Question about Sharp AR-M237 Digital Copier
Im working on a sharp AR-M237 and when i select the fax I get funtion can't be used right now, but I can hear a ring tone on the speaker. I'v installed the LIU fax board and did sim 66-2 to switch the langue to english, so what's can I do next to sovle this problem?
  • 52 Answers
The fax has been deactivated check your user gilde
Posted on Aug 27, 2010
Ring tone volume
Press the top or bottom of the circular dial button to select HIGH, MIDDLE, LOW or OFF .... while SPEAKER has not been pressed and a document is not loaded in the feeder.
The ringer will ring once at the selected level.
Jan 15, 2014 | Sharp UX-B750 Inkjet Fax
A am not getting any sound when faxing or when faxes are coming through and my volume is on loud why is that.. I disconnected plugged it back in changed some settings and i still get nothing
Your HP all-in-one provides three levels for adjusting the ring and speaker volume. The ring volume is the volume of the phone rings. The speaker volume is the level of everything else, such as the dial tones, fax tones, and button press beeps. The default setting is Soft.
1 Press Setup.
2 Press 4, and then press 8.
This displays the Basic Fax Setup menu and then selects Ring and Beep Volume.
3 Press to select one of the options: Soft, Loud, or Off.
Note If you select Off, you will not hear a dial tone, fax tones, or incoming ring
tones.
4 Press OK.
Sep 15, 2010 | HP OfficeJet 7310 All-In-One InkJet...
PC-FAX
No it needs fax modem board.
May 10, 2010 | Sharp AR-M237 Copier
How do I turn off the ringer volume??
I found this at hp website.
Adjust the volume
setting is Soft.
1 Press Setup.
2 Press 4, and then press 6.
This selects Basic Fax Setup and then selects Ring and Beep Volume.
tones.
4 Press OK.
Feb 22, 2010 | HP OfficeJet 6210 All-In-One InkJet...
Sharp AR-M237 EXPANSION MEMORY 8MB: AR-MM9 installation procedure
You are needing the installation manual for this. Please contact me so I can e-mail you the pages that you need. administrator@aokoffice.com
Oct 08, 2009 | Sharp AR-M237 Digital Copier
Will not feed to fax a document, but will feed to copy..?
Have you tried to see if you have a dial tone on the fax??? Can you recieve faxs? If not make sure you have the phone cable insurted in to the right connection "LINE" not "TEL" Good Luck
Jun 26, 2009 | Sharp AR-M237 Digital Copier
How do I mute the speaker so that we don't have to hear the ring when a fax is coming in?
That kind of selection is normally part of the initial setup menu where you also set time, date and whatever letterhead you want on outgoing materials. I don't know how that is accessed on your particular machine but entering the setup routine must be detailed in your owner's manual.
May 04, 2009 | Sharp AR-M237 Copier
Code: E7-10 on Sharp AR-M237
Your lsu or laser scanning unit is deffective that's why E7-10 appears. it should be replaced
Mar 11, 2009 | Sharp AR-M205 Copier
Faxing
You need Option, AR-FX7 (FAX) installed, real easy to figure out, look at the side, if you see a telephone line, with line and telephone connections (not the Network connection) then you have a fax.
Next your arm237 will also need to be able to print from the nextwork.. if this is all together..
you will need a driver called, PC to Fax for the AR-M237.
which you can find at www.sharpusa.com
Then you will have to set up the computer in the printer folder to PC to Fax.
Sep 29, 2008 | Sharp AR-M237 Copier
Fax Problem
It sounds like it has a lot of jobs in it's outgoing queue. Make sure your phone line is connected to the LINE port, and see if you can get a dial tone.
Jan 28, 2008 | Sharp AR-M237 Copier
Sharp AR-M237 Digital Copier Logo
55 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
