Question about Brother IntelliFAX 4750 Plain Paper Laser Fax
Won't receive or send
Says printing online, but can't receive or send faxes.
  • 5 more comments
  • Anonymous Mar 06, 2008
    I have the same issue.....Anyone have a solution?
  • Anonymous Apr 03, 2008
    Same problem
  • Anonymous Apr 08, 2008
    I had the same issue with a brother 4750e and I kept unplugging it and then I tried to hold the "Start" button and then plug it in and it started to print
  • guest54321 Apr 09, 2008
    Same exact problem... Nothing seems to fix.. Anyone have any ideas?
  • Anonymous May 07, 2008
    SCREEN SAYS PRINTING ONLINE AND MACHINE DOESNT DO ANYTHING DOESNT PRINT SEND RECEIVE OR ANYTHING
  • dhewittt Jun 26, 2008
    I tried to use the solution listed but it will not default from the regular "menu". When I hit the "menu" button it will not allow me to enter the *2864. Is there a work around
  • maryb533 Aug 20, 2008
    Fax will not receive or send. It also displays printer online
    I have reset and changed the drum.
I called Brother Customer Support and they told me to unplug the 4750e and then while holding the stop/exit button plug the fax machine back in. Worked like a charm!!
Posted on Sep 05, 2008
Try hitting Menu * 2864 (it should say maintenance) then 91 then 99
This will reset the fax machine without erasing your settings. It should clear it up. If it doesn't work after a few tries, you have to hit 0 instead of 91 and that will reset the entire fax machine to factory defaults.
Posted on May 28, 2008
4 Suggested Answers
  • 159 Answers
SOURCE: Hi, My office fax machine will not send or
Sounds like a glitch in the memory has left a document there, unable to print. You'll need to clear it out by going into the Maintenance Mode. Maintenance Mode is not mentioned in your user's manual, because there are several functions available that can seriously disable the machine. All you have to do to be safe is follow these instructions to get into the mode, clear the memory, then get out without messing around with other functions.
Press these keys in rapid succession:
Menu
* (the star on the dialing keypad)
6
Do that whole sequence in 2 seconds or less, ignoring all the beeping the machine will assault you with. It's designed to not allow some to accidentally enter Maintenance Mode; if you wait for the beeping to stop, you'll fail, left in some part of the normal menus. When you succeed, the word MAINTENANCE will appear on the display, and all the lights will flash in unison. If that doesn't happen, just touch the STOP button and try again.
Once in maintenance Mode, touch 91 on the number pad. The display will say Initializing or something like that as it clears all the documents form the memory. Your programmed phone numbers and settings will not be affected. When it finishes it will go back to MAINTENANCE. Unplug the power for a few seconds, then plug it back in. The machine should be fine and ready to use.
If Function 91 doesn't work, you should try going back into MAINTENANCE and touch 01 instead. It will clear all memory back to the point it was when you first unboxed the machine. But I think 91 will take care of everything.
Posted on Feb 15, 2011
  • 167 Answers
SOURCE: sending a legible fax
THE CIS SCANNER /REFERENCE WHITE NEEDS CLEANING AND THE CIS TRAINING NEEDS TO BE DONE.
IF ABOVE DOES NOT HELP U NEED TO REPLACE CIS .
HAPPY FAXING
OMNIPRESENT
Posted on Oct 16, 2007
  • 215 Answers
SOURCE: display says "printing online" but it is not connected to a PC
unplug machine, press and hold down the "stop/exit" key while pluggung back in. continue to hold the button down for 5 secs, then release. if machine returns to the regular date/time display, you should be alright. if not, then you'll have to call brother or an authorized service center. this is usually caused by a fax stuck in memory, which this procedure should clear.
good luck,
razors
Posted on Feb 18, 2009
Brother mfc-7840w won't receive fax
The first thing that I would try multiple people to ask them to fax you.Sometimes the 2 machines don't "sync".This is a toll free fax test number that I always use to check my machines..1-888-473-2963.Just write the words "FAX TEST" in large letters on a blank sheet of paper..fax it to that number...leave the line open...you should get a fax back in about a minute.If you get a fax back...your machine is fine...let me know if this was helpful....thanks.
Dec 14, 2011 | Brother MFC 7840W Printer
How to I turn off the automatic printing of the fax logs.
To change fax confirmation
1. Press Setup.
2. Press Print Report, and then Fax Confirmation.
3. Press the right arrow button to select one of the following, and then press OK.
Off - Does not print a fax confirmation report when you send and receive
faxes successfully. This is the default setting.
