Question about Sanyo Televison & Video
Tv wont come on and is making a clicking noice with out touching it
  • Sanyo Master
  • 19,396 Answers
The TV protection circuit had started. This happens when an internal fault had been detected.
The clicking noise that you hear is the protection switch preventing the TV from starting.
All you can do is checking all connections, and try leaving the TV disconnected from power for about fifteen minutes.
If that does not fix the problem, then there is an internal fault.
In that case contact manufacturer at the number listed on the manual.
You can follow the instructions on this article: Why my TV does not start up and remains in...
Posted on Feb 05, 2010
Daewoo tv wont turn
There is short circuited component/s at its main board. Your TV need a through check up. Contact any service technician. If you wish to get some details; check the site linked here.Viewing it in "Mosaic" will make surf easy.
Feb 13, 2014 | Televison & Video
Wont boot and clicking noice
A clicking noise usually indicates a bad hard drive. Any eMachine is now very old (in computer years), with an obsolete operating system.
You should consider replacing rather than repairing.
Jan 09, 2013 | E-Machines eMachines Desktop PC
Went to start my 05 road king and all i get is a clicking noice
Hi Anonymous, first when checking anything in the starter circuit you must make sure the battery connections are clean and tight especially the negative cable at both ends and has a 12.5 volt or better charge. It must not fall below 9 volts during the cranking procedure with a volt meter hooked up. If it does fall below 9 volts do a proper load test on the battery and replace if necessary. Second replace the starter relay cheap $6 and make sure it's well grounded and getting 11.5 volts or better to activate. Third remove the back cover of the starter solenoid and de-arc/refurbish the contact plate and shoes making sure they are tight. If it still chatters replace the solenoid. Good luck and have nice day.
Nov 21, 2012 | Harley Davidson FLHR - FLHRI Road King...
My tv keeps making a loud clicking noice
Does the set just click on and then right back off? Do you have Flashing power Light on Front or is TV playing with Loud Clicking?
Oct 07, 2012 | Sony SELECT KDF-E50A12U Rear Projection...
I plugged for the first time my laptop on to the VGA input tv screen showed a sign that read something like: no signal, tv will turn off. then it switched off and now it wont turn on on the on/off switch...
There is a button on your laptop for switching from laptop screen to external screen, This button is usually in the top row of special function buttons, did you press that as it will tell your computer you are connected to another monitor. Also some times you have to leave the monitor off for about 5 minutes so it will reset itself.
Oct 09, 2009 | Televison & Video
POLAROID TLA 04641C AFTER VGA PLUG TV WON'T WORK
i am having the same problem.. did u ever got it fixed?
May 10, 2009 | Panasonic Televison & Video
New Clutch, New Noise!
throw out baring was inproperly installed
Mar 30, 2009 | 1998 Ford Escort
Noices
there are two fans the heatsink fan and an extractor fan, either of theses can be replaced, you buy the heatsink and fan together for the processor and a seperate case fan can be fitted easily by yourself
Nov 06, 2007 | HP Compaq Presario SR2150NX PC Desktop
Infitek digital music player
dropped new player and it wont stop making noices. what can I do?
thanks
646 232 7396
Oct 21, 2007 | iLO (2 GB) MP3 Player
Televison & Video Logo
22 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
