Question about Air Tools & Compressors
I have a kaeser sx6 the wires are pulled out of the control panel
2 Suggested Answers
emissionwiz
  • 76649 Answers
SOURCE: Kaeser, SX6-150 circuit diagram
You may have this posted in the wrong product category. Please select another category appropriate to the problem and re-post the problem so the correct expert will see and respond to the question..
This is for car and truck problems related to factory installed systems not add on aftermarket systems.
This post can't be removed or moved, please re-post the question in the correct product category. Thanks
Posted on Oct 30, 2012
Oven keeps blowing thermal fuse
  • Disconnect the oven's power supply by turning off the breaker in your home's service panel.
  • 2 Open the lower oven door. Remove the screw at the bottom of the trip panel on each side of the oven.
  • 3 Pull the trim away from the oven approximately 2 inches, then slide the trim panel down to remove it from the oven.
  • 4 Remove the screws from the bottom sides of the control panel.
  • 5 Pull the control panel out from the bottom, then lift the panel to remove it from the front of the oven.
  • 6 Detach the wire connectors from the control panel by depressing the tab on each connector and removing it from the control panel.
  • 7 Depress the tabs on the thermal fuse wire connectors, then remove the thermal fuse.
  • 8 Attach the wire connectors to the new thermal fuse to install it in the control panel.
  • 9 Reassemble the oven by reversing the steps used to take it apart.
  • 10 Restore power to the oven.
Jan 21, 2014 | managemylife.com
I cant reset my service hours on my kaeser compressor
at service hours press and hold enter then password will be basic
Jan 16, 2014 | Cars & Trucks
Jandy RS 6 panel not working. After pressing reset button, all lights on panel come on and there is no effect from press panel buttons. panel reads "Rev 6700 C." Have pulled out red 4-wire panel...
check wire going from 4 pin to controller see if by 4 pins wires touching or try controller with short wire by system wire sounds like shorted sometimes cut by landscapers
Mar 30, 2013 | Jandy AquaLink RS2/6 All Button Dual...
Oct 30, 2012 | Cars & Trucks
Lint light ix on and wont start
Not sure if this will address the problem but it maybe worth a try. We also had problems with our dryer starting but the lint indicator was not on. We found the problem was with the start/stop button; it was not making contact with the mini-switch. Used some hot glue under the lever that makes contact with the mini-switch. Put it back together and works great again. Saved about $260 on new control panel. Removing the control panel was pretty easy for a DIYer.
Unplug the dryer.
Remove the four screws that hold the panel in place. They will be hidden under caps on the housing, Pull off the panel. Be careful because the wires will prevent you from pulling it entirely off but you can pull it from the right corner up and flip it on its back side to expose the back of the panel.
The white wire guard will have to be removed. The wire ties holding the wires to the guard will have to be removed by cutting the ties. Replacement wires ties can be purchased at any home improvement store. Remove the control panel by pushing the plastic clips in that hold it to the housing. There should be 6 and two plastic clips on the right center of the panel. If done right it will easily pull off. If force is needed one or more of the clips have not been disengaged. Do not force it because it is made of plastic and will break.
Once the control panel is removed from its housing, the start/stop button can be identified-last one either on the right or left (can
Nov 14, 2010 | Bosch Nexxt WTMC 3300 Electric Dryer
How to replace door gasket for GE WCVH6800J0mr
The front panel needs to be removed in order to replace the door gasket. This requires the removal of the top panel, control panel, service panel. Disconnect power to the machine before attempting any repair works.
Remove the 3 Phillips-head screws that attach the top cover then pull the cover rearward. It may be helpful to place a putty knife along the top seam between the cover and control panel then lightly tap it rearward. Remove the 3 hex-head screws that attach the rear of the top panel to the cabinet then slide the top panel rearward and lift the panel.
Remove the 3 Phillips-head screws that hold the service panel to the cabinet then pull the service panel down and off the cabinet.
Pull the dispenser out to the stop position then press down on the locking tab.
Pull the dispenser out completely then remove the single Phillips-head screw from the control panel dispenser recess.
Remove the 4 Phillips-head screws that attach the top of the control panel to the control panel cover.
Lift and push forward on the control panel from inside the cabinet to release the bottom tab from the front bracket.
Lift the top edge of the panel to disengage the 3 tabs that hold the top of the panel in place.
Push the control panel towards the left then release the side tab. Disconnect the wire harnesses from the control panel then set the panel aside. It is recommended to take note of the connections before disconnecting to prevent messing them up upon reconnection.
Open the door then remove the 3 Phillips-head screws that hold the door lock to the front panel and remove the spring and wire from the gasket.
Use a pair of long-nose pliers to grasp the wire hoop at the spring location and expand it to clear the door gasket and remove the spring and wire hoop.
Peel the door gasket off the outer lip of the front panel door opening then position it behind the front panel. Close the door and remove the 4 Phillips-head screws that attach the front panel to the cabinet. Lift up then remove the front panel from the hooks.
Once the front panel is off, pull down and disengage the gasket from the nozzle.
Ensure that the washer is placed on the outside and that the nozzle is aligned with the indent on the inside of the gasket when reinstalling.
Disengage the gasket from the water inlet pipe and loosen the 7-mm bolt that holds the wire and bolt assembly to the outer tub lip. Remove the wire and bolt assembly from the gasket then pull the gasket off the outer tub lip.
Install the tub gasket on the outer tub aligning the notch in the gasket with the arrow located on the top of the outer tub lip before tightening the wire and bolt assembly.
When reinstalling the wire and bolt, tighten it to a gap of approximately 11/4 inches. Do not over-tighten it to avoid tearing up the gasket.
Position the door gasket inside the drum then secure the front panel back into the cabinet. Put the door gasket over the outer lip of the front panel door opening then secure it with the spring and wire hoop assembly. Start at the top then work around the gasket on both sides simultaneously until the gasket is completely secured.
Reinstall the service panel, control panel, and the top panel to complete the procedure.
Aug 23, 2010 | GE Energy Star WCVH6260F Front Load Washer
How do you change the element on a kaeser in line air filter model KPF250
relief all pressure and push up and turn to left might have to use pliers to turn if it has not been changed in a while
Jun 22, 2009 | Air Tools & Compressors
My phone Airtel Telular sx6 1D02A047
sir,
i m other company sim insert but is not working
how to unlock my Phone
imei no:- 354577000681766
Mar 01, 2009 | Cell Phones
Air Tools & Compressors Logo
222 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
