Question about New Bright Toys
Gear assembly for the tower crane by new bright
2 Suggested Answers
SOURCE: My son has a New Bright Power Horse tower crane
It can be taken apart as i had the same problem.
Posted on Apr 08, 2009
Holmes u tower fan. How do I clean it?
Best way to clean most tower fans - YouTube
? 0:23
www.youtube.com/watch?v=PDnPs7AQu_M
May 9, 2014 - Uploaded by slim alee
Keywords; Lasko,Honeywell, ozari, Holmes, newair, crane, Seville, vernado, etc etc. how to open a tower fan ...
Sep 30, 2015 | Tower Dryers
How do I take apart the New Bright Power Horse Tower Crane TC36 to fix the tangled strings inside?
WOO HOO I FIGURED IT OUT!!!! You have to pull it apart from the base up. First thing I did was take off the feet. If you look down the tower potion you can see a screw. Then u took off the tower. I figured out that if you just lined up the black square portion it would have come apart with just the one screw. Anyways now there is 2 more screws to get. 3 total to take the new bright tc36 tower crane apart. They are hard to see, but once the base is off you can get at em. Good luck everyone.
Jul 09, 2012 | Garden
How do I replace the string on cranky crane
To start, you need a TA27 triangle driver bit to remove the handles. Then pull hard straight up on the top block with the face on it. It will separate from the tower. The rest is straight forward. I have some choice words for the person who designed this thing...
Apr 27, 2012 | Thomas and Friends Deluxe Cranky Crane...
X215 paper pickup roller needs to be replaced
My experience is paper pickup rubber is old, shrunk and dried out. You can replace the entire roller assembly (including shaft) or the roller only or just the rubber, sponge tire on the roller.
The pickup roller with its square shaft and bearings are removed as an assembly. Remove
1) Cartridge
2) Paper Tray
3) Rear Cover
Four M3x10mm bright washerhead threading screws. Two of them are very low down in deep wells.
Carefully tug the cover rearward to remove it.
Note the parallel printer connector's bails when reinstalling this cover.
4) Right Side Cover (Optional)
Carefully tug the cover forcefully rearward to remove it.
5) Left Side Cover
Disconnect the speaker.
Gently tug the cover forcefully rearward to remove it.
6) Drivetrain Assembly
Mark the green ground wire location at one of the center screw.
Six M3x10mm bright washerhead threading screws.
One cable connection.
7) Gear Support Plate at Front Left
Three M3x10mm bright washerhead threading screws.
8) Electronics Pan
Two M3x10mm bright washerhead threading screws at the rear. NOTE the black ground wire at the left side screw.
Ten M3x10mm bright washerhead threading screws from underneath. NOTE that two of the screws are accessed through 10mm diameter holes in the pan.
Note the cable connections do not have to be disconnected and the electronics pan does not have to be completely removed.
9) Pickup Clutch
Pull it straight off. NOTE that it's indexed to only go on, one way. Note the other gears and their position (take a picture!)
10) Pickup Roller Assembly (w/Shaft)
One side bearing has a claw. Release the claw and the bearing can be slid toward the pickup roller, enabling removal of the entire pickup roller assembly.
Carefully remove the just old roller tire (or carefully just cut the old one lengthwise and discard). If you are careful, you can remove the entire pickup wheel by unlatching the small fasteners and removing the whole wheel, remove the old tire, reinstall a new tire and reassemble the entire assembly.
Dec 08, 2009 | Lexmark X215 MFP All-In-One Laser Printer
Can't remove old assembly...stuck in there
You have to remove the tank bolts on either side of the flush valve. Once you remove it, there is a tank to bowl seal that will need to be replaced. Remove the old seal and there will be a huge plastic nut that holds the flush valve to the tank. Remember to use new hardware when reassembling the toilet so that it won't leak sooner rather than later!
Apr 03, 2009 | Crane Plumbing Toilet To Go Tall...
Toys Logo
194 people viewed this question
Top New Bright Toys Experts
Colin Stickland
Colin Stickland
MeAndMyBrain
Level 1 Expert
Tom Chichester
Are you a New Bright Toy Expert? Answer questions, earn points and help others
