Question about Dryers
Drywe drum will not turn. I found a wheel assembly laying on the bottom, and the belt is off. How do I access the area to try and reattatch the wheel and belt?
  • MIKE major May 11, 2010
    what make and where is the lint filter located?
  • laddwade May 11, 2010
    in order to give you the most accurate advice you will need to provide a little more info on the dryer, such as make and model number.
    Genius:
  • 1,122 Answers
That is the belt pulley,it goes into the groves right in front of the dryer motor,the belt goes under it and onto the motor-mike
Posted on Feb 05, 2010
Replace belt genesis upright
Turn vacuum upside down on flat surface, remove the 6-7 screws from the bottom of the power nozzle, lay it on it's side and pry on the two accessible internal tabs to pop top cap of the nozzle off to access the pn motor assembly. Lay flat on it's back again and remove the screws that hold the roller brush in, remove the roller brush, remove old belt, install new belt on brush roll and pn motor geared spindle, push brush roll back in place, replace screws and pn top and VOILA!..you're back in bidness! Hop that helps!
Jun 25, 2014 | Electrolux Vacuums
I have a Maytag front load Mod. # MFW9600SQ1 and It is making a grinding sound when the drum is rotating. I took off the back and belt to see if it was the motor but it is still making the sound. Is...
Is it making the noise with the belt removed ?? If so it is the pump has an obstruction in it most likely. As for the bearing it is not an easy job . The whole drum assembly must be removed from the case and separated.
Dec 07, 2010 | Maytag EPIC MFW9600S
We had a new serpentine belt replaced a couple of months ago and it just came off. How can I put it back on? Also the lug nuts seem to be stripped.
Click on the following free direct Link. It has the Serpentine Belt Diagram and Tensioner location for your 2000 Saturn SL.
http://www.2carpros.com/car_repair_information/year/2000/make/saturn/model/sl/2000_saturn_sl_drive_belt_routing_diagram.htm
Before we get to putting it the Belt back on...
Look at the alignment of the Pulleys. Most times the Tensioner or Idle Pulley are "canted" - meaning pitched or leaning forward, which causes the belt to "run off" the pulley - throwing the belt.
With the Belt off: check side-to side play for each one of the Pulleys by hand, especially for the Tensioner and Idle Pulleys. There should not be any side-to side play. If there is any other Pulleys that are canted - check if they are properly tightened. A new belt should not have come off on it's own without some other problem.
GENERAL/Standard Rules to Removal the Serpentine Belt with a Tensioner:
A. Find the Tensioner(s). (See Diagrams on Link)
B. Using a Serpentine Belt Tensioner Tool, Or Wrench OR Ratchet, Rotate/Move the Tensioner USING THE AVAILABLE NUT (on the Pulley or Arm Base) OR the OPENING (3/8ths or 1/2 inch square opening) rotating the Tensioner Pulley/Arm - moving it away from contact with the belt and towards the area where the belt is not in contact with the Tensioner Pulley. The Tensioner is spring loaded, and is hard to rotate/move.
C. Remove the loosened belt off one of the other more easily accessed Pulleys.
D. DO NOT quickly release the Tensioner, but gently allow the Tensioner to rest in its closed position.
Standard Rules for Installing the Serpentine Belt with Tensioners:
a. Pick a Pulley that is most easily accessed. This will usually be on top. This will be the last Pulley that the belt will go on.
b. Using the Diagram: Install the new Serpentine Belt on the remainder of the Pulleys....over, under, left right.
c. Using a Serpentine Belt Tensioner Tool or Wrench or Ratchet Tool: Rotate/Move the Tensioner Pulley/Arm "away" from Belt contact area on the Tensioner. This spring is pretty hard and with a new belt, it will be even harder to install. Rotate/Move this to as-close to the maximum allowed inorder to have enough slack in the belt to get it up and over the last pulley.
d. Using your other hand - Pull the Belt up and over the Last remaining Pulley.
e. Before releasing the pressure on the Tensioner, visually inspect the remainder Pulleys and the Belts' Positioning on them.
Regarding the Strip Lug -Studs.
Is this on the wheels with Rotors (Disc) or Drums? If the tire was not properly mounted, or the Lug Nuts were not properly Torqued; this will cause the Lug Studs (bolts) to be stripped.
