Question about Panasonic Lumix DMC-FX3 Digital Camera
Shutter wont open or close
When camera turns on it goes to say turn off camera and turn back on. I got the shutter closed and then it would not open.. I finally got it open and it does not close. It continues to say turn off and back on. I blew air in it to see if that would blow out any dust.. Any suggestions. I have had camera just one year. Thanks! Gina
  • Ladyhawk008 Feb 20, 2008
    Thanks for the advice. I got the shutter open but it will not close ( it tries to) and the message still come one turn off and back on. I was able to view my photos from mexico and download them on my computer. I did charge the battery over night and have been working on it. I downloaded the manual so I will see what I can with your advice to disassemble it. My one year warrenty just expired right when it happened.. go figure.. Thanks
  • Ladyhawk008 Feb 21, 2008
    I can get the shutter to open but the message "turn off camera and turn back on" still appears. Is the camera toasted?
    Genius:
  • 1,665 Answers
When you look at the camera from a horizontal viewpoit, you can see that the lens mechanism looks like Leaning a little?
You can hear the drive trying to move the lens but it doesn't? bud
The error message on the screen instructs you to turn off the camera then turn it back on.
When do this the same message re-appears.
So may camera had dropped down resulting in the lens not retracting when the camera is turned off.
Solution: All moving parts and their relative position must be checked. (Recommended an authorized service shop at your area.)
Good Luck
Posted on Feb 20, 2008
  • 4,102 Answers
Hi alot of people have been having this problem its usually either bit of grit stuck down side of lense or could be the lens motor failing.
One thing you can try is banging the camera into the palm of you hand not to hard but doing this got my camera working again failing this.
Are you sure the battery is fully charged and will the camera come on without it been in take picture mode can you put it into look at photos stored on device this would tell you the battery is fine.
If the camera has been put down with the lense out and any pressure put on it this will damage the lense motor.
The problem with the motor failing is that you cant get it repaired they dont sell the parts and also no shop will take on any repairs for your type of camera so just try giving it few taps in your hand to free any dirt stuck down side of lense.
Also when you switch it on try pulling the lense out this might also free the lense allowing it to work let me know how you get on ok
  • paul proctor Feb 20, 2008
    Hi if you have managed to get the shutter out and the camera on then check the battery level as low bat will cause the shutter to fail.
    But if you have managed to get the shutter out then the chances are that the shutter motor is up the shoot try working the lense in when it should go in ie turning camera of or out when on.
    Also try this when the camera is on put it into take picture mode then try using the zoom button whils touching the lense just to see if you can feel the motor trying to work if not then its definately the motors no good if you can feel it try to move then its going to have something jamed in.
    So if you can use the zoom button work it in and out a few times then when you goto zoom out pull the lense gently as you press the zoom button and the same reducing the zoom push lense back in but be gentle if this still dont rectify problem then the chances are you have to replace the camera.
    Knowbody repairs these and you cant get the parts.
    Just see if you can feel the motor working when you switch camera on and off just gently rest finger on the side of lense then switch camera on and off and if the lense motor is working you should feel it trying to move the lense let me know once you have tried this ok then i can assist you further ok.
  • paul proctor Feb 21, 2008
    Hi yes i would deffinately say its toast you cant get them repaired the best thing you can do is either sell it for spares like the battery or keep the battery and buy one with same bat that way you get spare battery.
    Even if you took it to camera shop they would tell you unless the camera is worth about £1000 or $2000 they dont do repairs sorry i couldnt offer you any more help
  • Panasonic Master
  • 19,396 Answers
Hi seems to be a mechanical problem.
  • Ginko
    Ginko Feb 20, 2008
    You should carefully remove the ring shaped part that close the shutter, check all single parts inside und unlock it.
  • Ginko
    Ginko Feb 20, 2008
    Probably you will need to disassemble partially the camera to fix this problem. In this case you will need the service manual. you can download it for free here:
    http://safemanuals.com/user-guide-instru...#
    Naturally, if your camera is still under warrantee I suggest to contact panasonic and ask them the address of nearest service centre.
The viewer is "black". The camera takes pictures, goes through th motion, sound, but the picture is black, no image
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jun 12, 2010 | Canon PowerShot SD1000 Digital Camera
Shutter wont close
Try setting the shutter to B and see if you can trip the shutter. If no go then it has mechanical problem. If it works on B but not on other shutter speeds, you have electronic problems.
