Question about Linksys Wireless-G Broadband Router
New dell, wireless linksys, windows xp, can remember my wireless router id or pwd
  • sibersue Feb 08, 2010
    thank you. resetting worked at first - then had to have some admin settign disabled by work - so will try again.
    next...security...
  • 136 Answers
If you want to know the username and password for the wireless you have to go to the wirless settings on it
Click here for step by step instructions
Posted on Feb 08, 2010
  • Mani Maran
    Mani Maran Feb 08, 2010
    If you find it difficult with that link
    Try this
    Open a browser
    Go to 192.168.1.1
    Enter the username and password if you have set
    Else use username:(blank) password:(admin)
    Go to Wirless and Wireless security and check if you have the wireless password in it
    Else try to reconfigure the wireless network on your laptop
    If still no go RESET your Router
    Note: Have all details provided by your ISP before resetting it
  • Mani Maran
    Mani Maran Feb 09, 2010
    Thank you for that comment.
    If you have issue with security then explain what the issue is to post solution accordingly
  • 617 Answers
Cant remember , press the reset on router, will reset to defaults
Posted on Feb 05, 2010
I format my computer i need to install the linksys router
Click the link below for proper cable connections in setting up your wireless network.
http://www.microsoft.com/windowsxp/using/networking/setup/wireless.mspx
Then, configure your wireless connection. The following links provides the step by step instructions for each version of Windows:
Windows XP. http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/wlan_client_configure.mspx?mfr=true
Windows Vista. http://windows.microsoft.com/en-US/windows-vista/Setting-up-a-wireless-network
Windows 7. http://windows.microsoft.com/en-US/windows7/Setting-up-a-wireless-network
I hope this works for you. Kindly reply/comment for further assistance. Good Luck!
Thanks for using Fixya!
Mongkey
DELL Tech ID #456563
TIPS: Is your computer slow? This might help
http://www.fixya.com/support/r8158906-diy_manual_pc_tune_up
(for Windows only)
May 08, 2011 | Linksys Wireless-G WRT54GS Router...
Since upgrading WRT150n router firmware, to be
Have you had a look on the firewall website for a suitable firewall system that compliments windows 7?
I had to download a new one myself when I went from Windows XP to Windows Vista.
Sometimes changing systems means you should also change your firewall, then you'll have the most up-to-date software going. Plus it won't slow your computer down like it doesn't sometimes.
Hope I helped Dr Reed
Apr 15, 2010 | Linksys Wireless-N WRT150N Router
I am changing to a new PC, from one that is already connected to a ASDL+ modem and a Linksys router. Do I need to install new drivers(for ASDL+ modem or Linksys router) in the new PC? Or can I just plug...
For you to use the modem direct - you may need drivers - BUT connecting to a router does not require any drivers - and you should just be able to plug in and go If wireless - then you may need to provide the wireless security key if the wireless is secure - and if the wireless is on the same SSID name as before that may cayse a problem - but you can renove the xp wireless profiles to overcome that Wireless Profiles
  • http://mgmcc.forumotion.net/networking-tutorials-f17/removing-an-existing-wireless-profile-t109.htm
  • http://www.tp-link.com/support/showfaq.asp?id=186
- delete the preferred networks start>control panel>network connections> right click on the wireless connection listed wireless networks tab in the preferred network list click on each one and - remove button you will then have to enter the wireless security key for any networks you connect to
If on a LAN connection - you may need to turn off the modem/router and PC - then turn on the modem - allow to settle and all the light to show normal status - turn on router and do the same then turn on the PC
Apr 13, 2010 | Linksys Wireless-G Broadband Router
Another application is controlling the wireless adapter
I believe you are using WINDOWS XP.
In case of windows XP, there might be 2 different wireless utilities can control your wireless adapter.
First utility is the manufacturer's utility. If you have Dell wireless adapter then you can use Dell utility to connect to the network.
Another utility is Window's utility. You are getting the error message in this utility because your computer is using another utility.
To use window's utility you will need to start the " wireless zero configuration ".
Click Here
for more information about wireless connection
Feb 22, 2010 | Linksys WRT54GX2 Wireless-G Broadband...
Is the wireless120 Router compatible with dell
Yes it is very much compatible with your XPS M140 that transmits 802.11 b & g wireless connection. In which the Linksys WRT120N Router can accept a/b/g and N wireless connections.
I highly recommend this router if you want to use one.
Jan 04, 2010 | Linksys WRT120N Router
My Dell lattitude D830 won't connect with linksys
Right-click the wireless icon with red X and click on View Available wireless networks. Highlight the name of your wireless network and click Connect. If it asks you for the network key, type in the secuirty key of the router and press connect. That should do it. If you don't know the wireless security key of the router, you can see it by accessing the router's Setup Page through http://192.168.1.1 on your browser. It's under wireless tab then wireless security sub tab
Sep 23, 2009 | Linksys WRT300N Wireless Router
Hardware.ID is missing warning
The Linksys might not be compatible with XP sp3. If it was working before, there is nothing wrong with your Linksys
Sep 10, 2009 | Linksys Wireless-G WRTP54G Router
I just reformatted my dell 8400 and lost my Linksys g router conn
After reformatting your dell 8400, did you reinstall all drivers of your devices? The linksys router won't be affected by the reformat. Your computer should still get connection from your router. This is a dell issue. If you have another computer connected and working with the router, that means the router is still functioning. Call Dell or linksys technical support. If they cannot help try this http://technicalsupport.blog.friendster.com
Feb 22, 2009 | Linksys Wireless-G WRT54G Router
Password for the Linksys Wireless Router
Power down the linksys and on the back is a reset button push it. The ones i have installed dont need a pass word or key,if it is asking you try the info you used from your internet provider ( e-mail address or access #s)Also try skipping this step and see if it will let you go on to the next part,Lynksys advisor has major issuses with it I dumped it from all the pcs I installed.
Jan 26, 2009 | Linksys Wireless-G Broadband Router
I recently purchased a new desktop which I had linksys connected to my old pc so that my laptop would work wirelessly. Both are Dell computers. I have a Linksys WRT54G router. I have Vista and the...
I don't see why not..
are you trying to hook up both computers to your linksys router?
if you have 3 computers now... I'm assuming your old pc was connected directly to the router, your laptop was connected wirelessly and now you have a brand new computer that you also want to connect to the internet using your lynksis router.. you should have not problems doing it, wirelessly or using a wire...as long as your router has ports avaliable...
Sep 21, 2008 | Computers & Internet
Linksys Wireless-G Broadband Router Logo
66 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
