I have an I/O Magic 200GB External Hard Drive. I admit I dropped it on the carpet a few times. It powers up w/ a steady blue light, but none of my computers recongnize it. I've gone into Disk Management to see if it was listed there, in which case I would have tried renaming it; it wasn't there. My software recovery program did not pick it up either. Others suggest it's a hardware issue, and that I should take it to the experts and prepare to spend a TON of money. OR remove the drive from it's casing and install it into my desktop to see if it'll be recognized in that fashion. Are there any other suggestions, as the above two are rather extreme.
  • 7 Answers
SOURCE: Vista stops recognizing external hard drive
This doesn't sound like an OS issue. This appears to be more an issue of the connection to the hard drive. The USB cable likely isn't the culprit, nor the laptop USB inputs. If the drive was ever dropped or the cable gets removed and reattached often to the actual enclosure, you might be looking at a bad port on the enclosure. This isnt a lost cause. You can always buy a hard drive enclosure from newegg and move the drive from the IOMEGA to the new enclosure. You can get a new enclosure for $15. Just because the USB port is bad, it doesnt mean the data is gone and the hard drive cant be used.
Posted on Aug 26, 2009
  • 696 Answers
SOURCE: I have a Lacie 250 GB hard drive. My computer can't find/access.
Thanks for all the info, it really helps us help you when we have the full picture.
The Seagate drive you are seeing is the hard drive inside the Lacie Enclosure. The fact it is showing up in disk management is a good sign for getting your files back. The fact that it shows as empty with no format type listed means that either the partition was deleted or damaged. This would be akin to loosing the microfishe in your local library. All the data is likely still on the drive but windows has no way of knowing what is there or where it is.
In either case the data can generally be recovered by a pro with speciallized software. In some cases you can do this yourself with similiar, less expensive software but I always warn Askers that this software requires significant knowledge to operate and you cannot recover the files back to the same drive therefor you must have another drive with at least double the space free of the data on the drive to do it yourself.
Let me know which approach would suit you better, if you choose the do it yourself method I can suggest software for <$100 that you can try but it carries inherent risk of damaging the data if you make any mistakes. f you choose to have a pro do this for you reply with your Country, State and City and I will recommend someone for you. For this type of failure recovery varries but usually runs $150-$500 depending on the volume of data you have.
In either case DO NOT format the drive or attempt to use it for anything in the mean time as every operation that writes to the drive runs the risk of overwriting your data and rendering it unretrievable.
Hope this Helps FixYa,
Posted on Sep 13, 2009
  • 4 Answers
SOURCE: How to open case: Seagate ST3160203U2RK External Hard Drive ??
This is one of the mean tricks that the industry uses to discourage people from opening things and then totally ruining them.
What about getting yourself a 5-star-shaped screwdriver? Ask your hardware store guy.
Too expensive? Well - I have a lot of different simple slotted screwdrivers. Normally I find one that fits into 2 corners of these "miracle screws". If you don't have fitting one use a cheap one that is slightly too large to fit and grind it down just to size.
The same trick works with the other kind of "discouragement screws" that have ALMOST a normal slot --- but there's an elevation in the middle of it. A slot screwdriver with a ground-in **** in the middle (Dremel tools work fine) does the trick.
Posted on Sep 24, 2009
  • 81 Answers
SOURCE: WD My Book not showing up in
It sound like to me that you have an operating system on that
drive and it will not work on your system , the only way you
can have two OS on your computer is to have both of them
installed and on when installing the OS and they both have
to be formatted the same like NTFS or FAT32 even though
Windows says it will work fine with both its just not true XP
and Vista doesn't work well with both , try taking it out of
its closer and powering it up with your computer go into
Bios and set it up as a slave or as a master that should
allow you to open it to retrieve your data so it can be
reformatted wiped clean and ready to use as a static
HDD storage , external HDD are intended for storage
back ups and should never have an OS installed on them
doing so will only allow your data to become corrupt
and contract viruses and even lock up forever corrupting
the HDD image that is set on it by the RAM . once the
image is corrupt the HDD will never turn on again without
wiping it clean and reformatting .
Posted on Jan 20, 2010
  • 95 Answers
SOURCE: My computer is not recognizing my LaCie external hardrive
First cehck whether your computer is able to recoznize other USB storage devices or not. If you see that it is not recoznizing other USB storage devices. Then you need go to your Boot Up screen, the screen that opens when you restart your PC.