With the vehicle raised and properly supported by jack stands:
For Rotors:
Remove the Tire, Brakes (Calipers/Pads) and Rotor, exposing the Wheel Hub (Bearing) Assembly with the Studs fully exposed. Rotate the Wheel Hub to a location where the Lug Studs can be clearly removed FROM THE REAR OF THE WHEEL HUB ASSEMBLY.
Using a impact hammer or mini sledge hammer: Hammer the Lug Studs back thru the Wheel Hub Assembly.
Remove the loosened Lug Studs.
For Drums:
Raise, support, remove the Tires.
Remove the Drums off the Wheel Assembly.
Using a impact hammer or mini sledge hammer: Hammer the Lugs back into the drum, removing from inside the Drum
Purchase the new, correct size and length Lug Studs and new Lug Nuts. If the Studs were stripped, most like the Nuts are too.
To reinstall the Lug Studs: Purchase an additional two (2) Lug Nut that fits that Lug Stud. Also purchase several Large Heavy Duty Washers that can fit on the the Lug Studs.
Place the Lug Stud back into the Wheel Assembly from the Rear (Rotors) or from inside (Drums). Use High Temp Grease for the area of the Lug Stud Splines that have to be "drawn" into the Wheel Assembly (with Rotors) or into the Drum.
After the Lug Studs are "IN" as far as they will go: on the outside place at least two (2) of the Washers on Lug Studs. Use a Lug Nut and tighten as far as possible down-on the Lug Stud as possible.
Next: Using an Impact Wrench tighten that Lug Nut down/on, drawing the Lug Stud into the Wheel Assembly/Drum. Check the rear of/inside the Wheel Hub Assembly/Drum. The Heads of the Lug Studs should be firmly against the Wheel Assembly/Drum.
If you do not have a Impact Wrench - use at least a 24-in Breaker Bar and Tighten the Lug Nut on, drawing the Lug Stud into the Wheel Hub Assembly/Drum. This takes longer and alot more work, compared to 10-seconds using the Impact Wrench.
Repeat as necessary.
Let me know if this helped, or if you have additional information or questions. Feel Free to contact me at FixYa.Com!
Mar 31, 2010 | 2000 Saturn SL
How to put a belt on a Maytag DE 410 dryer
with some you have to remove the front upper and bottom panel
then lift drum off bogie wheels and move it ahead a few inches then loop it over the drum and around the belt tensioner pulley most swing up and down so thatyou can put belt on
Dec 18, 2009 | Dryers
Changing a dryer belt on a Maytag DE410
in some models you do it from the front the drum sits on 2 bogie wheels and the belt sits behind ,lift drum off bogie wheels and thread belt around pulley it should be on a spring tensioner and it allows you to swing pulley up or down try to thread belt around drum and replace drum back on bogie wheels.... in some dryers you may need to thread belt on drum and then onto pulley good luck
How do you disassemble a GE harmony dryer
remove rear pannel and the motor is right there remove drum to acess the motor
remember to lay the dryer on an angle or even flat on it's face if you can to re insert the drum assembly and dont forget the belt
Jul 29, 2009 | GE Profile Harmony DPGT750EC Electric...
Left hand drum brake won't realece
make sure the parking brake is not on if not you can turn the star wheel adjuster on the bottom of the assembly to reduce the diameter of the assembly
Jun 20, 2009 | 2000 Chevrolet Cavalier
Frigidaire FER211AS2 dryer drum belt
the washer has to be tipped forward. can access from bottom (and back).
Jun 03, 2009 | Frigidaire FER211A Electric Dryer
Can't Put Belt On
You have to remove the front of the dryer to
access the drum. First unplug the dryer.There are screws at the bottom of the front to remove the lower section. Once you remove that you can get to the screws for the door section. The front of the drum rides on the inside of the front panel so when you remove the panel the drum will drop down. Try to keep the drum in place with something to hold it up. Remove the old belt and place the new belt around the drum. Slid the belt back to where the belt used to ride and then loop the belt around the motor and the tension wheel. Make sure the tension wheel is tightening the belt. Hold up the drum and put the front panel back on. You may need a helper to hold things while you do this. Rotate the drum by hand and make sure it moves smoothly. Plug it back in and give it a try. I hope this helps. Any questions feel free to ask. Please rate me so I know if I'm Helping. Thanks.
Dec 30, 2008 | Frigidaire FEQ1442ES Electric Dryer
Dryers Logo
Top Dryers Experts
