Question about HP LaserJet 1020 Printer
Motherboard with usb2.0 it has error usb print support cannot start. but for usb1.1 it work normal. any suggestion?
  • 617 Answers
Install correct drivers for mainboard
Posted on Feb 05, 2010
I am getting error 51 on the lower right of the screen right after post and machine will not boot
Hello.
I did some research and I found this article:
When a USB device (such as a USB memory card reader or USB camera) is connected, you may see the following issues:
  • System boots more slowly than usual
  • POST code error 51 appears at the bottom right corner of the screen
If the USB device is not connected, the system boots at a normal speed without any errors.
To resolve this problem, download and install the latest chipset driver and the latest BIOS. Chipset and BIOS files are available on Download Center.
http://www.intel.com/support/motherboards/desktop/sb/CS-031767.htm
this seems to adress your issue. I would start there and if you have more issues let me know
Hope this helps!
Please vote if so :)
Jan 26, 2011 | Intel Motherboard
Dear Fixya, my GA 6bx7 (Intel bx440) , GA GF400mx,JNC 235 W Power,Cel 900Mhz start clicking just seconds after (or during) Post (no Hdd ). In Bios signal sound more loudly. There is second or more...
your hard drive is dying or dead,mouse and keyboard ps2 will normally work with operating sys,try with another h/drive should work clicking are heads crashing good luck!
Jan 08, 2011 | Intel Motherboard
ASUS Rampage GENE II
first download the ASUS EZ Flash software into a USB stick, after which you download the BIOS file there as well. Make sure to format the USB stick to be bootable first. Then boot the machine from USB first.
May 20, 2010 | ASUS P5PE-VM Motherboard
Brother Mfc9840cdw (except for fax send) has been very good. During print job (2nd computer sent job during print from 1st computer), red light suddenly came on. everything stopped. No sign of a jam. No...
the machine is nearing service time.. Normally this is maintenance and resetting the print clock..
  • press both 3 and 9 buttons at the same time and hold
  • select each item 1 at a time and press ok
  • press 1 to reset it..
  • do this for each item in the list
  • repeat for each item.
Apr 05, 2010 | Brother MFC-9840CDW Laser Printer
USB hubs Error
Hi
Check your usb port settings in the bios and make sure that is everything is set to normal.
If it is a PCI USB Hub, replug it from your motherboard.
Hope it helps..Thanks for using Fixya.
Apr 01, 2010 | ASUS M2N-MX Motherboard
I own an ACer Aspire 4710 which has 2 sets of 2 USB's each on left and right side. Suddenly one day, one pair of it's USB stopped working and it started heating up from left side. Now, before booting, it...
Both are on motherboard. If you can open up the laptop cover, then check and make sure the connection diagram of that USB is perfect, clean it, make sure again.
Just remember to take your time and don't get nervous working on the computer. If hard to do, contact laptop repairing engineer.
Please report back to the thread the results of your work.
Regards;
Hassan
Jul 07, 2009 | Acer Computers & Internet
HP D1420
Create a new administrator user account and reinstall the drivers then print. OR check whether u have set it as the dafault printer.
Mar 06, 2008 | Office Equipment & Supplies
Epson DX8450 Set up
Dear sir,
Love to solve Epson printer products;) There's nothing wrong, what you are doing is correct you even tried to troubleshoot. You can even do the self test provided how to in your manual upon purchase. Well to start streaming down the problem; check the BIOS setup of your motherboard if USB ports have been enabled. Change and save the changes. Second. At windows environment check the "Port" properties at control panel system setting device manager if there are some errors or warnings. Install USB port installation update driver if necessary provided in your motherboard installation cd or you can removed or delete the errors and restart the computer, be sure you inserted the motherboard installation disk on CD ROM. The USB port devices shall be detected browse the CD and locate the USB driver. Hope this helps.
Best regards,
Rosener Guyano
Feb 02, 2008 | Office Equipment & Supplies
How to get a HP LaserJet 1018 to actually print something?
Yes it is a print driver problem, Unplug usb, delete all previous attemps at install, delete print software and drivers, Download and install correct driver from HP, plug in usb only when directed to do so.
Dec 18, 2007 | HP LaserJet 1018 Printer
A higher usb connection
What this means is that the USB Data Transfer Speed, "Speed" of your USB is NOT fast enough for the printer to use. I suspect you have USB version 1, Most modern things like this printer use USB version 2. Which has a much higher data rate. You can get an add on card to add USB 2 to ya PC or laptop. After ya done that you will find ya printer will most likely work.
Aug 14, 2007 | Samsung CLP 300 Laser Printer
HP LaserJet 1020 Printer Logo
Seeker5211
Seeker5211
