Question about Microsoft Xbox 360 Console
Xbox360 2 red ligths what can i do - Microsoft Xbox 360 Console
  • 1 more comment
  • joaorocha73 Feb 05, 2010
    the 2 ligths are one on top left, bottom left thank you
  • joaorocha73 Feb 09, 2010
    playstacion3 3 blinking red ligth please let me know wath to do dvd drive and hard drive it is ok i tested
  • joaorocha73 Feb 10, 2010
    realy helpful thank you
    Sniper:
  • 82 Answers
The two red lights on the Xbox, also known as the "red lights of death!" are a symptom of the Graphics processor unit (GPU) overheating and not making correct contact with the printed circuit board.
There are a number of guides on the Internet that suggest they can fix the issue; however in practice what is normally required is hwat is termed 'reballing'. In this process the GPU is desoldered from the PCB using specialist equipment and then resoldered. This uses specialist equipment and can not be attempted with a normal soldering iron.
The best course of action is to initially contact Microsoft to determine if it would be covered under their extended warranty programme. The following URL refers to the 3 red lights, but I would check anyway http://support.xbox.com/support/en/us/nxe/kb.aspx?ID=969905&lcid=1033&category=hardware
Failing that, there are a number of people that offer xbox repair services, not knowing exactly where you are located I can't point you at one in particular. I would google "xbox repair <location>" and check that the company is reputable. If you can physically take the 360 into the company that is even better.
Hope this helps
Posted on Feb 09, 2010
  • 434 Answers
Two red lights mean the CPU is overheating. Make sure the fans are running in the back of the XBOX when it is on. If they are running, make sure the box is in an open space where it can get plenty of air flow. If these do not fix the problem, you have one of many junk boxes. You can send it back to microsoft to be repaired. Here is the like for microsoft xbox repair, http://support.xbox.com/support/en/us/nxe/registerdevice.aspx?step=repairhttp://support.xbox.com/support/en/us/nxe/registerdevice.aspx?step=repair
Posted on Feb 06, 2010
  • 360 Answers
You have a total of 4 lights, which ones are lit up tell you what the problem is.
There are only a very few 360 red light problems that can be fixed by you, you generally have to send the unit in to Microsoft to have it repaired. About a year ago, Microsoft extended the warranty period of their 360's for red light issues...so there is a high possibility you are still covered.
If you comment on what exact lights are lighting up and their behavior (blinking/steady), I can help point you in a more specific direction to troubleshooting it. You can also contact Microsoft with that same info and they help you troubleshoot also.
Hope this helps.
Posted on Feb 05, 2010
My truck stop running with out any red ligth no chech engine ligth no codes at allt it is like its sucking air intead of diesel
Check fuel level in tank, check filter housing is not sucking air, check all fuel lines for leaks...
Check operation of lift pump...
Feb 12, 2016 | Cars & Trucks
DL 160 red ligth alarm hard disc
You could try re-seating the hard drive to see if comes back. Note most configurations on this is set to RAID 1 or 5. Double check before removing drive.
The drive will need to be replaced if the red light comes back (after a few days).
Jan 31, 2013 | HP Computers & Internet
Green ligth comes on and then gose off, proceed by red ligth flashing.
Hi:
If you count the number of times the red light blinks before pausing and starts to cycle over again. This is the error code the unit is producing. Also if its been a while since you replaced the lamp then it may be time for a new one. Check the lamp housing and pull out the lamp it may be shattered. You can find the lamp area and installing instructions using you onwers manual.
Nov 10, 2010 | Sony KDS-50A2000 50" HDTV
My car has a small red ligth in side panel by the estering well that is flashing and make a sownd like a emergenci ligths on
probably part of a antitheft system,talk to previous owner or disable it.
TIM...................
Oct 21, 2010 | 1993 Dodge Intrepid
Warning red ligth
you can have the vehicle check for code with a hand held device then you will know what sensor cause the light to come on.
after you make the necessary fix you can erase the code then the light will turn off
Mar 03, 2010 | Mitsubishi Cars & Trucks
Nintendo charges but doesn't turn on and both screens are ok
whats happening when you connect to a charger? if red ligth flashes that mean you have a blown fuse , if its solid red ligth that mean had a water damage or droppend , you will need to open up and put the loose part on the sopt , usually L1 next to power switch , REgards
Dec 08, 2009 | Nintendo DS Lite Console
Flashing ligth
Usually means the battery is not seated correctly or is not charging.
Jan 18, 2009 | Dell Inspiron 5100 Laptop
Red crt tube
IT IS PROBABLY TIME TO CHANGE IT OR THE LIGTH DIFFUSER THAT SENDS THE LIGTH TO THE TUBES OR LAMPS IS MALFUNCTIONING
Oct 01, 2008 | Philips 60PP9202 60" Rear Projection...
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
