Question about Kitchen Ranges
Igniter will not glow for oven, will for broil oven is GE XL44
  • 5,911 Answers
More than likely you have a failed igniter on the bake manifold. Since both manifolds have separate igniters and are BOTH controlled by the Electronic Range Control (ERC) board, its a safe bet that you need to replace the bake igniter since the broiler is working. This is not a diffuclt repair. The following link explains a little theory on how these igniters work and how to replace one:
http://www.fixya.com/support/r3575727-replacing_an_oven_igniter_on_a_gas_range
Follow all safety precautions and make sure the range is UNPLUGGED before servicing. Replacement igniters can be purchased on line at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites offer great service with competitve prices, so shop and compare. The first three sites I listed also include helpful exploded view parts diagrams to assist you in location/identification of parts.
If your replacement igniter connector does not match the existing one on your range, you will be instructed to cut and splice these wires together using the ceramic wire lugs included in the replacement kit. DO NOT attempt to use standard wire lugs as they will melt under extreme heat. The wires and ceramic lugs that are used on these igniters are heat resistant.
If you have any questions, please post back and let me know. I hope this helps you.
Posted on Feb 05, 2010
Testimonial: "Upon first reading, the information seems concise and complete. Now to follow it and see if I can find a part and actually do the repair."
My GE gas XL44 oven will not broil (upper flame burner). It worked as recently as last night. The Broil indicator is lit when selected. The upper broil burners do not flame-on. Thanks, Jeremy
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. This video will walk you thru the correct procedure for testing an oven igniter. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Feb 02, 2011 | Ovens
GE XL44 Gas Stove and Oven. Everything works normal except the oven which stopped working suddenly (no flame). Couldn't find the manual to check troubleshooting guide.
The oven uses a silicone carbide ignitor which requires 3.6 amps or better to open the gas safety valve.
If you don't see any glow from it then it is either blown or the gas valve has gone bad. If it is glowing but not real bright it probably is weak.
How it works: Silicone Carbide Ignition
XL44 gas stove manual
Jan 25, 2011 | GE Ovens
GE HotPoint XL44 Gas Range Model RGB528
My bet is that the broiler ignitor has been out for a while and you just never knew it...
I would change the ignitor as a first try to fix it it is themost common failure..
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Apr 27, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven won't work
Yes. The ignitor must register 2.9 amps or more to operate correctly and ignite the gas. Replace the ignitor.
Aug 02, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven not working
hey, turn the oven on and see if you see an orange glow at the bottom. this would be your glow coil. exactly like the broil. if you do, take an amp probe and check the amp draw to it. it should be over 2.9 amps. if no glow or low amps replace and start baking. enjoy
May 17, 2009 | GE JGRP17 Gas Single Oven
Ge xl44 oven not igniting but burners ignite
The most common failure for a nobake on this type of oven is the bake ignitor. turn unit on and look at the bottom of the oven, you should after about 30-45 seconds see an ORANGE glow, if you do not, chances are you have a failed ignitor.Remove lower part of oven and if you have a meter, place one lead on each terminal and check for continuity( a closed circuit)
If you have an "open" circuit, the ignitor is bad
Feb 26, 2009 | GE JGRP17 Gas Single Oven
Bake mode will not work
Is the bake igniter working ? There are two igniters one for bake and one for broil My guess is that the bake igniter is bad and only the broil igniter is working. part #WB2X9154.
Jan 10, 2009 | GE Profile Spectra JGBP79 Gas Kitchen...
Ge spectra xl44 stove
Most likely the oven ignitor is bad or weak.  You can look at it and see how it compares to the broil ignitor.  If you see a whitish color on the ignitor and if it doesn't fully glow then it needs to be replaced.
Oct 22, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
202 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