May 16, 2010 | Pentax Program Plus 35mm SLR Camera
My shutter will not close when turned off but when turn on it goes in and out
sensors around your shutter are not functioning properly... so they need to be repaired....
Feb 22, 2010 | Olympus FE-190 Digital Camera
LENS PROBLEM
The slightly open shutter is the reason for this problem. Thank God you mentioned it.
Solution: Try with your fingers to shift the shutter “blades” back and forth to see if they move freely. If they do no move freely it maens the shutter “blasdes” and stuck by particles/dust/something. So you just continue to shift them like that untill they are free again. Once they are free turn your camera back on and it should perform as normal.
Sep 18, 2009 | Sony Cybershot DSCW80 7.2MP Digital Camera...
When i turn on the camera the shutter closes, when I turn it off, the shutter opens
I dropped the camera and now the shutter opens when turning off & closes when I open the camera. But when it is open, the shutter will open a bit making it impossible to take pictures. What should I do or where do I take it for repairs?
Tks, Ruth
Sep 11, 2009 | Sanyo VPC-S500 Digital Camera
Lines on screen and photos, too bright photos outside
Lines across your pictures or pictures too bright are due to the shutter not closing correctly or at all.
to check this- turn camera on, turn off flash, turn camera around and look into the lens. Adjust the zoom so that the shutter and internal lens comes up to the end of the lens and whatch as you take a picture. You should see the shutter close completely over the lens. If it doesn't move or does not close over completely then there is your problem.
If camera was dropped it could have jammed the shutter open or obstructed it in some way from closing completely.
camera will require repair/ service.
You may have some luck if you power up and down your camera numerous times before taking a picture. The action of the lens opening and closing may free the shutter.
Aug 07, 2009 | Fuji FinePix V10 Digital Camera
Power shot a620. screen is not showing pictures, all icons are there but screen is black? Help please!!
Sounds like you might have accidentally pressed the DISPLAY button on the back of your camera. It turns the screen on and off to save batteries. Turn on your camera, and press this button once again to turn the screen back on.
But if your camera is also taking black pictures,
a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
Jul 30, 2009 | Canon PowerShot A620 Digital Camera
Panasonic Lumix DMC-TZ3 shutter doesn't close all the way and gives message "please turn camera off then on again"
My camera got dropped into the dirt. The dirt grains are detrimental to the plastic mechanics of the lens system, they imbed themselves into the plastic and become like sand paper. I took my whole camera apart - something that I would not recommend but I was desparate. I don't think I can save my camera, it needs a new optics.
If the shutter has problems it is most likely that the thin aluminum casing at the front of the lens got bent and you may be able to bend it back with a thin screw driver, that you can manage to insert between the plastic casing of the shutter and the aluminum cover. Just where the aluminum casing ends at the front of the lens. But be careful, you may otherwise damage the aluminum and the looks of your camera. If you got dirt in there, you may want to manually (carefully) open the shutter when the camera is shut off, let it close, etc. while blowing air between the gaps of the shutter blades. You can buy a 'Cleaning Duster' spray bottle from Office Depot and use that. But be carefull to hold the bottle straight, don't tilt it or the liquid content will spray over your lens and you have to clean the oily residue with a solution of soap and water (I had to) and wet a paper tissue (use a Kleenex that is not impregnated with a lotion, on the back of the box it will tell you 'Not recommended for cleanig eyeglasses'.
Hope that helps.
Stephan
If that doesn't work, then you may have to send the camera in for repair.
Aug 30, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
"turn off and on again"
a few weeks ago i dropped my camera in the sea and i thought, ****. i was in the same boat, so i opened the shutter myself and turned on the camera and it works and takes pictures but the shutter wont close again so if you can make sure you have no dirt in your lense and you can manually open the shutter yourself it may work and if it stops turning on all together keep charging it and once it goes green turn the switch off and on again until it always turns green then it should work again.
Jun 22, 2008 | Samsung NV3 Digital Camera
HELP! dropped camera, lens won't go back in, shutter won't close
$100 is hardly expensive, and at that cost it would be cheaper to replace it than have it repaired. In future, keep it on the neck strap.
Mar 15, 2017 | Cameras
Panasonic Lumix  DMC-FX3 Digital Camera Logo
183 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
