Question about JVC Everio GZ-MG21 Camcorder
EverioGZ-MG330 Notes on Instruction Manual p25 read "Never disconnect the USB cable while the access/charge lamp on the camera lights or blinks", and "Do not turn off the camera when the USB cable is connected, to prevent malfunctions of the PC". When do I disconnect the USB cable then? RPalou@aol.com
    Guru:
  • 377 Answers
Hi dear
it, suggest for us for not do it,
but if it happened just power off your camcorder , an power on again
oke, don't to worry about that
cropp
Posted on Mar 18, 2008
Why is red light blinking
The red lamp you are referring to is called the Access Lamp. This lamp usually illuminates if the camera is reading or writing information to the memory card. If this is blinking erratically, this could indicate an issue with the memory card. It is recommended that you try using another memory card with the camera to isolate the issue
Jan 20, 2015 | Cameras
Access lamp is blinking.
What is your cards Class(you can read it on the card) If it is less than 6 you better change it to 10
May 31, 2014 | Canon EOS 600D Rebel T3i Digital Camera
How to connect Hitachi camcoder with laptop
Connecting to PC via PC Connection Cable
Use the provided PC connection cable to connect the DVD video camera/recorder to PC as shown in the last.
Note:
• No data can be written to the HDD, disc or SD memory card in this DVD video camera/recorder when it is connected to PC.
• The PC connection cable does not supply power to the DVD video camera/recorder: Use the AC adapter/charger
to power the DVD video camera/recorder.
• Before connecting the DVD video camera/recorder to PC, disconnect any cables or camera accessories (external
video flash, external microphone, etc.) other than the PC connection cable and AC adapter/charger.
• When connecting the DVD video camera/recorder to PC, the ACCESS/PC indicator will light green. While HDD or
a disc is being accessed, the indicator will light or blink orange. While an SD memory card is being accessed, the
CARD ACCESS indicator will light or blink red.
If you connect the DVD video camera/recorder to PC via PC connection cable, the PC will automatically recognise the DVD video camera/recorder. After recognition is finished, it may be
prompted to restart the PC: In this case, follow the instruction and restart the PC.
Mar 11, 2012 | Hitachi Video Cameras
It won't start up. We put it to the charger and the green light blinks. Is it charging?
Welcome to FixYa.
If the charge lamp blinks slowly (green)
-battery is charging.
If the light is off
- battery is not charging.
- Also whe charging is complete, the charge lamp stops blinking and turns off.
If the charge lamp flikers (green)
- the ambient temperature is not suited to charging. Cganhe the battery indoors with an ambient temperature of 5C to 35C (41F to 95F)
- The USB cable or charging AC adapter is not properly connected, or there is a problem with the battery. Disconnect the USB cable or unplug the Charging C adapter and correctly connect it again, or chage the battery.
Please let me know if you have any questions and if this solution was helpful.
Thank you for using FixYa.
Apr 12, 2011 | Nikon COOLPIX S8000 Digital Camera
Where can I get an instruction manual for a GZ-MG330 jvc camcorder
http://books.jvc.com/booklist.asp?Model=GZ-MG330
Feb 06, 2011 | Cameras
Is there any way to download the set-up disk for my jvc gz-hd7u
Connecting the Camera to the PC
Preparation:
Set the camera’s power/mode switch to OFF.
NOTES
• When the USB cable is connected, turning on or off the camera causes malfunctions of the PC.
• Connect the camera directly to the PC, not through the hub.
• Do not use an extension USB cable.
• Saving the wrong kinds of files in a recording medium or deleting files or folders from a recording medium can cause problems with the operation of the camera. When it is necessary to delete a file from a recording medium, delete it through the camera. Also, do not move or rename folders and files in the medium on PC.
• Never disconnect the USB cable while the access/charge lamp on the camera lights or blinks.
1 Create a folder to back up files into.
2 Set the camera’s power/mode switch to STANDBY/ON.
3 On the camera, move the set lever to
\/ / /\ to select [PLAYBACK ON PC],
then press down.
4 Double-click [EVERIO_HDD] or [EVERIO_SD].
5 Select the folder that you want to back up, and drag & drop it into the folder you created in step 1.
SD_VIDEO:
Folder that contains video files. If you want to back up fi les individually, open this folder, and drag & drop folders such as [PRG001] one by one.
DCIM:
Folder that contains still image fi les. If you want to back up fi les individually, open this folder, and drag & drop files such as [PIC_0001.JPG] one by one.
When you have finished operation
Always follow the procedures below when disconnecting the camera, or turning off the camera/computer power.
Failing to do so may cause damage to the camera and computer.
1) Confirm that the access/charge lamp on the camera does not light or blink. (If the access/charge lamp lights or blinks, wait until it is turned off before proceeding.)
2) Double-click the [Safely Remove Hardware] or [Unplug or Eject Hardware] icon in the status bar.
3) Select [USB Mass Storage Device] or
[USB Disk], and then click [Stop].
4) Click [OK].
5) Disconnect the USB cable.
6) Turn off the camera and PC.
Sep 20, 2009 | JVC Everio GZ-HD7 Camcorder
Camera will not charge, should i be plugged in to the usb slot
please use youre usb and try again..that is the only way I charge mine
Oct 11, 2008 | Jazz DV-179 Digital Camera
JVC EVERIO gz-mg330 does not appear as drive
Another solution is to make sure you are using the usb cable that came with the camera. For some reason, if I use any other, the computer won't recognize the camera. It's the one with the magnet. In fact, mine has two magnets on it.
Jul 07, 2008 | JVC Everio GZ-MG30 Camcorder
Nikon Coolpix S2 green lamp
Check the PDF manual on the software disk to be sure Nikon Technical Support for confirmation- this is a possible replacement situation
Feb 16, 2007 | Nikon CoolPix S2 Digital Camera
JVC Everio GZ-MG21 Camcorder Logo
169 people viewed this question
Top JVC Video Cameras Experts
Steven Wander
Steven Wander
Marvin
Marvin
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
