Question about Polaris New Genuine Polaris Snowmobile Accessories / X Treme Sidecut / Out of Bound
96 Xlt Polaris Blew two pistons on pto side
I changed all seal / gaskets after 1st blow up . blew again . now afte 1 mile seems its gonna blow again. plug looks dry and its running hoter.
  • 39 Answers
I would richen the sled up one or two jet sizes.
Posted on Feb 22, 2010
PTO Issues
replace the pto solenoid as it has an internal short causing the fuses to blow.
Jun 02, 2013 | John Deere Garden
A friend asked my to look at his bike. He blew it up and replaced piston... ran for 5 weeks and blew again. Got another piston and ring and it had NO compression . Long story short.. I ordered a NEW...
Hi,,ok that is a lot of wasted money spent,,the power valve plays little role in compression,,the FIRST thing to do is remove the flywheel and check the crank seal,,the compression has to be going somewhere,,,and the stator side crank seal is almost allways to blame(blows engines real fast,,sucks air,motor runs lean and bang!)
good luck
Mar 28, 2011 | 2003 Suzuki RM 125
2004 600 twin sportsman over heating even when fan is on antifreeze shoots out the top of the resivor, new cap 13lb,could it be the pump ? does not leak from weep hole? top hose hot bottom cold.rad flows...
i had my 400 liquid sport blow a compression ring on the head gasket and it shot coolant out of the resivor because i was pressureizing the cooling system with the piston compression tho not a four stroke but it sounds like a head gasket. fan running on battery i made it 25 miles in upper penn of michigna befor i blew it completely and warped the head (white smoke) and the whole time it was shooting cooling out of the over flow cap pulled the head off milled it new head gasket and it was fine
Jan 13, 2011 | Polaris ATV
Pol xlt running lean on pto side. I changed all
I would jet the lean side up one jet size if the sled is running extremely lean. You can also adjust the needle up if you can without having to increase jet sizes.
Feb 05, 2010 | Polaris New Genuine Polaris Snowmobile...
My polaris Predator 500 2005. it blew a rubber valve cover gasket looking thing.OIL literaly blew 15ft and sprayed EVERYTHING in my garage. wondering what could have caused this before i tear it down....
if its a valve cover gasket that blew like that you could have major problems
Could be that it leaned aout and burnt up a cylnder or a piston, and you have major blow by now.
Jan 12, 2010 | Polaris ATV
97 mustang overheating and blowing cold air
Get a compression check to find out if you have a bad head gasket, I have a 96 with the 3.8L that had the same problems at first. then it started to blow out antifreeze thru the expansion tank, the head gasket finally blew the rest of the way going down the highway
Dec 04, 2009 | 1997 Ford Mustang Cobra
My 316 bmw se has water everywhere!!!
Sounds like a head gasket or a crack in the head/block. Try some block seal from the local parts store, sometimes it works well.
Sep 07, 2009 | 1997 BMW 318
96, polaris 600 xlt # 3 no fire
The problem was contaminated pump/fuel. Disassembled carbs and pump, inspected and cleaned, engine runs like new. Thank you
Feb 19, 2009 | Polaris New Genuine Polaris Snowmobile...
Blowing black smoke on acceleration 2.5 exceed turbo intercooler I have a Mitsubishi 2.5 diesel with what sounds to be a similar problem except it happens when you rev the engine suddenly but stops...
1 Inspect Piston Ring Set Worn or broken piston rings. grey_line.gif 2 Inspect Valve Stem Seal Cracked or brittle valve stem seals allowing oil to enter combustion chamber. grey_line.gif 3 Inspect Head Gasket - Performance Head gasket leaking coolant into cylinders grey_line.gif 4 Inspect Fuel Injector Rich injector grey_line.gif 5 Inspect PCV Valve Plugged or damaged pcv valve. grey_line.gif 6 Inspect Engine Worn or scored cylinder block grey_line.gif 7 Inspect Piston Worn or damaged piston. grey_line.gif 8 Inspect Valve Guide Worn valve guides
Nov 26, 2008 | 2001 Mitsubishi Montero Sport 4WD
Polaris New Genuine Polaris Snowmobile Accessories / X Treme Sidecut / Out of Bound Logo
218 people viewed this question
Top Polaris Winter Sports Experts
Larry Fostano
Larry Fostano
toddgilbert
toddgilbert
Are you a Polaris Winter Sport Expert? Answer questions, earn points and help others
