Question about Kenmore Elite HE4 Electric Dryer
My dryer is not getting heat, lint is clear, gas is on.
  • 10,319 Answers
The ignitor is at fault. Replace it and it should operate agian
Posted on Feb 06, 2010
Whirlpool dryer Model wgd59005wo not getting heat
1. remove lint screen and remove screws
2. take a broad blade putty knife ind insert between top and front panel
on either side(should pop up)
3. remove front panel screws at top of panel, remove panel
4. Igniter element is locared on burner(ceramic)
Jan 31, 2013 | Whirlpool Dryers
The gas dryer is heating but with diminished air flow.
Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance. Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician.
Jan 09, 2011 | GE Profile Harmony DPGT750GC Gas Dryer
I just cleaned out lint from the exhaust pipe. Louvers and pipe are clear and functioning. The dryer operates but doesn't heat. Some web sites talk about gas valve coils, the owners manual talks about...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 20, 2010 | Whirlpool LGR3624JQ Gas Dryer
My dryer isn't heating. The vent is clear and the lint filter.
heatman101
Aug 07, 2010 | Amana DLG330RAW Gas Dryer
Dryer won't heat? Lint screen is clean, duct is
heatman101
May 12, 2010 | KitchenAid KEHS01P Electric Dryer
Can't get heat from our gas dryer. LG dlg3788w
my model number is lgr4634eq1. my gas dryer just spins but does not heat. The dryer came w/the house 3/13/98..
Feb 01, 2010 | LG DLG3788W Gas Dryer
80 Series Gas Dryer - No Heat. All other parts
check outside drye vent where it goes through the wall they clog up with lint sometimes and force the escaping warm air to back up which causes sensor to give wrong reading if this is clogged just clear it till you feel the air coming through also check vent at bottom of dryer disconnect flex pipe and check for clogs there as well ..and always clear lint trap after every load
Dec 13, 2009 | Kenmore Dryers
Dryer taking too long to dry
If you can get the dryer outside, blow it out from the bottom with compressed air (using an air compressor or even a leaf blower). make sure the vent is clear and has no lint buildup. make sure the burner unit is also lint/dust free. If it is still heating, that is good news, and it is most likely a "breathing" issue. it also could be an issue with your gas pressure, however that is very unlikely. Best wishes in this project.
Oct 22, 2009 | Kenmore 73952 Gas Dryer
My dryer gets hot but it dont dry my clothes ,it turns the clothes but thay dont get dry and there is no lint in the filter..please help
Hello. I am glad you checked for lint in the filter. That could have been a problem. There are several other possible causes Since you did not state whether you had an electric dryer or a gas dryer, I will tell you what to look for in each category.
If you have an electric dryer it could be any one of these things If your dryer doesn't heat, check these:
Power from the house
Heating element
Thermal fuse
Wiring
If it is a gas dryer it could be one of these things:Igniter
Gas valve coils
Thermal fuse
Jul 31, 2009 | Dryers
Will not heat
glow bar igniter ... - thermal fuse ( not all models ) ... - coil on the gas valve ... - gas valve ... - thermostats ... - motor heat switch ... - timer ... - selector switch ... - sensor ... All these will cause this problem.
Mar 22, 2009 | Kenmore 74672 Gas Dryer
Kenmore Elite HE4 Electric Dryer Logo
52 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
