Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
The fridge has been working fine the past two weeks, but it has a horrible smell (like a burned motor or something) coming from inside. It's making all the food smell bad. What could this be? It's cooling fine
  • Frigidaire Master
  • 8,220 Answers
If you notice frost in the freezer that could indicate a burned out defrost heater. Might just be the smell.
Posted on Feb 05, 2010
I have DME321XE16 De Dietrich microwave. I have a problem as for the past week I have been able to smell a burning plastic smell coming from the control panel when microwaving something. I have checked as...
i would recommend not to operate it in this situation & should be opened and investigate the cause of the smell, most likely it'll be a very hot component on the board or a freaky contacts.
Oct 29, 2017 | Microwave Ovens
There is a strong odor coming from the freezer something like a fish smell or a burnt wire. The ice maker is working ok and the fan blows air just fine and the freezer and refrigerator are operating just...
The smell could either be the fan motor or the defrost heating coil...
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Mar 18, 2011 | Amana ABB1927DE Bottom Freezer...
I have a burning smell coming from inside my kitchenaid superba side by side fridge. It smells like a burning plastic. The fridge still turns on and keeps things cool, but it started to kick out that...
Remove the power plug and move your fridge forward. Now look at the rear bottom side of the fridge to see if there are any parts that heats up. You can trace this to the smell emitting from the heated part and confirm. It can be the motor, contactor or the defrost timer.
Mar 18, 2011 | KitchenAid (KSRD22FKST) Side by Side...
Unfortunately I cannot locate the manual but there is a horrible sweet smell coming from the back of the fridge on the outside. The inside smells fine. Where is the drip tray and how do I check for what...
drip tray is around the back you have to remove the lower panel where the compressor is located should be 6-8 screws holding the panel on sometimes it is made out of cardboard other times its made out of metal unplug machine when going inside to see what the smell is some small animals may get caught inside and chopped up by the fan blades hopefully this is not the case for your occurance of smell but it is something i have seen hope this helps
Jul 24, 2010 | Frigidaire Refrigerators
The engine started to make a horrible noise and practically jumped off the counter while it smelled like something burned.
these juicers have a tiny little motor. once they smell bad, they are shot. not worth repairing. Joe
Mar 04, 2010 | Jack Lalanne Power Juicer 250 Watts
I have a burning plastic smell coming from my refrigerator, the fridge is not working, but the freezer seems to be working fine. The smell is horrible though. please help
This is a serious issue, your appliance is a fire hazard. It's more likely that a electronic board is catching fire. I highly recommend you to get a technician to check the appliance. Don't wait until you see flames.
Dec 18, 2009 | GE Refrigerators
BURNING SMELL COMING FROM MY WASHING MACHINE
if it smells like rubber burning then i would suspect a belt is worn or slipping or somthing has jambed the basket from turning .. the belt is not expensive ..labor of course would be extra .. if the burning smells like insulation or a strong electrical burning smell then you may have a bad motor .. those used to be about $70 + labor .. no telling what they get for them now ...
you mention that the smell came from inside ... do you mean inside where the cloths are (the tub) or inside the cabinet (outside of where the cloths are) ...if the smell was coming from inside the washing tub .. then i would suspect something cought between the inner and outer tubs .. if the smell is not from there then the first suggestions above are good ... bras and slippers and such are good for getting cought .. check where the movable tub (with holes) meets the outer tube (no holes) .thats at the very top of the tub .. ..make sure nothing it cought there ...
Aug 05, 2009 | Washing Machines
Bad smell coming from fridge
Unplug fridge. Remove the panel on the back of the fridge look for dead rodents or fungal growth in the drain pan. consult your local appliance parts distributor for a product called kleene air or try www.reliableparts.com
Apr 01, 2009 | Refrigerators
Burning Rubber smell coming from fridge
try taking the bottom panel off and vacuming all the dust on the coils. The dust may be heating up and burning. The coils are usually at the bottom of the fridge. Check to see if the fan is running also.
Jan 16, 2009 | Refrigerators
Ice tastes funny and a strange metallic or plastic type smell
Sometimes the smell comes from something in the freezer or even the refrigeratior and makes the ice taste funny. My suggestion is to clean out the freezer compartment of anything frozen that has been there a while and may have freezer burn. That may be the funny smell you are experiencing.
Hope this will help you.
Jan 15, 2009 | KitchenAid KSRS25IL Side by Side...
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
384 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
