Question about Maytag Neptune MAH5500B Front Load Washer
OUR WASHER SHAKES ALLOT WHEN ON SPIN MODE. - Maytag Neptune MAH5500B Front Load Washer
It needs to be leveled. Try adjusting the threaded feet using a standard adjustable wrench (you'll need a slender one to fit under the machine) and check the level front to back, as well as side to side.
You may need to put wood shims under the feet to level it out.
Posted on Feb 05, 2010
2 Suggested Answers
  • 1937 Answers
SOURCE: washer shakes as if unbalanced during spin cycle
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Whirlpool / Kenmore top load, direct drive washers use a number of springs between the main suspension plate and base assembly as well as friction pads that are designed to minimize shaking.
See the Whirlpool / Kenmore service manual for top load washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It's likely that one of the springs or pads has broken or come off.
See the following for how to remove the cabinet to get at these.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Posted on Oct 24, 2009
Washer shakes during spin cycle
it's possible your load is unbalanced, if this is the first time this has happened
Mar 17, 2012 | Kenmore Washing Machines
Maytag neptune mah8700 a
ok..I'd suspect the mechanism for the timer is unhappy again.
and the shakes comes from imbalanced chassis. Try to re level it first..
Mar 04, 2008 | Maytag Neptune MAH6700A Front Load Washer
Unit shakes in spin mode
check to see if clothes isnt evenly coating the drum ,, is unit level remeber cabrio lid is slanted so you cant put a level on top lid and level unit must use the side of washer front to back on each side ...
Jan 28, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
My brand new amana washer shakes violently when spinning
try adjusting the feet on the bottom of the washer the floor may not be level to adjust the legs turn them with a wrench or if the lock nuts are not tight turn the legs clockwise as you look at the front of the machine till all four feet are sung on all 4 corners. This is the most common problem. hope this helps and thanks for using fix-ya
Feb 15, 2010 | Washing Machines
I have a wsxh208 washer that pounds awfully when in spin mode washer is level?????
check the shocks to see if broken.Is this item new?did you remove shipping restraints?Also check the top springs to see if there ok.Hope this helps happy thanksgiving.
Nov 25, 2009 | GE WSXH208A Front Load Washer
Shakes when on spin
Hi, your washing machine need to be leveled, use a spirit level, to level your washer, used washer legs for adjustments, after leveling of washer, place both hands on machine, and try to rock side to side, front to back,there should be no play (movements) on washer, make sure machine is firmly position, good luck.
Aug 13, 2009 | Washing Machines
Kenmore front loader washer squeaks in washer mode and shakes in spin.
shocks made of plastic squeaks, a little greese may help
Nov 08, 2008 | Washing Machines
Washer shakes on spin cycle
2 possible causes 1 cleanout filter and check water is pumping out properly before spinning
2 check the suspension legs at the base of the tub for wear or damage.
Oct 29, 2008 | Speed Queen AWS52NW Top Load Washer
Admiral Heavy Duty 22lb. 2 speed motor going off balance
Had Same problem. Replaced The 6 retaining springs and snubber.
$15.00 worth of parts.
Dec 22, 2007 | Admiral AW22 Top Load Washer
Kenmore washer shakes violently during spin cycle
syrny,
Not sure what you did, exactly. First, does the machine shake when spun empty...and then with water only? If so, you have probably failed to tighten something or misaligned something. Go over your work.
No shakes? Rearrange your load. You may have a pair of heavy wet jeans which is throwing the whole thing out of kilter. It only takes about a half pound of sodden clothing to do this.
Nov 26, 2007 | Kenmore 22422 Top Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
113 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
