Question about Kenmore HE2 Plus Front Load Washer
Getting rid of a horrible stink in my washer kenmore HE2
  • 5,911 Answers
The following link will give you some tips to try in order to minimize odors and mildew in a front loading washer:
http://www.fixya.com/support/r3608512-getting_rid_front_loader_mildew_odor
Following a good regiment of routine cleaning of the door bellow, followed by leaving the door open when not in use (at a minimum) can go a long way towards preventing odors in a front loader. Since the doors on these washers are water tight when closed, it is importnant to leave them open when not in use to allow the drum to air out. There is a small amount of residual water that remains in the drain lines and pump that will sour if you don't. I personally own a Kenmore Elite and have never had problems with mildew or odor in the 9 years I've had it by following this routine.
In addition, it is a good idea to periodcially check the drain pump reservoir to ensure there is not dirt or debirs clogging the pump and becoming stagnant. The following link explains how to access and clean the drain pump (if necessary):
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loade
The drain pump reservoir collecting debris, along with small articles of clothing getting caught in the folds of the door bellow are the two main causes of odors in a front loader.
Read through the links provided and let me know if you have any questions. I hope this helps you.
Posted on Feb 05, 2010
Testimonial: "I love this site. You all helped me fix my dryer and now you gave me good advice for my washer. Thank you very much. Rob"
F-24 error code so I ran a clean washer cycle, and the laundry room is now flooded.
what's f24 code? - Kenmore Elite HE3 Washing Machine ...
https://www.ifixit.com/Answers/View/85549/what's+f24+code
iFixitAug 21, 2015 - Aiman, The F24 error code indicates a water temperature sensor reading that is ... The Kenmore Elite HE3 is a washing machine by Kenmore.
F24 Error Code on My Kenmore Washer ' eHow
www.ehow.com > Home
F24 Error Code on My Kenmore Washer. Kenmore washing machines have several high-tech features, such as a stain treatment option, reduced energy and ...
Kenmore HE2 Plus Front Load Washer F24 error code ...
www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
...error code F24 I have a Kenmore HE2T washer and I keep getting an F24 error on it.. I have no idea what is means can't find the manual help!!! The "F24" error ...
I have a Kenmore HE2T error code F24 - Fixya
www.fixya.com/support/t3608391-kenmore_he2t_error_code_f24
Dec 9, 2009 - Posted on Dec 09, 2009.
Dec 06, 2015 | Kenmore HE2 Plus Front Load Washer
Why and how to get rid of smell on clothes with a kenmore He2 front load washer
Hi. inside the door seal is a lip that will grow mold or some kind of soap scum that turns black. pull back the edge of the door seal and wipe out with spray bleach ( wear gloves ). Leave the door open a little when you are done using it and that will help to let it dry inside.
Good luck
Aug 24, 2014 | Kenmore HE2 Plus Front Load Washer
I recently started getting a sewer smell during parts of teh wash cycle??
Once a month you need to wash the inside of your HE machine with a good cleaner. Here is what I use to get rid of the bad smells.
Dec 27, 2010 | Kenmore HE2 Plus Front Load Washer
This kenmore washer makes my towels smell horrible this has been a problem for the two years I have had the washer. I can't take it anymore
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip about how to clean your washer
How to have a Clean Washer
heatman101
Sep 03, 2010 | Kenmore HE2 Plus Front Load Washer
Towels smell moldy when washed and dried
run the machine on a 95 cycle,whilst adding a litre of white vinegar.this should get rid of the smell.
Oct 24, 2009 | Kenmore HE2 Plus Front Load Washer
HE2 Plus washer will not complete the rinse cycle.
Hi!!! You best been usin he detergent if not you are in trouble..You have a sud built up..clean all the water out and go to sears and buy whirlout for he machine..tell them that you have suds and want to clean it with whirout..good luck..
Jan 04, 2009 | Kenmore HE2 Plus Front Load Washer
My kenmore he2 plus washer is showing f21
"F21" is a Long Drain error. This occurs when the drain time exceeds 8 minutes. You will need to remove the bottom panel under the door by removing the two screws at the bottom edge of the panel. First, check the electrical connections to the drain pump and make sure the pump is running. Check the drain pump filter to make sure it is not clogged with debris. This is a very common problem. HINT: Before removing the drain pump filter, pull the drain hoses from the standpipe at the wall and use a shop vac to pull a vacuum on the drain hose to get rid of all residual water from the pump and drain lines. This is also a good way to get rid of minor clogs. If you do not own a shop vac, be prepared to lay down some old towels and soak up some water. There's quite a bit of residual water in the wash tub and lines (this is normal). In addition, check your drain hoses to make sure they are not clogged or kinked. If you check everything and still have the error code, replace the drain pump. Replacement parts can be found at searspartsdirect.com and repairclinic.com. Just type in your model number in the search menu. I hope this helps you. If you require further assistance, please let me know.
Aug 16, 2008 | Washing Machines
Kenmore HE2 Plus Front Load Washer Logo
221 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
