Question about Dryers
LOUD squeaking noise from rear of dryer; started when husband washed and dried a pack of gum.
  • Dryers Master
  • 8,220 Answers
Most squeaks com from worn parts.
I have repair photos: HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Feb 05, 2010
GE 5 Cycle Automatic Heavy Duty Extra Large loud noise
All ge dryers have a center bearing on the back side of the drum and drum glides on the frontside. The glides make a scrubbing sound when bad and the drum is hard to turn. The rear bearing does a squeak thang when the plastic bearing wears thin and begins to make metal to metal contact between drum mount and rear bulkhead mount. It is an easy fix but the drum gotta come out. here is my pictorial page that shows how with videos and repair pix:
Paw Paws GE dryer repair page
http://appliancejunk.blogspot.com/2011/09/late-model-hotpoint-dryer.html
http://appliancejunk.blogspot.com/2011/08/hotpoint-dryer-eating-clothes.html
Jan 09, 2013 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
I get a loud knocking sound on each revolution of the drum during the drying cycle (not caused by the load)
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Mar 07, 2011 | Washing Machines
Dryer squeaks
the rollers or belt idler may be corroded, use mineral oil or special bearing lubricant. DO NOT USE WD-40 OR 3 IN ONE OILS. you may find that they may need replacement.
Feb 09, 2011 | Frigidaire FEX831CS Top Load Stacked...
My dryer has developed a loud squeak when it is drying. Some times it is quiet but other times it is very loud. How what is causing this issue?
heatman101
Asker
Nov 30, 2010 | Fisher and Paykel DE09 Dryer
Maytag Neptune Dryer makes loud noise while drying.
heatman101
ergfgfjk
Sep 06, 2009 | LG DLE2514 Electric Dryer
Loud Squeaking noise when drying clothes
Might be the issue with the rotor bearings.
2.Might be there is some dust or other thing in rotor drum so please check and clean.
Aug 11, 2009 | GE DBSR453EBWW Electric Dryer
GE Clothes dryer squeaks
My ge electricryer sqeaks very loud and makes a thumping noise. it just started a cuouple of weeks ago.
Jun 19, 2009 | GE DWXR483EBCC Electric Dryer
Hotpoint WD 865- washes ok, dryer won't work makes loud popping
sounds like the dryer heater element has worked loose perhaps and shorted out against the metal dryer box which sits on top of the drum.
best to get an engineer out i'd say.
Jan 14, 2009 | Hotpoint Aquarius WD63 Front Load...
Whirlpool Imperial Dryer Model #LAE8800A0
these bearings are dry plastic pads if i am, correct, these can be lubricated very slightly with a little silicone grease where they are rubbing on when the drum rotates
if you cant use silicone grease, more or less any will do that is thick and doesn't smell, only use a very small amount so it doesn't go on the clothes
a very small amount is enough to stop the pad being dry but not enough to see? almost like wipe it on then wipe it off,
also lubricate the the pulley wheel on the belt tensioner (the little small wheel at the bottom if it has one
Oct 13, 2007 | Dryers
Dryers Logo
63 people viewed this question
Top Dryers Experts
