Question about Behringer Music
I'm using the ub2442fx but not getting enough volume
I'm using the ub2442fx pro for a show next week but can't get the volume high enough through my speakers. Any suggestions?
  • Behringer Master
  • 5,603 Answers
The unit should generate standard levels which then must be amplified. It LIKELY is doing that.
I suspect your amplifiers and/or speakers are insufficient. You have not told us the speakers you have or the size of the venue. The type of sound you are making is important too, as heavy bass requires BIG speakers... at least 15 inches for good reproduction.
I also would recommend you get an audio sound level meter... even an inexpensive Radio Shack one will do. This will allow you to comply with the sound level restrictions and compare speaker/amplifier sets.
If you can get to 90 Db, that is safe level.
Many venues they have massive amplifiers for say a 4000 sq ft area that have 1000 watts. This doesn't guarantee adequate sound since the efficiency of the speakers play a vast part. For good bass, the speaker cabinets need adequate physical size to match the speakers to be efficient.
A word of warning: If you have an ampliifier that generates much more than the rating of the speaker, expect to blow some speakers. Also DON'T be fooled by "peak power" ratings as they are fake, count on RMS power ratings when comparing.
Posted on Feb 06, 2010
Pdf manual by ub2442fx-pro
You can download from here... http://www.behringer.com/EN/Products/UB2442FX-PRO.aspx
Sep 30, 2014 | Behringer EURORACK UB2442FX PRO Mixer
I need a new fx push knob for eurorack ub2442fx pro
This place has a great selection of Behringer parts. You should be able to find your knob here: http://www.dbmproaudio.com/behrparts.html
Jan 10, 2013 | Behringer EURORACK UB2442FX PRO Mixer
My EURORACK UB2442FX-PRO has audio coming in but nothing coming out...
The outputs of these mixer needs to be connected to an active speaker.
An active speaker have an amplifier and a preamplifier.
Oct 02, 2012 | Behringer EURORACK UB2442FX PRO Mixer
I've only had my 714ce for about 5 weeks. I've used it for 4 shows and during my last show I experienced a volume drop. I unplugged the jack, plugged it back in and it was fine for a bit, bu
It's most likely the battery isn't producing enough voltage, though it may have been adequate for your other guitar.
However, you should discuss the issue asap with your dealer and/or Taylor support.
https://www.taylorguitars.com/support
Support
May 16, 2017 | Taylor 714ce Guitar Acoustic
Behringer Eurorack UB2442FX - PRO mic inputs are intermittent
Check the type of microphones connected and set the proper settings,
and connect it to other mic inputs .
May 21, 2012 | Behringer EURORACK UB2442FX PRO Mixer
I'm looking for a solution how can i connect my
You can use the compressor in two ways. 1st you can go inline from the main outputs into the compressor out of the compressor to the rest of the world using normal cables. You may also insert the compressor into the main inserts using a cable that is tip, ring, sleeve 1/4", to seperate 1/4" tip sleeve mono plugs. any more questions give us a call at the store 215-736-8055
Jun 10, 2011 | Behringer EURORACK UB2442FX PRO Mixer
When i have my FX on and sending to main they make a horrible clicking (shorting out) sound. if I push the main mix button it shuts off the effects and the noise goes away...bad side...then I have no...
Check the 5 volts to the FX unit, If the voltage is low, the FX processor will keep reseting generating clicks, In a different product, the 5 volt filter cap was degraded and voltage dipped down to 4.5 volts causing resets.
May 31, 2011 | Behringer EURORACK UB2442FX PRO Mixer
Mixer does not sound "clean"; almost distorted
If more than one input is bad, then problem has NOTHING to do with the preamps. Check list:
1. Make sure you are using BALANCED lines everywhere... either XLR or TRS cables.
2. Make sure ALL interconnected equipment, mixers, amps, powered speakers, CD players, etc. are ALL powered from the SAME receptacle or power distribution unit.
3. Do proper setup. Select each channel PFL and set the trims so the indicator never goes into clipping, but is in the 70% range during max volume input to mics, etc..
4. During operation the sliders should be at least 50% up on used channels and the mains. Setting of levels throughout the system is important for noise free operation. Using EXCESS gain at some point results in distortion and noise. Using sliders near the bottom position results in poor signal to noise ratio.
Now re-read #2 above... and believe it. I have seen a lot of equipment blown due to ground bounce of building power. That is why the pro's run power back to their mixer from the area where the amps are powered.
Apr 28, 2011 | Behringer EURORACK UB2442FX PRO Mixer
Will a Behringer UB2442fx-PRO run 2 main PA speakers plus two passive stage monitors without blowing up?
ALL the speakers will either have to be POWERED or have external amplifiers. The mixer has NO power amps capable of driving speakers. When connecting, make sure that the mixer is powered by the same receptacle as the speakers or amps. Used balanced line for interconnection.
Jan 24, 2011 | Behringer Music
My behringer ub2442fx pro has the numbers 88 flashing red in the display and a clicking sound every time they flash. any idea what the problem is?
A high likelyhood of a power supply problem.
I had a similar thing on a GX110 and it was an electrolytic cap that filters for the 5 volt regulator on the DSP board.
As the DSP starts up, the load on the supply sucked it below the operating point and caused the DSP to keep reseting. The display did flash.
The unit will have to be opened and trpunbleshooting done to find and repair the problem.
Dec 20, 2009 | Behringer Music
Music Logo
390 people viewed this question
Top Behringer Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Matthew Spark
Matthew Spark
Are you a Behringer Music Expert? Answer questions, earn points and help others
