HP Photosmart C7180 All-In-One InkJet Printer Logo
Posted on Feb 20, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Printer Disappears from file and won't print from any "print" area
Every couple weeks this new "wireless printer" Printer Icon just disappears. I'll go to print something off my wireless laptop and it will say there are no printers loaded...it is just gone and anywhere I go to print...it says it can't find it...then I go to printers and faxes and it is literally just gone...it has disappeared.
Also, I also am getting the box "Insert HP Product assistant Disk" and it will not click away. I don't think I ever had such a disk. If it came with the computer I can't find it AND if it didn't...where is it? Is it in the computer? Can it be re-sent to me?
  • DaddyGeoff Feb 22, 2008
    Same problem as described. Printer disappears. This has happened a number of times. Each time I had to uninstall the driver and reinstall it. HP says it's a problem with Vista. How can this be resolved?
Anonymous
Level 2:
  • Expert 97 Answers
  • Posted on Feb 20, 2008
Anonymous
Expert
Level 2:
Answers
97
Questions
13
Helped
46624
Points
224
Did u get the hp printer photosmart installation disk, if do install the printer disk and set your printer settings to through the network then everything should be ok. your computer should scan and find the network and the orinter. go to the control panel and set your printer to default printer. if anything goes wronf from there call tech support or neigbor tech peeps.
Anonymous
Level 3:
Genius:
  • Master 3,587 Answers
Anonymous
Master
Level 3:
Genius:
Answers
3587
Questions
29
Helped
1146815
Points
9064
Go to www.hp.com and get a fresh print manager driver,
sometimes, the wireless connection hiccups(from your router/wireless device) caused by power glitches..you have that router on a power strip?
got backup for your computer?
5helpful
My printer will not print still after I troubleshoot it and everything. I have a netbook laptop so I don't know why it's not printing. It says it's ready and everything
Problem Print job does not print; No Lexmark job status window Solution What you will see
  • The Windows print queue spools the print job.
  • The print queue icon appears in the systray or notification area.
  • The print queue icon disappears as if the print job has successfully been sent to the printer.
  • The print job disappears and does not print.
  • No Lexmark job status window appears to indicate a communication problem.
  • No other communication errors. This issue is most likely due to a corrupt device mode registry entry from another printer that was installed and used in the past.
Or
  • You do see the job status window and you do not see any alerts or communication errors, yet still nothing gets printed
What to do
A confirmed cause must be established before a resolution can be achieved.
To do this:
  1. download a diagnosis tool that will help determine the cause of the printing issue.
    IMPORTANT: Again, this tool is only to be used in cases where there is no communication error message from the Lexmark job status window and the job spools quickly through the Windows spooler, yet nothing prints.
  2. Select an easy-to-find Save location, such as your Windows Desktop.
  3. Double-click on the delserDevMode.exe file.
  4. Accept the License Agreement. After the file is executed, it saves devmode.txt to your root directory (e.g., C:\devmode.tx.
Cant print using Dell A920 printer on my imac. printer set up shows driver is correct I think and the printer name is correct.
So clearly the Macintosh sees and recognizes the printer. WIll it let you queue a document to the printer? After you do, you will see an extra icon on the Dock that represents the printer queue. Open it up and see what is happening to the printer job. If it disappears, it was sent to the printer and the Mac thinks it was printer successfully; if it isn't printed then you have either a bad printer or a bad printer driver. If it stays in the queue and goes to "hold" state, look in the log to see what the error was -- the Mac is unable to negotiate with the printer to get your file printed.
2helpful
2answers
The printer will no longer print. It sends the job to the printer and after a couple seconds it disappears
The following link to Lexmark support has an optional diagnosis tool to assist you with your problem: (you did not indicate any error messages)
Lexmark Z2300 Print Job Disappears
5helpful
3answers
Print job disappears withouth printing in Quickbooks
Go to the printers folder, right click the printer and chose properties. Under properties go to the advanced tab and check off print directly to this printer. I work with HP and find this solves the problem of printer 95% of the time
2helpful
2answers
Printer disappears !
hi there are 2 types of wireless installation 1 is infrastructure and the other one is Adhoc in Infrastructure the computer and the printer are connected through a router this is a permanent sort of connection and remains even if the computer is shut down
but the Adhoc connection is a short duration connection in which the computer and the printer are directly connected and the connection is lost as soon as the printer or the computer is turned off
so its always recommended to connect teh printer using the infrastructure mode so that you do not face any problem
HP LASERJET 1100 WONT PRINT
go to Start, Settings, Control panel, printers and faxes is your printer there? is there a checkmark? no, then right click and set as default, put your mouse over it does it say Ready? no, then change cable.
send test page, it should print, if not the USB or Parrallel input of your printer has a problem.
k24674
Grand Canyon Tech
Grand Canyon Tech
