Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
My freezor section of my profile side by side is leaking water on the floor in front of the door
  • 572 Answers
Your drain is clogged
Posted on Feb 05, 2010
Water on drivers side floorboard . Why?
If you have a sunroof it could be the drain that follows the front pillar letting out under the front fender. These hoses are known to plug and crack open releasing water into the floorboards.
Driver side door check along top and front edge for tears or twisted looses sections. Internal to the door water can drain down along the window and is released outside the door seal. If the bottom of the door has the opening that releases the water plugged then water will drain over into the floorboard.
Jan 06, 2016 | Cars & Trucks
Water leaking in front of refrigerator freezer door on floor
drain stopped up inside back of unit that drains down to drain pan..
Oct 30, 2010 | GE Profile PSW26P Stainless Steel Side by...
GE Profile leaking onto floor
Clean the drain pan and drain line in the back of the freezer section behind the cover underneath the evaporator coil. (hint: use turkey baster with hot water) Make sure water drains when you pour it in. If it doesn't - also clean drain tube on the back of the unit behind the cover. When done - put the tube exactly where it was.
Good luck! :)
Vlad
First Choice Appliance
Apr 19, 2010 | GE Profile TPX24PBDCC Side by Side...
2002 suburban has leak in driver side rear floor. Cannot see where water would be coming from?
We had same--water on driver side rear floor (soaked!). Driver side front floor seemed dry until feeling UNDER rug, was slightly damp. We found the location of TWO leaks causing this.
Leak #1 was through the parking brake line/cable seal; Recaulked with silicone. Removed plastic trim on floor between floor and door to reveal metal channel filled with water.
Leak #2 was where the door meets the car, near the hinge. It was the accordian-looking tube housing the wiring for the door. The big, rubber, circular plug connecting it to the main part of the car had come loose and water ran down through that, into the SAME metal channel filled with water from leak #1; will seal with silicone.
Note: We found that the channel filled extensively near the front door, BUT the carpet edge from the floor near the rear seat was dipping into it, wicking it up to the rear floor. Also, upon acceleration, the water in the channel gushed toward the back, thus soaking the rear carpet.
These leaks were found by removing all plastic trim (covering edges of carpet by doors), then one of us pouring water into specific areas of the exterior of the vehicle, and the other one watching closely with a flashlight for any signs of dripping.
Feb 18, 2010 | 2002 Chevrolet Suburban
Water leaks on to floor boards when it rains.
Does it just leak when you are driving or does it leak when parked as well? The reason I ask is if it leaks when parked, you can eliminate a floor pan leak, or a leak that gets water from the wheel slinging it up in the wheel well. These things can be a pain in the *** to find. If it is not obvious, like torn, worn or out of place weather stripping, then I usually take a pressurized hose to wet only one section at a time and narrow down the source of the leak. It could be the seal around your windshield, stripping around the door, or even water getting inside your door and somehow finding its way to floor by draining along the inside door panel. Good Luck! I hope you find this to be very helpful!
Dec 27, 2009 | 1997 Dodge Ram 2500 Club Cab
Ge side by s
found norcold #160107210--new #160107200-----on E-Bay ,under RV Thermostate-----thru seller---- eastcoastrv---Lexington,South Carolina
Oct 26, 2009 | GE Refrigerators
Where is drip pan on profile side-by-side
That is from your defrost drain either being clogged with food, or covered with ice. Behind the back wall in the freezer is a drain that empties underneath the fridge. If that drain gets blocked or froze over then the water will dump into the floor of the freezer and out the door gasket.
Sep 13, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Water leaking
water leaking in door or icemaker check water valve
Feb 26, 2009 | GE Profile PSW26P Stainless Steel Side by...
Water leaking - GE Profile Refrigerator, Model: TPX21PRX
Check to see if the drain at the bottom of your freezer is plugged. When the refrigerator goes on defrost, the water has to go somewhere. Look below the coils in the freezer section and see if there is ice in the drain.
Jul 15, 2008 | GE Profile 20.7 cu. ft. CustomStyle...
Refrigerators Logo
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