Then go to the USB section and enable USB drive.
If this also does not resolve your problem, then try installing USB drivers on your PC, You can install them from the website :
I hope this resolves your problem.
Posted on Apr 20, 2010
Computer is not recognizing my external hard drive
If the light won't blink, there could be problem with the power source. Do scanning hardisk for errors manually ( take off the hardisk from the case, assemble it on other PC Desktop)
May 06, 2010 | IO Magic Corporation GigaBank (I250HD35)...
Not recognizing external harddrive in "my computer". I/O magic blue light continually flashes blue instead of staying solid light
There are a few possibilities, the fact the light is blinking generally means the power adapter is fine.
The options left are a faulty driver in your PC, a failed circuit board in the enclosure or a failed circuit in the drive itself.
First try the drive on a different PC and see if it works. If it does reply back and we can look into the failed driver. If it doesn't then take it to your local PC shop and have the technicians move the hard drive into a new enclosure.
If it works in the new enclosure buy the enclosure and your on the way. If it doesn't, then the hard drive itself is the problem. If that is the case you will need the help of a data recovery pro to retrieve your data. If this is the case reply with your location(Country, State and City) and I will assist you in finding a reputable pro to assist you.
Hope this helps FixYa,
Oct 26, 2009 | IO Magic Corporation GigaBank (I250HD35)...
Maxtor external HDD not detected by Vista
try to format might need a quick format for you to use it. if still doesnt work check for the sata,pata cable that connects your motherboard.
Apr 30, 2009 | Maxtor Hard Drive
Drive manager is grey and says that no drive is attatched.
You need to get a Seagate Harddisk Utility software to check the disk intergrity.
Although hardware issues like can sometimes be very difficult to fix due to the impact on a volatile component on the harddisk which are most times not replaceable
Apr 06, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Slightly dropped seagate external hard drive, recover data??
please use stellar phoneix software
that will do your job surely
Mar 16, 2008 | Seagate 160GB 3.5" External USB Drive 160...
Will the drive be shown under "Disk Management"? If no, make it. Then the MOST effective way is to try some so-called data recovery software to rescue the data.
First of ALL - Connect your hard drive to your personal computer. And install this software Wondershare Data Recovery on the computer in order to perform data recovery. Get the program from its site.
data recovery (for Windows OS)
Mac data recovery (for Mac OS X)
Good luck. I hope that my reply has shed some light on the problem!
Remember - Always make Backups of your precious data!
Mar 16, 2008 | Computers & Internet
Blinking Lights
I had this EXACT same problem. Blinking blue light and the hard drive never powers on. VERY frustrating...I have a home studio was in danger of losing over a year's worth of original music. However, this problem has a solution which I read about on this site:
"The problem was with the power source not the actual drive so I ended up pulling the drive out of the case and purchasing a new case from It now works fine and only cost about $30 to fix."
This is EXCELLENT advice and FixYa is the only place I read about this solution. Though I'm no newbie with computers, I certainly had never swapped out an external hard drive. But, in 30 minutes for about $30, this problem is TOTALLY SOLVABLE. I went to and ordered this product:
an external Azio hard drive enclosure. Because I always used Firewire hard drives, I got an enclosure that accepted Firewire---however, many others are available with just USB 2.0. Following the directions that came with the enclosure, I removed my blue-light blinking, non-functional hard drive from its enclosure and placed it into the Azio. Now, the unit is working fine. No datawas lost and the Azio drive seems to be working properly.
THIS IS A FANTOM HARDWARE PROBLEM---NOT SOFTWARE PROBLEM! I encourage the MANY people who have complained about Fantom drives and gotten no assistance to try this solution and avoid Fantom in the future.
To whoever posted this solution: thanks a million. You made my day.
Dec 24, 2007 | Fantom Drives 120 GB Hard Drive
Lightly Dropped Seagate 100GB External Hard Drive
Unfortunately, this probably means the read/write heads were jarred and can no longer function properly. That's usually fixable, but it's a very expensive fix because the parts are inside the hard drive and the data surfaces are very delicate... Most people are better off simply replacing the hard drive unless the data is absolutely vital.
Dec 06, 2007 | Seagate USB 2.0 External Enclosure + 400GB...
Computers & Internet Logo
53 people viewed this question
David Payne
David Payne
