Question about GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker Microwave - Turntable doesn't turn (I replaced the motor already) - No working noise, no noise at all. - Keypad works, when I press "Express Cook" light comes on in oven but no turning turntable and no microwave oven sound. HELP!
  • NozFineArt Feb 05, 2010
    How do I replace the bottom door switch? Do you know the part number?
  • 72 Answers
You have a bad door switch, probably the bottom one
Posted on Feb 05, 2010
Testimonial: "Quick and to the point."
    Problem Solver:
I purchased a kenmore microwave/hood combo microwave (model # 66560622000) at an estate sale. i am using it on my countertop. it works well except the turntable does not turn. i connected the bottom light fixture to the motor to check the power supply but the light did not come on and the turntable still did not turn. there is a one inch clearance between the motor and the countertop. how can i get the turntable working?
Posted on Jul 25, 2011
Why wont my GE Spacemaker JVM1650 turntable wont work?
replace the turntable synchronous motor
look to ebay search for
ge jvm1650
then add turntable motor or browse down youll find a new motor
the coils inside may be duff
Aug 12, 2014 | GE Profile Spacemaker Over-the-Range...
GE Profile Spacemaker XL1800 microwave turntable
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
On some, you have to cut the motor cover off with snips, then use a screw when reassembling it.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Oct 28, 2013 | GE WB26X10037 Microwave Stirrer Motor
Microwave turns on but no heat and turntable doesn't turn
It is one of two things, a defective door switch, "most likely" or the keypad control board is faulty.
Apr 22, 2012 | GE Spacemaker JVM1540 Microwave Oven
We have a JVM 1443bk02 ge microwave. Today the turntable stopped working. You can depress the key pad on/off button but that makes no difference for the turntable. How do you test to make sure it is the...
The problem with the turntable could be the following:
  1. Gummed up lubrication or bad bearings. Check to see if there is any food on the turntable spindle.
  2. If that is ok, check to see if the belt is loose or broken.
  3. If that is ok, check the motor. A meter will confirm whether there is power going to the motor, when you depress the keypad on button. Use the AC Volts setting, if you have about 21 VAC and the motor does not work, then the motor is bad.
Jan 03, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE SpacemakerXL Microwave oven clicking noise
Spacemaker t/t motors are very easy to change. Removed the screws from bottom of microwave. the bottom panel will found towards wall. Mtr is in very center of unit. Should have 2 wires going to it
Nov 21, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker Microwave Oven Model JVM1440BD: turntable doesn't work. When we press start, turntable make semi-loud noise while oven is cooking, but it does not turn. We can stop noise by pressing...
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Nov 28, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE PROFILE SPACEMAKER MODEL JVM1350BW
There is a turntable motor that maybe bad you can access it by removing the scres on the boyyom of the uniot it will flip down on a hinge NOTE: you do not have to take down the microwave to do this. the motor should be getting 110v when on also make sure on your keypad it says Turntable on Some models have an option to turn it off on the keypad
Jan 23, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1631BB005 making noise
Many thanks to e3enigma above! I removed the synch motor under the turntable; all other microwave functions work fine and the grinding noise is gone, hooray! A trip to the appliance parts store tomorrow for a replacement synchronous motor and all should be well. Thanks again!
Jan 06, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Turntable does not work
Need to check if you have power to the turntable motor. Either is has a bad motor or a bad relay on the control board.
Nov 12, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
515 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
