Question about Kenmore Washing Machines
My kenmore washing machine shows a f24code why
  • 15,935 Answers
This advice is for Whirlpool Duet and Kenmore Elite model FRONT LOADERS displaying the “F24” Error Code. Some of the error codes on these model washers can be erroneous, however. The first step in troubleshooting any error code is to simply unplug the washer for AT LEAST 30 minutes in an attempt to reset the Central Control Unit (CCU). This is the main "brain" of the washing machine. If the error code reappears following a CCU reset, then you have a genuine problem.
"F24" is an indication of a water temperature sensor (NTC) error, or Heating Circuit failure. Check the Water Temperature Sensor and check connections to the Water Temperature Sensor.
To access, you will have to UNPLUG your washer and remove the lower access panel under the door. The panel comes off by removing the screws under the bottom edge. HINT: If you place a 2 x 4 under the front feet of the washer, it will make access to the screws much easier. If the panel sticks, a tap on the sides will knock it free. The panel will drop down then come off. The sensor (NTC) is located at the base of the wash tub in the front on the heating element. This will be a small square shaped plug between the heating element terminals. Make sure this plug is secure and not loose or unplugged. It is common for the connector plug to come loose due to vibration. If the plug is intact, check the contacts for corrosion. If everything appears as it should, then unplug the wire harness and take a resistance check. Readings will be as follows:
Temperature Meter Reading
32°F (0°C) 35.9 K ohms
86°F (30°C) 9.7 K ohms
104°F (40°C) 6.6 K ohms
122°F (50°C) 4.6 K ohms
140°F (60°C) 3.2 K ohms
158°F (70°C) 2.3 K ohms
203°F (95°C) 1 K ohms
Roughly...around 9K ohms at room temperature if I'm reading the chart correctly. Take readings as listed and also double check the connector to make sure it is not oxidized. Try cleaning the plug and reconnecting to see if the error code goes away. If not, you will probably have to replace the sensor. If the sensor checks good, take a reading across the heating element terminals. It should indicate about 15 ohms.
Lastly, remove the washer top panel by removing the three screws holding the panel in place in the rear. Once the screws are removed, slide the panel back then off. Locate the Central Control Unit (CCU) directly behind the wash tub. Take a resistance check at the Heating Element Solenoid by removing connector 9 from the CCU (this is the second connector from the RIGHT as facing from the front). A reading across test points 1 & 2 should also read 15 ohms.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
I have Kenmore washing machine showing F1
The F1 fault code on this washer indicates that the water level pressure transducer signal is out of range. The pressure transducer air hose tubing being pinched or crimped can cause this. A failed pressure transducer on the machine control board can also cause it.
Jul 25, 2017 | Kenmore Washing Machines
Kenmore washer mod.11023822100 fills with water drains water will not wash or spin
Your washing machine has a transmission and a electronic clutch your clutch is bad it is not engaging to let the motor turn your transmission. Please go to Sears Parts Store near you and ask them for a clutch for your kenmore washer model# 11023822100. Then tell them to print you out a diagram to show you how to replace it. Thanks
Aug 23, 2010 | Kenmore Washing Machines
My kenmore oasis shows the f1 upon starting the machine and at 23 minutes and often shows th ul why is this
Mine is doing the same exact thing. Just after I press "Start", the F1 starts beeping. Then at 23 minutes into the cycle, it does it again. So frustrating! What is wrong with this machine?
May 20, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Have Kenmore Elite Catalyst Washer showing F3.
I have a top load Kenmore Gold Catalyst Cleaning Action washer that is stuck on permanent press mode. The digital display reads 8 min. and will not turn off or clear.When it is turned on the, the timer goes to 37 minutes and beeps repeatedly through all cycles. It will not clear even when I unplug it. How do I fix this annoying thing!!? Thoughts please.
Bill
May 22, 2010 | Kenmore Washing Machines
Kenmore elite washing machineshuts off and shows
with an f1 code most likely youd have to replace the control board f1 is also know as the code of death 99% of the time it is the main control board
Apr 07, 2010 | Kenmore Elite 45986 Front Load Washer
My Kenmore front load 4304 washing machine tub
I would need the complete model # to get you a breakdown showing the piece i believe to be broken and in need of replacement. I believe this Kenmore F.L. was built by Frigidaire and they have had a problem with a specific piece on this machine. I will be glad to help once you get me the full model, should be around the opening of the door.
Oct 25, 2009 | Kenmore 43042 Front Load Washer
Washer showing 5d
Sensing suds. There should not be any. Please contact me if you need further help and leave feedback. Thanks for letting me help you!
Nov 30, 2008 | Kenmore Washing Machines
Washing machine fault
lg trom showing E and on display won't drain
Mar 26, 2008 | Washing Machines
Washing Machines Logo
49 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