On Fax Send - Prints a fax confirmation report for every fax you send.
On Fax Receive - Prints a fax confirmation report for every fax you receive.
Send & Receive - Prints a fax confirmation report for every fax you send and receive.
May 03, 2011 | HP Officejet Pro L7780 All-In-One InkJet...
How can I get a FAX Confirmation printed out on the HPJ4680?
If you require printed confirmation that your faxes weresuccessfully sent, follow these instructions to enable fax confirmation beforesending any faxes. The default fax confirmation setting is Off. This meansthat a confirmation report is not printed for each fax sent or received. Aconfirmation message indicating whether a fax was successfully sent appearsbriefly on the control-panel display after each transaction. NOTE: You can include an image of the first page of the faxon the Fax Sent Confirmation report if you choose On Fax Send or Send &Receive, and if you scan the fax to send from memory To enable fax confirmation
1.Press the (Setup) button.
2.Press right arrow to select Print Report, and then press OK.
3.Press right arrow to select Fax Confirmation, and then press OK.
4.Press right arrow to select one of the following, and then press OK. Off Does not print a fax confirmation report when yousend and receive faxes successfully. This is the default setting. On Fax Send Prints a fax confirmation report for every faxyou send.
OnFax Receive Prints a fax confirmation report for every fax you receive.
Send& Receive Prints a fax confirmation report for every fax you send andreceive
Jan 10, 2011 | Office Equipment & Supplies
HP 6310 All-in-One. How do I get a fax confirmation?
If you need printed confirmation that your faxes were successfully sent, follow these instructions to enable fax confirmation before sending any faxes. Select either On Fax Send or Send & Receive.
The default fax confirmation setting is Off. This means that the HP All-in-One will not print a confirmation report for each fax sent or received. A confirmation message indicating whether a fax was successfully sent appears briefly on the display after each transaction.
To enable fax confirmation from the control panel
1. Press Setup.
2. Press 2, and then press 3.
This selects Print Report and then selects Fax Confirmation.
3. Press to select one of the following, and then press OK.
Off Does not print a fax confirmation report when you send and
On Fax Send Prints a fax confirmation report for every fax you send.
Fax
On Fax Receive Prints a fax confirmation report for every fax you receive.
Send & Receive Prints a fax confirmation report for every fax you send and
receive.
Oct 27, 2010 | HP Officejet 6310 All-In-One InkJet...
My fax machine sends faxes, prints, and received faxes but the faxes are blank. We have been trying to figure out the problem and while fiddling with the machine have actually received a successful fax???...
Probably not. You can change that setting in the user modes in menu/function and set it to 99 minutes. HAve you tried another drum unit? Your charge corona wire in the drum unit maybe broken!
Aug 28, 2009 | Brother IntelliFAX 4100 Laser Fax
How do I get a fax conformation?
This is an excerpt of the User's Guide for your machine. You can download from here:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=1138342&
Print fax confirmation reports
each transaction.
1. Press Setup.
2. Press 2, and then press 1.
Send & Receive Prints a fax confirmation report for every fax you send and receive.
User Guide 65
Fax
Tip
If you choose On Fax Send or Send & Receive, and scan your fax to send from memory, you can include an image of the first page of the fax on the Fax Sent Confirmation report. Press Setup, press 2, and then press 2 again. Select On from the Image on Fax Send Report menu.
Aug 14, 2009 | HP OfficeJet 4315 All-In-One InkJet...
Wish to print outgoing fax log date/time/number
I don't think there's a log you can print but you can do the following. Not quite what you want, but better than nothing...
You need to set the fax confirmation option to log faxes before you send anything. The default option is off, so you won't be able to get a fax log for anything you've already sent unfortunately.
1. Press Setup
2. Press 2 then press 1. This displays the Print Report menu
3. Select Fax Confirmation
4. Press c00424037.gif to highlight one of the following, then press OK
Off Does not print a fax confirmation report when you send and receive faxes successfully. This is the default setting.
May 06, 2009 | HP Officejet 5610 All-In-One InkJet...
01.12.2008 i fax to one number. now i want aknowledgement of that fax. its gone or not. How i can find on HP Officejet 5610 all in One System?
You can get the manual here if you do not have one - LINK.
Here is an exert form the manual on this:
1. Press Setup.
Send &
Receive
receive.
Dec 10, 2008 | HP Officejet 5610 All-In-One InkJet...
Brother IntelliFAX 4750 Plain Paper Laser Fax Logo
447 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
