Question about Canon DR-2580C Path-Through Scanner
Scanner only scans top page although set on duplex setting.
    Scholar:
  • 150 Answers
Switch the little button on top of the scanner next to the 3 buttons. This switches between 1 page or multiple page.
A.Misset
Installing these devices in the Netherlands.
Posted on Mar 11, 2010
How do I get the scanner to scan several pages into one document instead of each page being an individual document
Dear
Pl. do select the multiple page in scanner software (application) setting, and format setting to pdf type.
Thanks.
Feb 26, 2015 | Canon MF-4150 imageClass Black & White...
My scanner is now adding a page with a black line that runs from top to bottom of the page and the actual document scanned is page 2. But the document is fine with no line through it. Does this mean that...
Check your scanner software settings. It is probably set at duplex ever time you start to scan. That is why you get two pages for every pass, the front and the back. You must place the document in the feeder in a way that the front side of the document is page 2. You may want to flip it next time you scan. So the main question is why there is black line from top to bottom? That is because there is a piece of dirt stuck on the glass of the scanner. You see, this scanner actually does two scanning when a page runs through it: the front and the back in duplex mode. So there are two scanners in side the box. The front page scanner apparently is dirty and needs to be cleaned with clean cloth and lens cleaner.
Aug 31, 2010 | Canon DR 3060 Path-Through Scanner
How do i delete error pages after scaanning?
I changed the settings from duplex (double sided) scanning to simplex (single sided) scanning under the settings tab in the scansnap organiser. this was ok since i had all one-sided documents to scan. you would need to reverse this settings change anytime you have a double-sided document to scan.
Nov 18, 2009 | Fujitsu ScanSnap S510
Canon Dr2050C Duplex scanning reverse page all black
Check your brightness setting for backside. Ideally keep it automatic, else you can manually choose the right brightness.
S. Mohan
Sep 18, 2009 | Canon DR-2050C Path-Through Scanner
Scanner is not reading multiple pages...
Check your scanning software settings. If you are getting only one file output, then you must have chosen 'multipage' option.
S. Mohan
Jun 12, 2009 | Canon DR-2580C Path-Through Scanner
When i scan a letter 2 page is scanned:letter and blank page
You may be set for front & back (duplex) scanning. Change the setting for front only or simplex. This could be done with check/uncheck boxes, a drop-down menu, or a keyboard shortcut. I believe the standard Kodak settings are via check boxes.
This model is also capable of putting out color & bitonal (black&white) images simultaniously. If that's the case the pages should be separate image files. Uncheck either color or bitonal depending on which you want.
Apr 09, 2009 | Kodak i40 Path-Through Scanner
No duplex scanning
Try going to the hp solution center
Then settings, scan settings, scan preferences (third from top), under the automatic tab, bottom of list is “Scan both sides of the original when using duplex feeder”
I’m using version 70.0.128.000 of the HP Solution Center if that helps.
I told my brother once to ask HP support about a problem for his laptop, and they proceeded to instruct him how to make the problem worse and royally screw up stuff that was completely unrelated to his problem.
Jan 11, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
Duplex- Back of page not clear
Clean the glass with Isopropyl alcohol. Set proper Contrast level. If the level is not okay, you should get atleast a dark/very light image. If there is no image at all reinstall driver. Run Scandisk on the Comp
S. Mohan
May 05, 2008 | Canon DR-9080C Path-Through Scanner
Scanner problem
Try scanning a double sided document in duplex mode. Reverse the page and scan again. Make sure contrast/rightness settings are okay. If one side output is still not okay, then it possible that the lighting has failed. Either loose contact or failure of the lamp. Some scanners have LEDs and some have a lamp.
S. Mohan
Feb 19, 2008 | Office Equipment & Supplies
Canon DR-2580C Path-Through Scanner Logo
261 people viewed this question
old marine
old marine
