Question about Kenmore 53642 / 53644 Side by Side Refrigerator
I have a kenmore side by side refrigerator/freezer with an ice and water dispenser in the freezer door. The ice dispenser quit working. It doesn't even make a noise when you push the lever that is suppose to turn on the dispenser. Any ideas as to what might be the problem?
  • 572 Answers
Ice bucked is jammed
Posted on Feb 05, 2010
  • debdave58 Nov 23, 2010
    I have the same issue and there is no ice in the bucket and everything rotates freely. Could it be the switch in the lever assembly? I do not here a "click" when activated. Thank You
I have two problems with the Kenmore Ultra side-by-side refrigerator I inherited with my new house. 1) Water and Ice Dispenser do not dispense. Ice is being made but doesn't come out and water...
check the switches inside the panel where water and ice come out. that front panel comes off. this happened to me those switches are mounted on plastic mine broke and I used zip ties to put them back in place. The switches were just dangling there.
Aug 04, 2011 | Kenmore 53642 / 53644 Side by Side...
Freezer door lost power, will not dispense ice or water, light does not work Kenmore/10 years old /side by side
Check the door switch.
If the door switch is not working the light will not work and the ice or water will not work.
John
Sep 28, 2009 | Kenmore 57029 Side by Side Refrigerator
Freezer is too cold, ice crystals. Refriderator
I'm not sure which one you have, but try this: Look for the area where the air passes from the freezer to the refrigerator side, in the wall somewhere between them. Make sure that there isn't something blocking the passage. This is a good place to start.
Regards,--W/D
Jul 10, 2009 | Kenmore Refrigerators
No water but ice is fine
turn freezer side to zero for 1 minute press water dispenser
Mar 29, 2009 | GE GSH25JSRSS Stainless Steel Side by Side...
Ice does not dispense through door of kenmore elite side by side
take ice bucket out, dump ice, clean with hot water and let dry ,,,, put ice back in and try it ,,, bucket is most likely frozen up thru ports
Nov 28, 2008 | Kenmore 53642 / 53644 Side by Side...
ICE MAKER NOT WORKING
Check to make sure you freezer is at 0 to 5 degrees. If it is not the water valve to the ice maker will not even open.
Nov 20, 2008 | Kenmore 53642 / 53644 Side by Side...
check the mirco-switches behind the panel at the dispenser section. basically, when you depress the lever for water or ice, those levers make contact with a switch, and the switch turns on the ice dispenser motor. if the lever is pushed too hard, the switch can be knocked out of position. I had to re-position my ice switch with some duct tape.
Feb 16, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore Refrigerator stopped dispensing water
Either your water tank in the fridge froze up, the waterline that goes up the freezer door from the bottom hinge froze, or the switch that your glass hits is damaged. Do you hear any humming or noises when you put your glass up to get water?
Oct 27, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice maker failure
1) Check the filler tube which allows water to enter the dispenser through the back wall of the freezer. This tube may be frozen inside. You can pull the tube out gently and clear it.
2) The inlet valve may be faulty/blocked. Where the water connects to the water valves behind the fridge, try to swap the plugs around from the one valve to the other. They should be colour coded. Then try dispensing water. If water runs into the ice-maker then the ice maker valve is faulty/blocked.
Oct 23, 2007 | Kenmore 50522 / 50524 Side by Side...
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
377 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
