Question about Boating
How do I use the tilt adjustment on my 6hp mercury outboard? Is there any other way than lifting the horse-shoe shaped bar around the shaft to release it for lifting?
Asked a boat mechanio, & he explained a circlip and spring are missing.
Posted on Feb 06, 2010
Testimonial: "thanx, I posted this reply;>"
2000 mercury 75 horse wont idle or run trimmed down but runs and idles trimmed up
Good Day
The Carburettors Need Servicing And float Levels Adjusted correctly
Apr 02, 2017 | Mercury Mark 75 Outboard Boat Motor...
I have a 2012 mercury 6hp four stroke that will not idle without the choke on
Hi, Lee and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Float needle and seat sticking.
5. Float level too low.
6. Carburetor bowl vent line clogged/blocked/pinched.
7. Idle adjusting ***** set too low.
8. Air/fuel mixture ***** set too lean.
9. Idle port, transfer ports, slow air jet clogged.
10. Slow fuel jet clogged.
11. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on the links below. Good luck and have a nice day.
Boat Motor Won Stay Running Watch This
Mercury Outboard Idle Adjustment
2010 6 hp Yamaha 4 stroke wont run with choke in Page 1 iboats Boating...
8m0055686r. google this for a free manual
Won Idle Here what did to fix it Yamaha Outboard Parts Forum
Apr 13, 2016 | Motorcycles
How to find model number on mariner outboard 4hp 2stroke engine
Mariner 4hp are identical to Yamaha engines.
You should find a sticker on the port bracket with serial and model number.
If that sticker has disappeard, an aluminum piece is stamped in the side of the cilinder. The numbervstamped in that round pieceis the serial number. I can convert that serial number in a year/model number...
Feb 27, 2015 | Mercury Marine 4hp & 6hp Stroke Outboards...
How do i replace a shift lever on a mercury 6 hp 4 stroke outboard 2006
Hello, is it the external shift handle you want to replace?
Then you'll have to remove the engine block from the driveshaft housing.
To do so: Drain the engine oil.
Disconnect the throttle cable from the carburettor.
Disconnect the start-in-gear cable from the recoil starter housing.
Disconnect the fuel lead at the fuel connector
Disconnect the choke puller at the carburettor.
Disconnect the white and black wire from the stop button at the engine-block and engine wires.
Remove 6 bolts holding the engine-block to the driveshaft housing.
Lift the engineblock.
The shift lever is fixed with a M6 bolt in the front-top of the driveshaft housing. You'll need a new gasket, Part Num 803508-9
May 04, 2014 | Mercury Marine 4hp & 6hp Stroke Outboards...
How do i replace shift lever on a mercury 6hp 4 stroke
shift lever has a bolt in it and shift rod you need to remove powerhead complete to access also remove gearbox !
Need to know year model for mercury 6hp serial 9494287
I was able to find the following information regarding 6 HP manufactured by Mercury. You can find more information on the boating forums.
http://forums.iboats.com/mercury-mariner-outboards-25/
HP
Cyl.
Beginning Serial #
Year
6214086111961621485612196262155144319636216075131964621745521196562195827819666220961711967622284857196862A910596198662B114231198762B233200198862B3855001989
Mar 14, 2013 | Boating
Boating Logo
154 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
