Question about Wittnauer 11L00
How do you size the bracelet - Wittnauer 11L00
  • 2,334 Answers
Check out my tips here and find out how to do it.
Posted on Feb 05, 2010
Tip
How to manage your SUBMARINER's size to fit your wrist
Take of your ROLEX, look on the inside of the bracelet. Near the area where you have the crown, there is a miniature circle, push with your thumb on it with strenght, you will hear a click . You pull your bracelet , it will open, then you look on the sides of the bracelet, and you insert a needle into the little screws on both sides, and then you choose the size you wish for your watch , and then put the circle back and close everything again.
on Oct 10, 2010 | Rolex Oyster Perpetual Submariner Date...
Where is the spring loaded pin
In the bracelet where the bracelet enters the sides of the watch. Also in the catch if it has size adjustment.
Dec 23, 2015 | Watches
Spare bracelet links required for Ellesse watch model 03-0041-201
Hi
Does anyone know where i can get links for Ellesse watches. I have a range of different watches all too small.
Grateful for any help.
Jun 15, 2012 | Watches
Adjust bracelet on sea spider?
Thank you for contacting FIxYa.<br /> I suggest you take your watch to a reputable local jeweler for sizing. Expect to pay a nominal fee (around $5) for this service. Do not attempt to size your own watch! You may damage or scratch the watch and bracelet. The liability is yours.<br /> If you still decide to do, follow instructions given here:<br /> <a href="http://www.webwatches.co.uk/how_to.htm" target="_blank">http://www.webwatches.co.uk/how_to.htm</a><br /> Best wishes. Jewel
Aug 26, 2010 | Invicta Watches
How do i get extra links for a concord veneto
Go to watchbands.com, enter your model number and bracelet size and problem solved!
Feb 10, 2010 | Movado Concord Saratoga Chronograph Watch...
What size screwdriver is required to remove the screws on the braclet of a ladies accutron courchevel 26R28?
All screw heads in watch bracelets are usually 0.8mm - 1.30mm in diameter. In my experience screwdriver with the blade width of 1.00mm was good for unscrewing the bracelet screws in majority of cases. So, I would advise to buy a screwdriver with 1.00mm wide blade.
In case if you realize that the bracelet screws are a tiny bit smaller than your brand new screwdrivers blade - do not panic but use the sandpaper or any sharpening stone. Just a few strokes from both blade sides will reduce the width of the blade to the required size and you will be able unscrew the screws with ease.
In case if you brake the tip of the blade, use the same method as described above, just in this case reshape the blade. As the size of the blade is quite small, it is easy to do and takes very little time.
And,yes, the blade can be reshaped plenty of times, not just once or twice. In fact it can be reshaped and sharpened till you run out of metal.
Do not forget to rate, please.
Mar 12, 2009 | Watches
Need pin for band on Fossil Am 3754
Measure distance between the lugs of your watch. Find the nearest watchmaker and ask for spring lug of that size (this is if you need to attach band to watch).
If you need a pin for bracelet links- measure width of bracelet and ask for split pin of that size.
Dec 18, 2008 | Fossil Watches
I want to adjust the steel bracelet on my new GMT II
You can do it yourself but proper watchmakers screwdriver is needed.
Check the sides of your bracelet and you will see screw ends with grooves. Unscrew them and adjust your bracelet (take the links out). Then screw them back in.
Regards
Arthur
Dec 13, 2008 | Rolex Watches
Wittnauer 11L00 Logo
49 people viewed this question
Top Wittnauer Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Wittnauer Watch Expert? Answer questions, earn points and help others
