Question about Lexmark X2550 All-In-One Printer
Incompatible print cartridges?
I have installed compatible print cartridges, but error message states that print cartridges are unsupported. How do i get them to work?
  • fizzybum Feb 20, 2008
    thanks for the tip, but no options to select cartridges, cartridges are exactly the same. i think its the chip. any ideas
    Genius:
  • 1,019 Answers
just click on them to say ok, and accept the unsupported cartridges ( if applicable ) do you get the choice.
certain printers, have an option in printer prefs, to change cartridges. check the cartridges are the same ( or compatable )
if the cartridges have a chip fitted, they need to be reset if recently filled.
hope this helps mike @ Compurepair.
Posted on Feb 20, 2008
  • Mike Waldron Feb 20, 2008
    If its the chip. You,ll need to replace the cartridge.
    First try this. remove the cartridge. and reinstall it. usually you,ll have to push it down until you feel a gently click. if the chip is not correctly aligned in its holder. the printer will not recognise the cartridge. if the printer recognises the original but not the replacement. then it,s likely to be a faulty Cartridge or chip.
    regards mike @ Compurepair.
Error 9
Is there a camera or smart card connected to the printer? This error usually has to do with an unsupport camera or card being connected.
Feb 28, 2011 | Canon PIXMA MP160 All-In-One InkJet...
I have a Lexmark x7170. After installing ink cartridge printer says incorrect left cartridge.If you try to print you get unsupportive cartridge.We had just changed the cartridges and it printed fine till...
Some older print cartridges are not compatible even if your model is listed on label. I'm talking a few years difference. The printer knows this and that is what the error is telling you. Make sure you have the right number in the right slot.
Jan 06, 2011 | Lexmark Office Equipment & Supplies
Hi, I have a lexmark x7170 and keep getting an error message "unsupported cartridge". Help please!!
If you receive an error message that tells you that you have an unsupported cartridge, then you need to remove the cartridge. After installing the appropriate type of ink cartridge you should no longer receive the error message and you can then perform a print test.
Instruction on how avoid unsupprted cartridge message.
  1. Lift up the scanner unit (with the power on). The printer cartridge carrier will move to the top of the printer into the loading position.
  2. Press down on the lever above the cartridge and then raise the cartridge lid. Remove the cartridge and make sure the cartridge supports no more than four colors (cyan, yellow, magenta and black) and a speed of 22 parts per notation.
  3. Insert the compatible ink cartridge into the carrier and then lower the cartridge lid. Close the scanner unit, then make sure plain white paper is inserted into the paper loader.
  4. Press the "OK" button on the control panel and the unsupported cartridge message should be gone. Press the "Select" button and a test alignment page will print.
Nov 21, 2010 | Lexmark X7170 All-In-One InkJet Printer
I have a lexmark 2580, I keep getting 'unsupported cartridge' message, and one of the lights on the printer is constantly blinking. I have brand new lexmark cartidges installed.
Problem Unsupported Cartridge; Error: "Unsupported cartridge"; Incompatible cartridge error; Incompatible cartridge in the printer; Cartridge not recognized Solution What you will see
When a cartridge is inserted, an Unsupported Cartridge error message is displayed on the printer operator panel.
Affected printers
This issue affects printers sold exclusively in the Dixon Store Group (DSG) in Europe and in Circuit City in the U.S. NOTE: The cartridges for these printers are sold exclusively in these stores or on their websites.
Explanation
The printers listed in the table below are compatible with a #2 cartridge (in single cartridge printers) or a combination of #2 and #3 cartridges (in two-cartridge printers). They do not support the standard color 28A 35, and Mono 29A 34 ink cartridges. If the standard color 28A 35 or Mono 29A 34 ink cartridges are used in these printers, they will fail to print and the printer will post an Unsupported Cartridge error message.
Solution
Lexmark recommends using either a #2 cartridge for single-cartridge printers or a combination of #2 and #3 cartridges in two-cartridge printers.
Cartridge compatibility chart
NOTE: These printers are sold exclusively in the Dixon Store Group (DSG) in Europe and in Circuit City in the U.S. The cartridges for these printers are sold exclusively in these stores or on their websites.
Item Printer #2 Color Cartridge #3 Mono Cartridge #31 Photo Cartridge 1 Lexmark Z738 Yes ... ... 2 Lexmark Z1380 Yes Yes Yes 3 Lexmark Z1480 Yes Yes ... 4 Lexmark X2480 Yes ... ... 5 Lexmark X2580 Yes Yes Yes 6 Lexmark X3480 Yes ... ... 7 Lexmark X3580 Yes Yes Yes 8 Lexmark X4580 Yes Yes Yes
Nov 07, 2010 | Office Equipment & Supplies
I continualy get error msg to check printer cartridge, when new ones are installed same msg repeated.
I just replaced my black ink cartridge on the same printer and I'm encountering the same problem: a message that states "the black cartridge is not compatible with this printer". Well, that's not true. It is compatible. As a matter of fact, I got my printer (with new cartridge installed) to print a page once. But, now its giving me problems again and I can't get it to work. Help!
Oct 28, 2009 | HP PSC 1315 All-In-One InkJet Printer
HAving trouble printing
Check and make sure you did buy the right one first.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Apr 23, 2009 | Canon PIXMA MX310 All-In-One Printer
In canon pixma ip1700 Alarm light orange flashes 15 times
Fifteen Flashes: The FINE Cartridge cannot be recognized.
Possible causes are as follows:
- The FINE Cartridge may not be installed properly.
- The FINE Cartridge may not be compatible with this printer.
Install the appropriate FINE Cartridge. If lines are misaligned or the resulting output is not satisfactory, carry out the Print Head Alignment.
Apr 06, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Lexmark x2500 invalid cartridges
I am out of ink for my printer the numeber is 28 black 29 color
Nov 23, 2008 | Lexmark X2500 All-In-One Printer
Unsupported cartridge message
I was having this problem with a Z730. The printer was finally working again after removing and inserting ink cartridge like 40-50 times. No pun intended. After installing cartridge try turning off printer and then back on.
Aug 19, 2008 | Lexmark X2470 All-In-One InkJet Printer
Printer will not work
Hello trudyann,
I think you re-filled the cartridge and that's why you got this message
Use genuine cartridge and it will be work correctly.
But if you can copy papers by this All-In-One device .. and you can't use it as printer .. re-install the driver .. While installing if you got error message like [Unsupported cartridge] Press [Alt+F4] and continue the installation.
Thank you for using FixYa.
Aug 03, 2008 | Lexmark X2470 All-In-One InkJet Printer
Lexmark X2550 All-In-One Printer Logo
1,143 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
