Question about Sunbeam 5890 ExpressBake Bread Maker
Loud noise and not kneading
I haven't used the machine in a long time...so I can't remember how it should sound. When I started the basic cycle it was much louder and clankier than I thought it had been. Also, after about 3 minutes into cycle after the ingredients had mixed into a sticky ball it still sounded like it was running but the dough ball was just sitting there...it didn't appear to be kneading at all. I stopped the machine to, hopefully, keep from burning it out or something. Is this normal?
  • vwsmith Jan 29, 2009
    I've been using my bread machine for a good while and have never had problems. I use the dough stage the most. However, it has started getting louder and the last 2 dough balls I made were STICKY--that has never happened to me and they're dough recipes I make all the time.
    I'm not sure if it's kneading or not, but is this the end of my machine?
    Problem Solver:
  • 3 Answers
No, not normal. Your belt is probably gone.
Posted on Dec 29, 2009
Refrigerator is louder when it turns on maytag performa side by side model psd262lheb
sometimes, as the machine starts to get a little age on them, the Freon flowing through the unit will get a little loud during the first minute or so of cycling on and for about a minute after unit cycles off. could make banging sounds, popping sounds even might sounds like water running or rain. All those sounds are normal operational sounds. I would not worry about those sounds unless you start to notice a slow temp. increase in the next few months. If you start to notice cooling issues, then I would start to get concerned about a sealed system issue.
Feb 26, 2015 | Maytag Washing Machines
Mav6000awq
well..that would certainly make it sound better. you might want to check the bearings and belts first though..
Mar 10, 2008 | Maytag MAV3855A Top Load Washer
My West Bend Homestyle Plus bread machine makes clunking sounds when it mixes the dough. The paddles are in correctly, but seem loose on the spindles. I hadn't used my machine in quite some time (years)....
like you, I pulled my bread machine out after several years. It clunked loudly for the first few loaves and then it settled down. It's still louder than I remember, but it seems to work fine. I try to be home whenever I use it, as I don't completely trust it. Otherwise the loaves are turning out amazingly well!
Jan 23, 2011 | West Bend 41053 Bread & Dough Maker
My washer is very loud when it is in the spin cycle.
if the machine is more than five years old or it gets a lot of use it sounds like the drum bearings are starting to wear. If it sounds like a jet taking off when it begins to spin then thats your problem. Basically bearings have seals which over time and use will eventually allow water in and the bearings will start to wear. Now is the time to get the bearings done before they seize. It can be a laborious and expensive job
May 24, 2010 | Kenmore 43042 Front Load Washer
Washing machine began squealing like a bad bearing
my first thought is belts, but maybe pump
need more info for proper dianosis
Apr 24, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Washer very louded in spin cycle.
Most likely this will be the drum bearings.
Bearings normally last quite a long time but some will fail sooner than others. Quite often bearing failure is due to a faulty drum shaft seal which allows a small amount of water through and in to the bearings. The bearings then start to rust, which then accelerates the wear on the bearings.
Replacing the bearings needs well above average DIY skills to do, so unless you feel confident to tackle the job, can get hold of a tech manual, and can get hold of new bearings, it's time to call an engineer for a quote and then draw your own conclusions as to whether it's worth it.
Oct 02, 2009 | Washing Machines
Washer gw11us
If it makes it through the cycle from start to finish ,consider yourself a lucky one.If it breaks I don't recommend fixing this.
May 18, 2008 | Fisher and Paykel GWL11 Top Load Washer
Washing machine is louder then normal on the spin cycle.
This sounds like the rear bearing is going. After getting louder, the next problem is grease appearing on your clothes during the spin cycle. This is a very major repair.
Jan 10, 2008 | Kenmore 43042 Front Load Washer
Vibrating noise when cooking
In order to try to set your mind at ease I will have to explain the Basics on how a Microwave Oven Functions.
When a Microwave Oven is set to COOK ...START. It cooks at 100%. There is no lowering of the heat as with a Range ( Cook Top) Control. So in order to do the other things such as DEFROST, WARM, or anything other than 100% COOK. A COOK ON- COOK OFF system was utilized. To DEFROST, the Microve COOKS at 100% for 30% of the TIME, then IDLES for 70% of the TIME. COOK ON 30% of the TIME, COOK OFF 70% of the TIME = DEFROST This is why you can hear the CYCLE. More power is required during the ON CYCLE, thus the lower vibration. The Vibration occurs when the High Voltage Transformer is turned ON ( COOK ON).
The VIBRATION seems to have got louder with age. This is somewhat normal as there is a vibration from the High Voltage Transformer present every time the Microwave is used. screws and other metal parts seem to get loose with this vibration. There is no solution, unless you can tighten EVERY screw, nut, and bolt in the unit.
Sorry!
Dec 07, 2007 | Kenmore 62642 / 62644 / 62649 Microwave...
Sunbeam 5890 ExpressBake Bread Maker Logo
129 people viewed this question
Top Sunbeam Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Sunbeam Kitchen Appliances - Other Expert? Answer questions, earn points and help others
