Question about Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
Automatic chain oil leaks oil?
Automatic chain oiler leaks oil on the poulan model pp3416?
  • 2 more comments
  • de53anva Feb 05, 2010
    The populan chain saw model pp3416, not only weeps oil overnight. But after using the saw you can set it down for just a few minutes, and when you pick it back up the saw will have a puddle of oil where it has been setting.
  • dontbother10
    dontbother10 May 11, 2010
    Dime, quarter, dollar, sized pool? Do you run out of oil before you run out of fuel mix?
  • lindsay836
    lindsay836 May 11, 2010
    Pull off the chain and bar, clean all the wood chips, and oil out of the oiler hole, re-assm.
  • dontbother10
    Weeps if oil left in the tank over night?
  • 35 Answers
Possible crack in the reservoir, or line has come loose
Posted on Feb 09, 2010
Automatic oiler problem since date of purchase. Remedy?
No found recall for this. link below not your exact model, may help on repair of oiler
Chainsaw chain oiler repair
Jan 16, 2016 | Makita UC3530A 14" Electric Chain Saw
Poulan Wild Thing bar oiler adjustment
there is no adjustment for the oil flow i find the screws that hold the pump on loosen up and then leak oil
Jun 09, 2012 | Poulan Wild Thing 2375 18" Gas Chain Saw...
The automatic chain oiler does not get oil to the chain. Yes, it has chain oil. The black tube to the top chamber at the bar, seems to be plugged and I cant get it off to clean it out. Thanks, Steve
I have never seen an automatic chain oiler that worked. Even new ones don't seem to work. Just pour a little used engine oil on the bar once in awhile like everyone else does.
In theory there is a small piston that rubs on an eccentric at the chain sprocket, and that sucks in oil and pushes it through a hole, into the center groove of the bar.
But if the piston is dry, it won't pump.
If the holes are clogged with sawdust, it won't work.
Here is a video that may help:
http://www.ehow.com/video_4756894_a-chain-saw-bar-oiler.html
Mar 12, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Brand new poulan pro 4620avx--bar oil is coming out of oiler but not getting onto chain
Hello. Thin your bar oil just a wee bit with some kerosene. If you have a gallon of bar oil add 1/4 cup of kerosene, stir it up and you will be fine. For starters also, directly apply some bar oil to the chain so that you are always using a well lubed chain. Joe
Oct 03, 2010 | Poulan Pro Chain Saw 46cc 20"
I have 3 older Poulan chain saws, XXV, 1800, and 2000, essentially identical saws. They all use a check valve from the crankcase to pressurize the chain oil reservoir. The check valve apparently uses an...
These oilers are called diaphragm oilers and work fairly well when the saw is new with great compression. As the saw wears out, the compression drops and a side effect is less oil pumped. The diaphragm is replaceable and it's not horribly expensive. Most good saws use a gear oiler - and even the newer Poulans use gear oilers. The gear oilers tend to have less problems and don't rely on engine compression.
Oct 09, 2009 | Garden
It seems like the chain is not getting any oil earlier in the day the saw was fine. I had to replace the chain and started sawing on a tree and the chain just smoking and burning the wood. It does not look...
Are you using any oil in the oil resivour? The oil lubricates the chain on the bar. I would guess that you installed the chain backwards. If the chain moves freely on the bar it is getting lubrication. I have made that mistake before. check rotation and your new chain. Don't know what brand of chain saw you have, automatic oiler, manual oiler, ect. but would guess that the problem is with the chain itself. Hope it as simple as that.
Aug 23, 2009 | Poulan Garden
Craftsman 2.3 14" / Poulan 1800 auto oiler leaking
Loosten the oil filler cap before putting it away. The tank is pressurized to force oil to the chain. Relieve the pressure before storing. Lou
Jun 05, 2009 | Poulan 1630 16" Chain Saw
Poulan oiler don't work
Common problem with Poulan and Craftsman gas saws. Take off the chain and chain guide and clean out all the saw dust etc. Start saw without chain and look for port where there are signs of oil. If port is clear of sawdust, then it is likely the pump which is located behind the chain break assembly. you can get the diagram on Poulan website and the replacement pump will cost about $15 - $20 to replace yours.
May 22, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Trouble with Poulan 2150 Chain saw automatic chain oiler
Hi
It is gear driven oiler and there is not any adjusment for it.
regards savumihai71
Dec 11, 2008 | Garden
Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin Logo
398 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
