Question about Craftsman Saws
Will a sears craftsman tablesaw 113.275 rails and fence fit a 113.298 saw
SOURCE: Can I mount a Delta 36-T30 T2 30-Inch Fence and Rail System on my
I just installed a Delta T2 fence on my 10" Craftsman Table Saw. It's 27" deep. The bushing either could be relocated or you could use spacers on the front, back, or both on the saw to get the required distance. Also, you'll have to drill new holes, however, I used one of the existing holes in the front and back of my saw as well.
Posted on May 15, 2009
  • 4088 Answers
SOURCE: I just bought a Sears radial arm saw. Model
Go to searspartsdirect.com and list the model number which brings up drawings of all parts and usually a manual. Hope this helps!
Posted on Feb 08, 2010
odiebugs
  • 949 Answers
SOURCE: need substitute switch part for sears saw
Sorry , but go buy a new saw. Your not going to find an aftermarket
dealer that carries this switch.
Trying to rig some other switch is not worth the trouble over buying a new one. If the switch is not available, then the saw is old.
New
Craftsman Evolv 12 Amp 7-in Circular Saw 35.00 dollars.
Posted on Feb 15, 2010
  • 4088 Answers
SOURCE: Need help locating a manual for an old Craftsman saw
Go to Searspartsdirect.com and list the complete model number minus the decimal point. You will get a series of drawings listing all of the replaceable parts and hopefully, the manual. Hope this helps!
Posted on Jun 22, 2010
Testimonial: "Good advice which I followed and it worked."
  • 760 Answers
SOURCE: Craftsman circular saw 7 1/4" broken handle
You can buy the handle for 11.59 per side (left and right halves) you can buy them from: www.searspartsdirect.com They have substutited a new part (probably better one) You would have to decide if 25.00 is worth it to fix your saw. You could buy the part and fix it yourself. A new saw like this one is probably not more than 75.00
Posted on Jul 19, 2010
2 questions re Craftsman Tablesaw 137.218072 since the young men in that dept at our Sears did not know what a table saw was!
You can find a nice quality feather board that will fit your table saw from www.leevalley.com. They have one that comes with both 5/8" and 3/4" table bars and sells for about $15. I have one and it works great, Look under the Woodworking tab and type in feather boards. Look at the brand Versatile Featherboards. http://www.leevalley.com/US/wood/page.aspx?p=60022&cat=1,240,45884,60022 You may want to call Lee Valley to see if they have a zero clearance insert that will fit your saw. Otherwise, order a new insert from Sears Parts Direct. From the picture on their website I believe it comes as a blank and you will need to cut the new opening in the insert. To do that lower the saw blade all the way below the table top, install the new insert, move the rip fence over top of the insert but not over where the saw blade would penetrate, turn on the saw, and slowly raise the blade up through the insert.
e1e75b0f-dc3b-4bbe-bf84-360a611e8e41.jpg b3efb051-1d00-43f6-bc27-d2f9d84da710.jpg
Oct 02, 2014 | Craftsman 10" Table Saw
Sawblade is not parallel with fence on delta tablesaw
The Rip fence SHOULD toe out aprox 0.010mm over the length of the rip fence to prevent binding. Adjust using the Rip fence to measuring rail. Should be adjusters there but if its an old saw, you may have to adjust the measuring rail where it meets the saw frame.
Jan 06, 2014 | Delta Saws
I need a fence for my model # 113221770 craftsman table saw
look at the uni9 fence by delta or the better yet from general. Delta is part poor. retrofit shouldn't be too much of prob.
Dec 28, 2013 | Craftsman Sears 10" Table Saw Extension...
Is there an after-market up-grade for the rip-fence on my sears craftsman table saw - model 113.298151 ?
i need a replacement fence for my craftsman model #113.298762 craftsman no longer makes them . the only other replacement , i found was a delta 36t-30 t2 , which also no longer made thanks bill in ohio
Dec 19, 2012 | Craftsman Radial Arm Saw Table Locking...
I need a table saw motor model rm871 where can i go to get it?
Sears.com would be the only place that I know of, I also think that the motor number has changed,
Oct 02, 2009 | Saws
Need motor for craftsman table saw model rm871
Go to midlandhardware.com.For about $4.00 more than just price ofthe motor,you get the complete saw 15amp.motor with a laser guide!The table saw has a 3yr. warranty,3 extension wings,and a sturdy stand.Shipping to your door $24.00,$198.58 total.
Jul 03, 2009 | Craftsman Saws
I have a Craftsman table saw with a burned out motor. The motor model number is RM871. Where can I find one for less that the $130.00 that Sears wants for the motor. That's the price of the saw.
SOUNDS LIKE THE PROBLEM I HAD, BUT WAS JUST A SEIZED-UP BEARING. I WENT TO LOCAL ELECTRIC MOTOR REPAIR ($15.74) PARTS AND LABOR, THEY REPLACED THE BEARING, THERE ARE 2 BEARINGS ON IT, COST IS THE SAME FOR EACH. THE BEARING IS PRESSED ON, SO REPLACEABLE. HOPE THIS HELPED
Mar 27, 2009 | Craftsman 10" Table Saw
Mar 11, 2009 | Delta 36 T30 T2 30 Inch Fence And Rail...
Saws Logo
61 people viewed this question
Top Craftsman Saws Experts
Mike
Are you a Craftsman Saw Expert? Answer questions, earn points and help others
