I have no sound from my monitor - Office Equipment & Supplies
  • spiritmounta Feb 05, 2010
    I have updated my sound card, checked the sound on the bottom right icon as well as in the control panel. My sound still does not work on my monitor
    President:
  • 1,871 Answers
Hello :
You need to uninstall the software of your printer and reboot the system , then install it again and reboot once again and problem will be solved .
good luck
Posted on Feb 05, 2010
  • 11,896 Answers
Find the speaker icon in the bottom right hand screen. Then right-click on the icon, go to properties, then you will see volume and wave adjustments and probably some others as well. Make sure they are ALL turned up and it should fix your problem. If by some chance it doesn't, then you may need to update your sound card drivers.
  • Nate Stansfield
    Nate Stansfield Feb 05, 2010
    try going to control panel, performance & maintenance, system, then device manager, find the sound card, expand the list, and check to see if it is enabled and see if the pc says if it is functioning properly or not. If not, you may have a bad card.
ASUS VH238 LED MONITOR HAS NO SOUND, NEED SOUND DRIVER
The VH238 monitor does not need a sound driver, the monitor plugs into the sound card in your computer and that is what needs the sound driver. Be sure the sound/speaker cable is connected between the monitor and the computer. It should look like this. The cable was included in the box with the monitor and plugs into the jack on the computer where the speakers usually plug and is green in color.
Mar 27, 2012 | ASUS Computers & Internet
No sound on my Samsung SyncMaster 930MP All drivers are updated
Lets find out first if it is the monitor amplifiers problem or PC sound card problem.
Try feeding the monitor with sound source such as MP3 player to see if you can get the sound or not, the sound system in the monitor is nothing more than Powered PC speakers mounted inside the monitor, no driver required to make the sound to work.
If it is the amp problem inside, you will be better off spending money on a good set of Powered speakers system that will have 100 times better sound quality than the monitor built-in speakers.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Dec 31, 2010 | Samsung SyncMaster 940MW 19" LCD Monitor
I can not get any sound from my monitor speakers since we received this monitor
Let find out first if it is the monitor rpoblem or the sound card problem. Feed the monitor with sound source such as MP3 player and see if you get the sound OK, if not then it may have bad sound IC which will not be worth fixing because the price of a good set of PC power speakers will cost you less than the repair job on this monitor, beside, you will get much better sound from the PC speakers anyway, something to think about.
Basic LCD monitor troubleshooting guide:
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Oct 20, 2010 | ViewSonic VX900 19" LCD Monitor
Can't hear volume from my monitor
We need to find out if the problem is in the monitor or at the PC sound card. Try feeding the monitor with sound sound source such as MP3 player to the audio line in of the monitor to see if you get the sound or not. If you do not, then you will need to open up the monitor and inspect the audio power amplifier circuits. If you get the sound OK, then verify that the cable between the PC audio line out (green jack) and the monitor audio input (green jack), next verify that the audio level controls (on screen volume control panel) are set up OK, not at minimum setting. Verify that correct driver for the sound card is installed.
Apr 29, 2010 | Hannspree HW191D LCD Monitor
Need the sound drivers for the monitor
You do not need sound driver for the monitor, but you do need the sound card driver for your sound card. Your monitor has powered speakers built-in, you just need to connect the green mini stereo jack from sound card audio out to monitor audio line in and adjust the volume control at both monitor and the PC.
Nov 30, 2009 | Hannspree 19" Widescreen LCD Flat Panel...
No sound on monitor
First off is your monitor has any speakers on it or capable off producing any sound? Not all monitors comes with speakers attached to it.
Jul 03, 2009 | ViewSonic Monitor Lcd 22in Wide Va2216w...
No sound driver on acer x223w how do i download
This is not a sound monitor, it does NOT have built in speakers. You need to have external speakers that plug into the audio jack in the back of your motherboard.
If this monitor did have sound, then you do NOT use an additional cable, you do not use DVI and HDMI at the same time.
HDMI is for graphics and sound, and you also need a graphics card that has a HDMI port to buy a monitor with sound, or you can't use it.
Monitors do not need drivers, most all OS, Windows have a monitor driver and there is no better monitor driver then the one in windows.
The drivers for sound come from the graphics card that has HDMI.
Dec 01, 2008 | Acer 22" X223w LCD Monitor
Sound
Is your monitor SUPPOSED to have sound? Apart from the power cable and the monitor cable, if it is a monitor with speakers, there should also be an audio cable. So 3 total. If it has a mic too, 4 cables. The audio cable is normally green and the mic cable pink.
Most monitors don't have sound though, and the ones that do, sound crappy. So unless you just plan to hear Windows dings, get some cheap speakers.
Sep 20, 2008 | Acer AL1916W 19" LCD Monitor
20 people viewed this question
k24674
jasbo
jasbo
