How to replace the outer clamp on the rubber
How to replace the outer clamp on the rubber baffle of a sears Kenmore front loading washer
  • 5,911 Answers
If you are referring to the front bellow clamp (wire hoop with small spring), the following link explains the steps required to install the bellow and both clamps:
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
Refer to step 12 where it explains how to reinsert the front bellow clamp after ensuring the rubber bellow is seated properly all the way around the perimeter of the door opening. If you need further assistance please let me know. I hope this helps you.
Posted on Feb 05, 2010
How to replace the drum baffles on a Kenmore HE3 front load washer?
Hello Dennis
Appliancepartspros does indeed show an entire kit for EXACTLY YOUR problem... $34
Good time to compare SEARs prices... for those very same parts!!
Happy hunting!!
Sears
Water Filters Lawn Garden Appliance Parts
Appliance parts
http://www.appliancepartspros.com/search.aspx?model=kenmore%20he3t
May 15, 2016 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Removing outerseal on my frigidaire front load w as sher
Are you asking about the rubber door boot/seal??? The outer edge is held on by a spring loaded wire that runs around the door opening. You can see it if you lift the outer edge of the boot close to the painted cabinet front. The inner edge of the boot is help on by a very big hose type clamp. Some models you can get to it through the opening after you remove the outer wire. Some models need the washer top removed to get to the clamp screw.
Jul 06, 2014 | Frigidaire ATF6000ES Front Load Washer
Washer door leaks
The front baffle/boot will likely need replaced. You can do this yourself but it takes some patience. You can order the part, list model #, at 888-321-3107. The procedure is as follows:'
1. Tilt washer, back against wall.
2. Remove wire spring with needle nose plyers. The spring is located at outside perimeter, under lip, of baffle.
3. Peel baffle from front panel.
4. Remove clamp from the outer tub lip. Look closely and you should find a large hose clamp. Use small socket wrench to loosen.
5. Install in reverse order. Be careful and take your time.
Rich
Western Appliance Repair
Washer Repair
Sep 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My Kenmore Elite washer is leaking when it fills with water
I followed the instructions on how to replace the boot from your website. When i got in there i realized that the metal clamp holding the boot secure to the outer drum area had come lose...so i just reattached the boot around the outer edge of the drum and tightened the metal clamp and put in all back together again. I have NO LEAKS! and i didnt even have to replace any parts!!
Jun 01, 2009 | Kenmore Elite 45986 Front Load Washer
Replacing the drum baffle in kenmore elite he3t front loading washers
The baffle basket, I ordered from sears for my Kenmore Elite he3t washer was a "new" design but the screw holes lined up. My baffle basket did not come with the screw either. I took out the screw from an existing baffle basket and found something close. Test it in the baffle basket before you try to install it. Be careful not to drop the screw or bit.
To replace the baffle basket. Remove top of washer using a screwdriver with a T20 torque bit. There are three screws at the rear. The top slides back about an inch and lift up. Place aside. Then you will see a hose going into the drum. Ignore the clamp, just squeeze the end going into the drum and work it out. Now you need to insert the baffle basket in the drum through the front door. It is easiest to rotate the drum so you are inserting it on the bottom. It slides in with the small end toward you and you must pull it forward. Hold the drum for leverage. Now rotate the drum so the new baffle is on top. You need to line up the screw hole and screw in a small screw. Replace the hose and top of washer.
Good Luck...
Aug 09, 2008 | Washing Machines
Front Door Seal/Baffle Replacement
I need to replace a baffle from inside my Elite HE3T. Do you have directions? Only 1 came off but when I order the new one apparently it only comes in 3, so show I replace the other 2 as well? (if I can figure out how)
Of course the part did not come with any! And Sears customer service is of no help and the technical people have not responded to me.
Thanks,
Jul 16, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore 40922 front load
This advice from Sears to replace baffles only applies to dryers. The baffles for the washer are installed from inside the basket. If you can't locate mounting from inside the basket, then the entire basket/tub will have to be removed and disassembled.(big job)... But I am pretty sure they mount from inside. Washer or dryer, there are three screws in the rear along the top. Remove screws, slide top toward rear and lift off.
Jun 07, 2008 | Kenmore 4292x Front Load Washer
Tub seal has rip therefore washer is leaking.
Its pretty comlicated requires dissasembly of the front of the washer. A good tech can do in 1 hour. You may want to pay for it rather than spending all day and possibly damaging something. Let me know if you need further assistance.
Jan 24, 2008 | Kenmore Elite 45986 Front Load Washer
How do you get the front panel door off?
three screws behind kick plate remove,them two screws holding on doorlock remove them, remove outer clamp on door boot,pull panel from the end near were kick was,some of those machines have 3 more screws behind control panel? see how you get on and let me know . close Ireland bye for now!
Nov 22, 2007 | Kenmore Elite 45986 Front Load Washer
Distroyed drumb
if it is only the rubber gasket and the spring loaded clamp that holds it in place it is worth repairing. if the tub, inner or outer, is damaged it is probably time to replace it
Sep 19, 2007 | GE WSXH208A Front Load Washer
Washing Machines Logo
206 people viewed this question
Top Washing Machines Experts
