Question about HP Compaq Presario SR1303wm PC Desktop
My card reader on my computer has stopped working!? ok i took my computer in to my computer teacher to get it fixed, well she put in a second hard drive in and said it should fine. well it does but after i got it back my card reader has stopped working! like it dont show up on my computer, like at all. so is there an easy fix or do i have to wait for my teacher to fix it again? o btw my computer is a compaq pesario sr1303wm, if possible show me a link of reconnecting it back to my computer. thank you
  • big_dude2010 Feb 05, 2010
    ok she wasnt fixing the card reader like i said she was getting me a new hard drive put in. she must have disconnected it from my motherboard and the problem is that im having is how can i connect it back in, i know some stuff about computers but i dont see a cord to plug in the thing. i would buy that, just dont have any money lol.
  • joecoolvette
    joecoolvette May 11, 2010
    Suggestion. Spend $20 for this card reader that plugs into any available USB port on your computer, and put a smile back on your face.http://www.tigerdirect.com/applications/... Scroll down, and watch the animated GIF, that is right above the red Ultra 3 Year Warranty, heading. By the way. How is a Slave harddrive supposed to fix a card reader? Ask your teacher for me, and post it in a comment. This one I gotta hear.
  • HP Master
  • 5,660 Answers
Ah, My Bad, big_dude2010, perfectly understandable about the budget thing. The world is in an economic crisis right now.
As for reattaching the Card Reader cable, can't help you.
OH, I'm just PLAYIN'!
Before we go ANY further:
1) Computer off, and unplugged from power.
Unplug the power cable FROM the surge protector, and NOT plugged into the surge protector, and take it out of the back of the Power Supply.
With the power cable plugged into the surge protector, and unplugging it out of the Power Supply, you could create a voltage spike.
Result can burn out the Power Supply, and may go on to burn out the Processor, Motherboard, Ram Memory, and a graphics card. (IF used)
Many have stated, that they do this all the time. Eventually, they come back to state they fried out their power supply, and/or motherboard, and so on.
2) Computer unplugged from power, computer case open, TOUCH the metal frame of the computer case to relieve your body of Static electricity.
Static can fry out, (Short Circuit), the delicate hardware components inside your computer.
(For this reason also work on a table. If you have a carpet floor, refrain from swinging your feet back, and forth.
If you get up, walk away, then return, TOUCH the metal frame again)
If you already know the above, please disregard.
The Card Reader cable has a white sheath, and is approximately as thick as a No.2 pencil.
It should have 8 wires in it.
Orange, Yellow, Blue, Brown, Red, White, Green, and Black.
It will have a white rectangular connector on one end, that has 10 socket holes. 2 rows of 5 holes.
Only 8 socket holes are used.
The other end of the cable should have a Black connector. It also has 10 socket holes. 2 rows of 5 holes. This connector plugs into the circuit board of the Card Reader.
The White connector end plugs into the motherboard. It plugs into the Front USB 1 header on the motherboard.
(Connector on a motherboard is referred to as a Header)
Orienting the motherboard, so we are both looking at it in the same direction.
Processor to the top. Ram Memory slots to the right.
There are 3 white PCI slots down towards the bottom.
The white PCI slot that is closest to the edge of the motherboard, is PCI3. (PCI 3)
Down below the PCI 3 slot is a blue header. NOT the one you want.
That's for the audio ports in the front of the computer. (Front Panel)
To the right of the blue header, is a white header. This is the one you want. Front USB1. (The Front USB1 header, is below the Right/Bottom corner of the PCI 3 slot)
Note that there are 5 pins going along the top of the Front USB 1 header, and 4 pins going along the bottom.
The missing pin, or blank spot, helps you to orient the white connector of the card reader cable.
The card reader cable's white connector also has a missing socket hole, or blank spot.
There is No slot on the header for the motherboard, and No locating lug on the Card Reader cable's, white connector.
Line the card reader cable connector's blank spot, up with the blank spot on the Front USB1 header.
This is HP Support, and the Motherboard Specifications page, for the Compaq Presario SR1303WM Desktop PC,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00069442&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&lang=en&product=447312
Scroll down the page about halfway, and you'll see an illustration of your motherboard.
(To enlarge it for better viewing, you can right-click right on it, then in the drop down menu, left-click on - Save As
Put this in your My Pictures folder.
Then go to My Pictures, and double-click on the illustration of the motherboard.
Now go below in the window, and click on the + sign to Zoom In.
Use the bottom, and side bar, to move it around to the view you want)
Below the illustration is an actual photograph of the motherboard, with no hardware components installed.
The Black connector that goes to the circuit board of the Card Reader, plugs in like this.
There are four wires across the top. There are five wires across the bottom.
Looking INSIDE your computer, TOWARDS the Card Reader circuit board, the four wires go on top, when plugged in. (Not shouting)
Again, looking at the back of the Card Reader, the color code of the wires on the top, going from Left to Right, are:
Thin Black wire, Green, White, and Red.
