Question about Whirlpool GS6NBEXR Side by Side Refrigerator
Whirlpool side by side refridgerator doors rusting
I have white vinal(?) covered doors that are rusting.
  • Anonymous Jan 02, 2009
    We have the same problem with our Whirlpool Side by Side as well. Modell number listed below.
    ED25PQXDW04 manufactured in 1997
  • Steve Mar 24, 2012
    This looks like a very commone problemhttp://whirlpoolrots.blogspot.com/2012/0...
    President:
  • Whirlpool Master
  • 2,651 Answers
Sounds like an older refrig, we call that "refrigerator cancer", its rusting from the inside out. your inner insultion has become saturated w/ moisture and is just rusting away now, you can try covering witha rustolem might buy you some time only other way is to replace entire door and thats a few hundred dollars
Posted on Feb 24, 2008
The front door of my side by sde refrigerator is rusting
Go to www.applianceart.com -- These guys specialize in refacing your appliances. Their motto is Don't replace your existing working appliances -- Reface them. They offer magnetic and vinyl options that will fit over the existing surface. I believe the vinyl option will work best for you.
They have solid colors, designs, textures and even stainless steel options.
Worth checking out.
Nov 11, 2011 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
HAVE A ED5FHEXT REFRIGERATOR MAKES A POPPING NOISE ON BOTTOM OF DOOR EVERY TIME YOU OPEN.
there is a magnetic vinyl covered seal glued all around the door frame to seal the refridgerator from escaping cold. If this seal has come loose, it will adhear to the door frame a little after opening and then be pulled back and make a slapping sound. Check this seal to be sure it is not torn loose.
Dec 28, 2010 | Whirlpool ED5HHEXT Side by Side...
Whirlpool Gold Conquest refrigerator side light bulb flickers/buzzes and display lights don't light. The bulb is good. If I pull the bulb the display lights and frig works properly.
This may not be the problem now but by the sound of the malfunctioning electronics, it could be in the future. The start device on some models of refridgerator for maytag and whirlpool have been recalled. If your appliance was manufactured in the last 5-10 years you may be having an issue with this component. Mine recently caught on fire at this device that is located near the compressor. If you would like to be a part of the petition for a recall on this appliance contact me at jboooor@hotmail.com
Jun 06, 2010 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
WHIRLPOOL SIDE BY SIDE fridge GD25DFXFW 10 YRS
Get your refrigerator repainted before it is too late. It isn't that costly. Cracks may be due to rusting. Ask those mechanics about it when you give it for painting.
Apr 21, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool refridgerator is leaking water on the freezer side (side by side refridgerator) onto the floor. The ice machine was overflowing with ice and has frozen ice in the ice maker that won't budge. We...
WAS IT LEAKING FROM INSIDE THE FREEZER OR FROM BOTTOM OF FRIDGE? ONCE IN A WHILE YOU NEED TO TAKE OUT THE ICE BIN AND DUMP ICE OUT AND CLEAN IT. HOW CAN THE ICE MACHINE OVERFLOW WITH ICE WHEN THE ICE IN THE TRAY WON'T BUDGE? NEED CLARIFICATION. SOUNDS LIKE YOU EITHER HAVE A BAD ICE MAKER MODULE OR THE SOLENOID FOR THE ICE ON THE WATER VALVE IS BAD.
Jan 24, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool ED5FVGXSS00 freezer door ice dispenser flap will not close ..causing frost buildup. What parts do i need?
On the back of the door directly behind the flapper door , you will see an access cover ... take it off and adjust the tension
Oct 02, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Repainting doors on whirlpool white refrigerator
oowwwww!!! thats what we call in the refrig biz "refrig cancer" the door itself is actually rusting from the inside out. the older refrigs used fiberglass insulation inside the doors which has a tendency to hold moisture, and overthe years rusts through. the new door use blown-in poly styrene foam far less likey to hold moisture. That being said you could remove the door lightly sand and paint, can of krylon enamal aint should do it, at least for a little while anyway
Nov 30, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refridgerator door handle
The entire handle slides upward and out to detach from the door. There are two screws attached to the handle which can be tightened once the handle is off. Those screw heads are what reattach the handle to the door by sliding them through the door bracket opening, where they follow a short channel down leaving the handle secured again.
Dec 30, 2007 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool side-by-side refrigerator ice dispenser
First pull out the ice bucket and close the door.  Set for cubed ice.  Press the button for ice to come out and listen for a loud clunk noise.  That is the sound of the solenoid.  You can open the door, hold the light switch and press the button and watch for the solenoid moving up and down.  Solenoid is at the back of the freezer in a little square opening where the rod on the ice bucket goes into.  If that solenoid is moving ok then put the bucket back in while the solenoid is in the down position and cubes should work.  If solenoid is not working then it will need to be replaced.  Let me know what you find.
Oct 13, 2007 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
1,282 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
