Question about E-Machines (T2958) PC Desktop
Emachine wont start up
I used my computer one night. and it worked fine i went to get on it the next day it woundnt come on the light on the montier and the modem came on, but it would not do anything elese it does not even come to the screen to reboot. could we have removed something we needed to start up. my daughter had used disk clean up that night she said.
  • 4 more comments
  • baaa Feb 20, 2008
    the power button flasses on the montier and the light stays on the modem
  • hemor123 Jul 14, 2008
    i just got a My Emachine T2958 from a friend and it wont turn on at all onthe mother board the green light comes on but nothiing else will. how do yoou replace the start button with out buying a whole new case.
  • merusmer Sep 05, 2008
    e mach went dead no power changed power unit still no power but now green lite on mother board comes on nothing else
  • rubano11 Oct 11, 2008
    I have the same problem, i took it to a computer tech and he said that e-machines is famous for bad motherboards.... so it appears that im not the only one, as mine did the same thing as yours... i shut mine down the last time it was working because the fans were running inside when the computer was on standby, and i couldnt bring it back up so i had to disconnect the power from the back,,, and it never turned on again,,,,
    did anyone find anything different for a solution? im now trying to figure out if its worth replacing the mother board or buying a new pc.....
  • Anonymous Nov 26, 2008
    how do i clean my computer!
  • dkihara Jan 15, 2009
    i have the same problem the mother board light is on but the screen is not showing a thing even though the power is ok
    Genius:
  • 3,587 Answers
Nope..that's not an issue...is the power button showing a solid color, if applicable?
Posted on Feb 20, 2008
I just added a LCD monitor to my eMachines ET1331G desktop computer. Everything worked fine until I left it on for a day. The computer went into sleep mode and now I can't get it to wake up. I've trie
You should be able to just press the main system unit power button to wake up your 'sleeping' computer which will then resume your Windows desktop and bring you back to the Login panel if you have a password set for your account.
Dec 29, 2011 | eMachines D Computers & Internet
My night time head lights wont come on. Ive changed multipurpose switch and lights still wont come on. Day time lights run in the day just fine, Earlier when my my lights started going out at night. I...
first thing to do is check all your grounds batt. to engine batt. to body batt. to frame then have someone scan the bcm body controll module that operates the headlights ,int.lights, doorlocks, ect.
Mar 24, 2010 | 1998 GMC Sonoma
O2 lincoln ls check engine light & fuel gauge went to empty the next day it wouldny start replaced fuel pump & fuel gauge ran fine drove about 40 miles the next day started it up check engine light...
You have two pumps,I guess you know that ,if you already did one. Did you check fuel pressure at the rail and check out the electronic pressure regulator? What codes are coming up and do they stay set?
Feb 05, 2010 | 2002 Lincoln LS
My Acer Aspire 5735z battery won't charge!
Your adapter port might have been improperly adjusted. Jiggle the cord around in there while it's plugged in to see if the plugged in light comes on. If it does then that's your problem. You can prob things under it to keep it at that point for a quick fix but I'd recommend a local computer shop for repairs.
-CompDoctor
Feb 01, 2010 | Acer Aspire 5735 Notebook
WILL NOT START
sounds like water ingress to either a control module or the coil pack, check all control box locations eg footwells for water and then check the engine bay for loose or naked wires, dry and clean and possibly cover with a plastic bag etc and it should be fine.
Jun 14, 2009 | 2000 GMC Safari
My 2003 dodge wont start.
sounds like a crank positioning sensor
Feb 23, 2009 | 2003 Dodge Ram Maxi
1994 cavalier wont start
Crank positioning sensor I had the same problem back bottom of motor if its the 3.1.
Dec 02, 2008 | 1994 Chevrolet Cavalier
Ps2 wont turn on
it might be the disk...when the ps2 cant read the disk sometimes it justs turns off...mine does the same thing....when i put in a another disk it works fine
May 17, 2008 | Sony PlayStation 2 Slimline Console
Emachine desktop
I understand that your cpu is not turning on and the repairer confirmed that it is the issue with the mother board. I suggest you to please check the smps fan spinning or not. If its spinning then then the issue could be with the mother board. If not try changing the power cables.
Next check whether your cd rom light is glowing. Even if there is an issue with the mother board, as the power is supplied by the smps the light  should glow if the light is not glowing its clear that something must be wrong with smps.
Please provide us the result of the above steps so that I could assist you further.
Nov 08, 2007 | E-Machines eMachines Desktop PC
E-Machines (T2958) PC Desktop Logo
160 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