Wires going along the bottom, starting from Left going Right,
Thick Black wire, Brown, Blue, Yellow, and Orange
Posted on Feb 05, 2010
Testimonial: "this worked so perfectly thank you so much!!:D:D"
  • joecoolvette
    joecoolvette Feb 05, 2010
    You are most KIND, big_dude2010!
    Thank You for the rating, and your testimonial!
Sim card reader not working.
Does the card still work in the device you took it out of? Have you tried a different card in the computers reader?
If the card still works in the device you took it out of, plug the device directly into the computer to download. Then format the card and try to read it again in the computer. If this works could be a format error, if the card does not work in either device, bad card.
If another card works in the reader, put it in the device you are using (digital camera, phone, ect) and put something on it. Then try using the computer reader. If it works great. If not, your device is formating the card in away the computer does not recognize.
If non of the above work, look in device manager and see if there is any ? marks next to anything. If there is go to Gateways website and look for the updated drivers for you computer. This is a good idea anyway, since drives are updated all the time and having current ones help reduce issues.
Hope one of these items helps
Jan 31, 2012 | Gateway 507GR PC Desktop
Ok I was messing around on the computer with my sd chip in my dynex card reader and then I put my sd chip back into my Verizon cell phone and now the phone says I have no pictures saved on memory card so I...
Did you use the safely remove hardware icon your computer before you took the card out? Might be damaged.. copy them to your computer atleast, the card can be replaced if its bad.
Apr 22, 2011 | Dynex External USB 2.0 Multiformat Memory...
Computer has no sound. Took hard drive to Best Buy. Geek said according to the computer, the sound card is ok, don"t know why there is no sound, oh and by the way you have a high fidelity sound card, and...
Yes you should be able to fix this. First do you have external speakers for this computer or is it internal? Next has this worked before and stopped working?
Aug 14, 2010 | Dell Dimension 4700 PC Desktop
I put a sd memory card from my camera in my computer. the computer hasnt uploaded the pictures or done anything.
I guess you have a built in card reader? Is there any chance your camera SD card is SDHC? Some card readers including built in types and those that you connect to a USB port have trouble with the later and faster generation SDHC cards but are happy with plain old SD cards.
If you are using an external card reader, does it work in another computer? If it does work, then the problem is with your computer.
If you have a built in reader, can you borrow someones external card reader that you know and does work with SD and SDHC cards?
Can you try an older SD card in your current setup? If that works OK then it's the issue with SDHC that is your problem.
Easily fixed by buying yourself a $10-20 external card reader
Cheers,
Steve
Aug 11, 2010 | Computers & Internet
My MicroSD Memory card in my phone just stopped working...
put your memory card in the computer as if you were going to put the picutres on your computer and save them then clear your memory card and then take them from the computer adn put them on your memory card adn then save all pictures from memory card to phone and then clear memory card again and then place in computer defrag memory card and then put all pictures back on and then place in phone move all picutres to the memory card and then you will have two of each picture then delete them to where you only have one of each and then it is fixed
May 05, 2009 | LG VOYAGER VX10000 Cellular Phone
LG KC550
kk to add music make sure you syn the phone and the cp do the data and all then put .mp3 on all the media files and see if it works. Then if that doesnt go to computor format the card and then put it in the phone. Otherwise you need new stuff.
Mar 13, 2009 | LG KC550 Triband GSM 5MP Camera MP3 Phone...
Memory full message
Hi There
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • Jan 15, 2009 | Aiptek A-HD 720P Flash Media Camcorder
    Took pictures with Panasonic DMX-FZ50 using a Lexar SD 2GB memory card. I put card into card reader in my computer to upload. It shows a JPEG thumbnail with a file # and if you place the cursor over it, it...
    Firstly, whenever you put the media card into a card reader, ALWAYS turn write-protect on, to protect the images already on the card.
    Secondly, AFAIK, the only way that your computer could have 'wiped' the card is if you told it to Move the images, rather than just Copy them. Again, setting write-protect would have solved this.
    May 04, 2017 | Cameras
    3110c 1gb "memory card not formatted"
    nokia 3110c show the disiply memory cord not formated how to solwe thes prablam
    Jun 29, 2008 | Lands Phones
    SDHC Memory Card error
    I had exactly the same problem with a 2 year old LX-1. The card worked fine on the computer, formated no problem but would not work in the camera.
    I took a can of air and used maybe 3 one second bursts to blow out the card slot. Card immediately started working.
    -prmolina
    Feb 19, 2008 | Panasonic Lumix DMC-FZ18K Digital Camera
    HP Compaq Presario SR1303wm PC Desktop Logo
    240 people viewed this question
    Top HP Computers & Internet Experts
    pontelemon
    pontelemon
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
