Question about Lowrance Boating
Our lowrance x135 just quite working Its less than two years old, where do we send it?
  • 425 Answers
Here is a manual for it. http://www.lowrance.com/upload/Lowrance/Documents/Manuals/x136df_0151-171_112003.pdf ,
Take it to a major marine outlet, they generally have access to experts who fix this type of equipment
Posted on Feb 05, 2010
Unit will show correct depth for a short time and then reset to 2.2 feet and stay at that reading for long periods of time!
I assume that when it resets to 2.2 feet that the readout is flashing. If so the it sounds like you have a bad transducer as the problem has been getting progressively worse.
The transducer needs to be replaced. Sounds like the sending crystal is fractured.
Aug 06, 2014 | Lowrance X135 Power Pro Sonar Without...
Lowrance X135 blows in-line fuse and won't power up? How to troubleshoot
First, follow the wire from the fuse to the unit. It may be pinched or cut somewhere between those two points. Seems simple, but this happens often. If the wires look ok, You could also try a fuse one size bigger. If it blows that fuse, then the problem is in the unit, and you will have to sent it out for repair.
Apr 10, 2014 | Lowrance Lms 520c 5" Screen Color External...
Lowrance x135- Unit will not switch on?
check to see if you have power to unit if so pull plug the power plug off the back of unit to see if the prongs in socket is ok if all looks good sounds to me you got a bad key bad..repair shop or time for a new one
Oct 19, 2013 | Boating
Lowrance fish no display
its history buddy screens out time for a new one
Apr 18, 2013 | Lowrance Boating
Lowrance x135
solid vertical lines on graph different widths...is this the transducer?
Jan 04, 2012 | Lowrance X135 Power Pro Sonar Without...
Lowrance x135 wont power on?
could be a bad connection to power
Jan 09, 2011 | Lowrance Boating
Lowrance x135 not functioning properly
Had the same issue with another brand. Turned out the transducer cable was picking up noise from other cables (power, trolling mtr. etc). Try moving the transducer cable away from any other cables. I put the cable in a 1/4 " plastic housing up to the point where it was above deck and it stopped all the strange stuff. Not sure about the temp issue??
Mar 29, 2009 | Lowrance X135 Power Pro Sonar Without...
Proper set up for lowrance sonar
Where do you use your boat?
There are so many variables it's hard to fit it all here, but there are some excellent tutorials on the Lowrance website. The most important thing is to pick the right frequency, for the depth of the water. (200khz for less than 70', and 50 khz for greater depths). Depending on how serious you are about fishing, there are a lot of extras that you may never use. The key is to figure out which features will help you the most and forget about the rest.
You may also get some help at this link: FixYa Service Directory
It's common for SONAR to lose contact with the bottom at high speeds. The better the transducer installation, the faster you can go. Turbulence and bubbles will cause the SONAR to drop out. Lowrance's transducer installation guide explains it very clearly.
Jan 03, 2009 | Boating
Boating Logo
237 people viewed this question
Top Lowrance Boating Experts
Phil Walker
Phil Walker
Jerry Greenberg
Jerry Greenberg
Are you a Lowrance Boating Expert? Answer questions, earn points and help others
