Question about Goodman PHKJ048-1 Air Conditioner
I have a Goodman phk 024-1 unit that will not heat.
What are the testing procedures for the elements etc.
  • Goodman Master
  • 1,070 Answers
Basically, set unit to call for the heat strips to be energized. There should be a control that sends power to the heat strips. Usually a contactor or relay. Verify that power passes thru this device to the heat strips. Make sure that the correct voltage is being delivered to the heat strips. If correct voltage is present at the terminals of the heat strip, check the amps. If no amps, heat strip is probably broken. Don't forget that some of these units have sequencers that "Stage" the energizing of the strips. And all of them should have some safety device such as a fuse or thermal overload or some other device that stops voltage should there be a malfunction.
Hope this helps.
Posted on Feb 06, 2010
Heating elements not energizing on Goodman AFUE 60 air handler
FIRST i would use a multi meter and check elements for power. one or more may not be working. SECOND iwould check sequenser . also look for burnt wires at element and throughout. probably sequensor they are usually under 20 dollars. the wires on very bottom of sequensor should have 24 volts when heat is on.
Jan 21, 2014 | Goodman Heating & Cooling
Goodman package unit heat strips will not turn on
Put meter probes at in put terminal of the element if you read 220volts that mean your relay is good. if you got it there use amp meter on one leg of that element. You should read some amp draw there but if there is no amp draw it mean the element broke.
Nov 29, 2013 | Goodman Manufacturing Goodman GPH1530M41...
Heating element will not work
CHECK UP THERMOSTATE GIVING CONT. TO hTR. OR THREE WAY VALVE
Nov 11, 2013 | Goodman Manufacturing Goodman GPC1448H41...
I installed my new unit this summer and the ac worked fine, now the heater does not work
frist check that the thermostat and the mood is in right positions then check that thermostat give signal to Htr.if Htr is right ohms
Nov 11, 2013 | Goodman Manufacturing Goodman...
I JUST BOUGHT THIS UNIT IT HAS THE OUTSIDE UNIT AND THE INSIDE UNIT AND I WAS TOLD THAT THE HEAT PACKS IN THE INSIDE HANDLER IS FOR EMERGENCY HEAT ONLY...IS THIS TRUE?
Yes, if you are talking about a heat pump. It you have an electric furnace inside, the electric elements are for emergency heat. Otherwise, unless you switch it manually at the thermostat, the heatpump (outdoor unit) will run all year around. If you want to use your inside heater (electric heater) just switch your thermostat to "emergency heat" and it will turn on the electrical elements instead of the outdoor unit. This way will make your elec. bill higher tho. The heat pump is much more efficient. Hope this helps you , have good day
Jul 21, 2011 | Goodman Heating & Cooling
I have a Goodman Electric furnace, Model AR 30-1 that is not putting out enough heat. Could it be that the heating coil is going out? Air from ducts is lukewarm at best.
There are more than one set of electric coils in these units. You can test each one with an amprobe to see which one has no flow. Than it is a matter of finding out why. Sequencers stagger the starting order of coils in electric furnaces, could have one of several other issues!
Feb 02, 2011 | Goodman Heating & Cooling
Heating Element on my A/C not getting hot
It definitly did not open the element the 24vac isn't enough. I would go back over the wiring.When your t- stat calls for heat you want it to energize both sequencers. the easist way to assure this is to connect the whiet and purple two gether at the a/h.
Mar 14, 2009 | Goodman CLQ36AR49 Air Conditioner
Fan oven element
The test is fairly straight forward: Make sure the unit is off. Generally, there is a screw which holds the element in place near the connector. Remove it and the element will slide out. Now, use a resistance (Ohm) meter and measure the resistance across the terminals. If the unit is visibly damaged or you get no reading (use the 1 K ohm scale), change out the element. If the unit tests good, suspect the control or the wiring from the control to the element.
Dec 31, 2008 | Ovens
Heater problem model PHK 080-1
THE BURNING SMELL IS NORMAL. BEFORE HEATING SEASON OPEN ALL DOORS AND TURN THE HEAT UP AND LET RUN TILL ALL DUST IS BURNT OFF. IF BLOWER IS NOT COMMING ON NOW. THERE ARE 2 TIME DELAY RELAYS, AND ANOTHER RELAY FOR "FAN ONLY OPERATION". ALWAYS MAKE SURE THEY ARE NOT THE PROBLEM BEFORE REPLACING AN EXPENSIVE MOTOR.
Feb 07, 2007 | Goodman PHKJ060-1 Air Conditioner
Heating & Cooling Logo
345 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
