Question about Dryers
My dryer does not put out any heat even though it does run through a cycle
  • 10,319 Answers
There is a heat sensor that controls the heat. Also a ignitor that lights the burner. If you do not hear the burner turn on after 30 seconds the ignitor is shot
Posted on Feb 05, 2010
My Maytag dryer, MDG4658AWW, will turn on heat for one cycle then heat never comes on again. Also, when using permanent cycle the heat cycle comes on once, dryer continues to run then shuts down (cooling...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 25, 2011 | Dryers
I have a Whirlpool Gold Senseon electric dryer that will run but does not heat. When the dryer is started it will remain in the "sensing" cycle for 9-10 minutes then jump to the cooldown cycle.
heatman101';
Sep 19, 2011 | Whirlpool LER4634J Electric Dryer
My kenmore dryer model #11069202990 is no longer putting out heat in the cycles--it's still running, just no heat at all. I am trying to obviously find the cheapest route to get it fixed. Sears was...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 05, 2011 | Kenmore Dryers
1. When you set the timer knob for the dry cycle it gets stuck and dryer keeps running. 2 The dryer turns on and runs but does not always ignite to provide heat. Heat source LP Gas.
heatman101
Jul 20, 2011 | Whirlpool Dryers
Dryer won't heat up & keeps running after cycle.
heatman101
Jul 03, 2011 | Dryers
Dryer runs but will not heat on any cycle? Is this the heating element or fuse?
heatman101
Mar 24, 2011 | Kenmore Dryers
Dryer runs but does not heat
heatman101
Nov 15, 2010 | Samsung 7.3 Cu. Ft. 9-Cycle Electric Dryer...
Was getting one heat cycle then ignitor woud glow but no call for gas. put in new cycling thermostat, thermostat boosting heater and heat sensor. I got two heat cycles before it went cold..?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Aug 08, 2010 | Amana DLG330RAW Gas Dryer
Ignitor? dryer runs through cycles, but NO heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
gfgf
Oct 16, 2009 | GE DBL333GB Gas Dryer
Dryers Logo
Top Dryers Experts
