Question about Acer Aspire E380-UD420A (ASE380-UD420A) PC Desktop
My dvd door will not open? I can hear it attempt to open but it give up. Can I replace the dvd unit?
    Sergeant:
  • 206 Answers
If you have a paper clip handy you can unfold it and use it to stick in the emergency eject hole. If you look on the face of it there will be a tiny hole just big enough for the paperclip...a disc may be jamming it...if you get it out it will likely fix the problem.
Posted on Feb 05, 2010
Dvd door won't open
Someone is going to have to open the unit to see what is happening--either a disc is jammed inside or a mechanism problem.
Sometimes with unit apart you may be able to gently probe and free the jammed area--possible also something that does not belong there got inside--look closely.
Jun 16, 2012 | Daewoo DV6T-81N DVD Player / VCR Combo
The dvd door doesn't open
plug out the player for 5min from wall power and then plug in.
else you wil have to open the player and push it out manually.
Sep 04, 2008 | GoVideo Televison & Video
I have a DVD Recorder, Lite-On LVW-5005X. I have been having sporadic problems with the disc tray not opening for some time. But usually after repeated attempts, it would open. I have recorded and...
You need to replace the disc tray belt,it streches with age.It is called a square belt,size 1.9.To open try tapping on TOP of cabinet with your knuckles just above the disc tray door.While you are doing this press the Open button.Once again this must be done at the same time,the door will open 90% of the time.When you get it open you will see the little black square belt,this can be removed and replaced with a twizzers.Make sure belt is in the track if not it will jam and door won't close.
Dec 10, 2010 | Lite On LVW-5005X DVD Recorder
When big buck hunter pro is turned on I'm getting system boot failure. This has happened a few time over the last month. The last time it happed I turned game off and it booted up. This time it is not.
Reimage the hard drive by opening the DVD drive door and inserting the recovery disk, which is obtainable from a distributor such as Betson in the US. Close the DVD drive door and power the game off then on again. Follow any on-screen instructions as the software installs. If this procedure fails or the game still gives trouble, you may have a failing hard drive. You could attempt replacement yourself if you feel up to it, or alternatively send the entire computer unit to a distributor or specialist dealer for testing and possible repair as necessary.
Mar 12, 2010 | Arcade Raw Thrills Big Buck Hunter Pro...
Dvd player will not open disc, display lock
Sound like it either has one or two problems, the door is stuck and or the door eject motor has failed. Look in the front to the player for a small paperclip like hole, and use a paper clip to manual eject the and engage the loading mechanism usually located under the door for most cases. Check you manuals troubleshooting section for manually ejecting a CD..
Please leave comment.
Oct 12, 2009 | JVC XV-N312S DVD Player
Liftmaster 1/2 hp won't open
Turn the gears again by hand like you did and lower the door a couple feet. Now find the 'up limit' on the side of the motor unit and using a small screwdriver turn this about 3 turns in the opposite direction of the arrow printed on the cover. Now you can go ahead and operate the door.
May 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
DVD going crazy
Not sure what the problem is..could be a problem with the relay or powerboard. Best bet is to get a repairman take a look at it. Dont try to open it yourself, as there are high voltages inside (even when powered off) that can kill...
May 17, 2008 | Televison & Video
Rca dcr8060n dvd tray will not open
Your kid did not damage it, try this, apply pressure slowly to the top of the unit about 3 inches from the front of the unit centered above the tray. Press the eject button, I am betting it will open. They seem to have used really crappy dvd drives in this unit and the top magnetic mount does not release cleanly, therefor causing the unit to hang when the door attempts to open.
Jan 29, 2008 | Televison & Video
Acer Aspire  E380-UD420A (ASE380-UD420A) PC Desktop Logo
77 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
