Question about Cyberhome CH-DVD 300 DVD Player
Want to select scenes without remote
We have no remote and want to select scenes on 24 DVD Cannot seem to play second or moe scene without it. Wants to rest same scene
Toshiba SD-6100KU2 DVD Player keeps freezing up.
check blu ray dvd for finger prints or scratches. may need to clean the dvd disk with a soft cloth with pure alcohol or metho.
Sep 22, 2016 | Toshiba Televison & Video
DVD player won't play new movies
Try this
1.While the previews are playing, press the Menu Button on your DVD player remote to access the DVD's Main Menu.
2.Go to Scene Selection and press your Enter or Ok button on your DVD player remote.
3.Highlight Scene 2 and press the Enter or Ok button. This will start the DVD in Scene 2.
4.Use your rewind or reverse button on your DVD player remote to rewind back to the beginning of Scene 1.
Walt Disney Home Entertainment Technical Support
1-800-723-4763, Monday's 9:30-7:30 and Tuesday through Friday 9:30-6:30 CST
Excerpt from email tech support Walt Disney
Dec 07, 2007 | RCA B27TF680 27 in. TV/VCR/DVD Combo
How do I find the delete option on my hitachi camcorder?
Hi! The solution to your problem is Three fold.
First make sure that your Camcorder is in the Disc Navigation mode to be able delete your required scene. When the camcorder is in the play back mode the delete scene won't appear.
The second situation is to check if your scene is not locked because if it is locked you are not able to delete it.
Supposing that your scene is not locked then check what type of DVD disc you have. The discs labelled DVD Ram, DVD+RW, and the Card can be deleted. The DVD-RW can be deleted only when in VR mode and not the VF mode. Other types of discs like the DVD R can not be deleted.
Another way of deleting a scene after it has been recorded on a disc that's not deletable is to transfer the recorded scene to a computer disc and then edit it off.
Oct 08, 2011 | Hitachi DZBX35A DVD Camcorder
Purchased the DP300 at the Goodwill. The DVD has the remote control;however, I do not know how to use the remote control. I used the red, yellow, and white connector to my the DVD player and to the TV but...
with regard to using the remote control :
Make sure the batteries in the remote are working (they go in the back of the remote at the bottom).
Turn on the DVD player with the power button on the DP300 itself (lower left). Open the dvd tray either with the remote (press open/close button, upper right) or with the button on the DP300. Put a DVD in the tray and close it with the remote or the button on the DP300. The DVD should load.
Use the arrow buttons in the centre of the remote to select choices from the onscreen menu of the DVD. Press Play (centre of the 4 arrow buttons) to activate the choice you want. For example, if you want to play a movie, use the arrow buttons to go up or down until "play movie" is selected, then hit PLAY, and movie will play. If you want to choose a scene/chapter of the movie, use arrow buttons to go up or down until Scene Selection or Chapter is selected (highlighted), and press PLAY. This should bring up a list of the scenes or chapters. Use the arrow buttons to select the one you want, then hit PLAY, and that scene should play.
If the DVD tray is taking less than 20 seconds to operate, there is likely no problem. If it is taking more, there may be. I think the mechanism that opens and closes the tray is often the first thing to stop working on DVD and CD players.
Jul 20, 2011 | Norcent Technologies DP300 DVD Player
Plays disc up to point where the movie should start and just keep restarting over and over?
I had a similar issue a while back. It didn't do it every time, just on one DVD.
When given the choice, go to "scene selection" instead of "play", and select scene 1. This bypasses the loop that the "play DVD" is on, and takes you straight to the movie.
Hope this helps!
--W/D--
Jan 30, 2011 | Samsung BD-P1500 Blu-Ray Player
Lost the remote
If it is Sony DVD Player DVP-NS425P then you need original remote to use above options.
Remote part number is as follows...
clear_spacer.gif " 147772411 " RMT-D153A REMOTE CONTROLand price is approx $18 and available at Sony Accessories. Please write model number of your dvd player DVP-NS425P in search box and see result.
Oct 04, 2008 | Sony DVP-NS425P DVD Player
Delete unwanted scenes
The FORM that you have to be on has to be VR not VIDEO. But the bad thing is on VR you cant finalize and play it as a DVD only on the computer, unlike what you can do on VIDEO.
Oct 31, 2007 | Sony Handycam DCR-DVD108 DVD Camcorder
How do I playback a particular scene?
Turn the camcorder on and press the ‘Disc Navigation’ button. A list of thumbnail previews of photos and/or movie scenes will appear Select the scene using the joystick control on the DVD-Camcorder and then press the joystick or ‘Play’ button.
Sep 05, 2005 | Hitachi DZ-GX20A DVD Camcorder
Cyberhome CH-DVD 300 DVD Player Logo
329 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
