Digital Photo Frame Logo
    76 people viewed this question
    Top Kodak Photography Experts
    Michael Galve
    Michael Galve
    Bill Eager
    micky dee
    Are you a Kodak Photography Expert? Answer questions, earn points and help others
