PAPER JAM The copier makes half a trip on the bath, barely pulls a little paper, then shuts off and the paper jam sign comes on. I have looked through front and back of path, and can't find any paper. Please help.
  • 1 more comment
  • kescott Mar 06, 2008
    Machine will bootup at 35% of the "warming-up" phase paper jams at the top exit cover. I have take 50% solution of Isopropyl Alcohol and cleaned the rollers, but same problem.
  • corporatepro Jan 10, 2009
    my image Runner irc3200n when switched on it keeps on saying paper jam in the fixing unit i have removed the paper but what i have noticed is that there is some cutting mark on the surface of the upper roller as if a small screw was stuck between the roller can this be the problem why is always showing paper jam in the fixing unit when there is no paper there?
  • brian c
    brian c May 11, 2010
    Can you be more specific with the make / model of the machine?
    Problem Solver:
  • 9 Answers
Make sure all trays/doors are shut properly, also make sure the rollers are contacting with the paper
Posted on Feb 21, 2008
Repeated paper jam for Brother MFC-J475DW
The sensors that report paper jams often get little pieces of paper stuck inside tripping the sensor when jammed sheet gets pulled out. Powering off and restarting will not help this. You'll need to do a little bit of disassembly looking for loose bits of ripped paper. Maybe use canned compressed air to blow it out first.
Feb 07, 2015 | Brother MFC Office Equipment & Supplies
Tip
Paper Jams
The most common error message is the notorious paper jam message. You do a quick look and then determine there is no jam. What next? Well here is a tip that will save you possible a service call. If you find a sheet of paper that has jammed, look at it closely. It is all together as one piece or is there the tinest of pieces missing? It only takes a tiny piece to cause a jam error. Pull the print cartridge out and with a flashlight look inside the printer and especially at each roller and see if there is any hint of a piece of paper. Look closely because you can miss something. Next open the paper tray and make sure the paper guide is firm against the paper. This will cause a jam. Just drove an hour and a half this week for this issue. The paper guide was not up against the paper causing the jam. If you have a small vacuum I suggest you vacuum out the printer because there are times that the sensors can get covered with paper dust causing them to fail. Hope this helps!
on Oct 26, 2011 | HP Office Equipment & Supplies
Paper jam message but no jam seen. Have unplugged from computer and wall. Shut off x 20 minutes. Alarm light shuts off momentarily and then reappears with first printed page.
Paper can be jammed internally.
1) Turn off the printer and disconnect the power cord and USB cable.
2) Open the rear cover. Look for a jam or even little scraps of paper from a previous jam that may be obstructing the paper path.
3) On the front, remove the tray and look into this area. Make sure it is free of any obstructions.
4) Replace tray.
5) Reconnect the USB cable. Power ON.
I hope this helps!
Dec 24, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Hp2200D Won't print - "jam" light comes on - but no jam
Have you cleaned the feed roller? If it's dirty it'll spin but won't pick up any paper. Look at the paper after a "jam." Can you see any black roller marks on it? That's a sure sign of a dirty roller. If you suspect a dirty roller, clean it with a little alcohol on a cloth.
Mar 10, 2009 | HP LaserJet 2200D Printer
Paper jam display
open machine look for an upright lever at the paper in side.... it is called a paper detection switch its function is to detect the position of the paper movement through the machine, if the paper does not trip the switch at the right time the machine will indicate a paper jam and shut down, most machines have this sort of detection system
Dec 21, 2008 | Toshiba Office Equipment & Supplies
Canon PC720 copier
Looking at the copier where the paper comes out of, there is a switch to open and close it. Pull up and look on the left side in the back. There is a little spring that comes off, or breaks, or the plastic that holds it on breaks. THIS CAN PAPER JAM THE MACHINE AND SEEM LIKE A MAJOR PROBLEM. ALL IT IS IS A LITTLE SPRING. Hope that is only your problem.
Dec 31, 2007 | Koutech Systems PC720 (IO-PC720) (IOPC720)...
Minolta keeps jamming
Hi Daryl, what does the paper look like? Is there a "nick" in the leading edge of the paper or any signs of damage to the paper? Remove it carefully an look, but be careful cause the toner isn't fused yet, so it will get on your hands and clothes.
Nov 15, 2007 | Konica Minolta DiALTA Di200 Copier
NP 6030 paper jam
It may be this simple:
1- as silly as it may seem, are you sure the size  is correct, if it is a letter size paper and it says legal, it will jam. open the paper tray and make sure the guides are snug againgst the paper,
does it say letter (or legal) for the tray you are going to use, if they do not correspond then look behind the tray inside the machine, is there a paper jammed in the back?
Or not so easy
2-You are having a sensor problem, take a look at the duplex tray,
pull it out and look at the sensors ( black little levers that stick out) are there any pieces of paper, can you move them and they spring back into place?
Oct 22, 2007 | Canon imageCLASS D761 Copier
94 people viewed this question
k24674
jasbo
jasbo
