Question about Whirlpool Duet GHW9150P Front Load Washer
Tub appears loose in the front next to door. washer makes loud noise in spin cycle like a helicopter.
  • 572 Answers
You might need a new tub. could be your bearing that is broken
Posted on Feb 05, 2010
Frigidaire front loading washer has loud spin cycle, Why?
That's a great question, Roth!
Based off the information you have provided your Frigidaire washer is making a loud noise during the spin cycle. This could be an issue with your bel, motor, or tub. In order to find the cause of your noise you may need to disassemble your washer. This is not a simple DIY job and I would recommend contacting a technician to come out. This will help prevent any future issues or personal injuries. -Matt
Mar 11, 2015 | Frigidaire GLTF2940ES Front Load Washer
My Whirlpool Estate topload washer agitator will not spin in spin cycle & makes grinding noise
No spin, try these:
Using a multi meter check for continuity the door switch, which when bad may not allow agitation or spin. The lid switch assembly can fail either mechanically or electrically.
Check the clutch, brake assembly and transmission, one way to check for slipping is to get under the machine after a spin cycle ( this is if u get a lil spin but not much leaving clothes still wet) mix in a spray bottle a lil water and some dish detergent, then spray it on the clutch assembly ( the metal round pc. Connected to the tranny) if it sizzles and steams up then u know its bad and slipping. Another way to check clutch if u get no spin at all? Is to take it out and use ur hand to try and turn the inner spring assembly pushing it around the inside? If its very easy, it BAD should be hard to push by hand.
Next check the motor coupler which engages the tub and tranny to the motor. ( if its bad u usually get no wash or spin or very little of either)
Next check for a loose, worn or broken belt if belt driven.
On some front load models u may need to check the STATOR assembly.
The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
LOT OF THINGS TO CHECK, THE BELT LOOSE OR WORN, THE CLUTCH, THE TRANNY, THE BEARINGS BOTH TUB SEAL AND BEARING, THE REAR DRUM BEARING, the balance or counter weights.
THE DRIVE PULLEY- If the washer is making a loud noise the drive pulley might be worn out, cracked, loose or bent. Remove the drive pulley and inspect it carefully. If it is damaged or defective replace it.
THE TRANSMISSION, THE MOTOR COUPLER, THE MOTOR DRIVE BEARINGS,
THE DRIVE MOTOR- If the washer is making a loud noise the drive motor bearings may have worn out. Washer motors are normally almost silent when they run. If the motor is run without a belt hooked up to it and it's loud it will have to be replaced.
Jul 09, 2014 | Whirlpool Washing Machines
During spin cycle loud clunking noise
LOUD NOISES IN washing MACHINE;
The drive coupling connects the motor to the transmission and consists of two plastic drive forks with a rubber coupling between them. One of the drive forks is attached to the drive motor shaft and the other is attached to the transmission input shaft. As the motor shaft rotates, the rubber coupling between the drive forks absorbs the torque to prevent the forks from breaking. Normal use will create wear on the coupling and eventually the drive forks may slip and cause a vibrating noise. If the transmission seizes or if the spin basket cannot turn freely, then the coupling may fail and again you may experience a vibrating noise. Most models will require you to remove the cabinet to access the drive coupler. Disconnect power from the appliance before attempting any repairs.
If the washer is making a loud noise the drain pump might be going bad or might have something caught in it. Remove the drain pump from the washer and inspect it carefully. Look for anything that might be caught in it, a piece of wire, plastic, etc. If nothing is wrong with the pump, but it's still noisy it will have to be replaced.
Front load washers often use a self contained electric drain pump and the motor may be worn or damaged and require the complete pump to be replaced. Remove any foreign objects or replace the worn or damaged pump, thencarefully tighten the hose clamps and check for leaks before installing the cabinet or front panel.
All front-load washing machines have shock absorbers that are used to dampen the tub movement in the spin cycle. The shock absorbers or struts are attached to the base frame and to the outer tub and you will need to remove the front panel or the rear panel to access them. When shock absorbers weaken or become damaged, the machine will often make a loud banging sound during the spin cycle and if the symptom is not corrected, can lead to damage of other components. Inspect the shocks for signs of broken attachments, leaked fluids or a weakened dampening action and replace both shocks if worn. Remove power from the appliance before attempting this repair.
Some models of top-load washers use tub dampening straps to cushion the movement of the tub during the spin cycle. There are four straps attached to the top of the tub and to each corner of the cabinet
Feb 16, 2014 | Frigidaire GLTF1670A Front Load Washer
Machine makes noise on spin cycle
Feb 15, 2014 | Frigidaire Washing Machines
Thumping and banging during the high speed spin cycle
Feb 08, 2014 | Frigidaire Washing Machines
The tub inside of the washing is very loose and bangs very loud when washing especially on yhe spin cycle
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Oct 13, 2010 | Frigidaire ATF6000ES Front Load Washer
Into the spin dry cycle a loud hammering noise appears. Immediately goes away when powered off and drum speed drops. Can you please advise. Regards Geoff
Check out this tip I wrote about the noise and vibration that front load washers can make..
heatman101
Oct 05, 2010 | Hoover H130E Front Load Washer
Frigidaire front-load washer making LOUD banging noise on spin cycle. Support brace under washer tub is detached.
Does the loose brace end look broken or like a bolt fell out of it. If it has the missing bolt appearance, look for parts on the floor of the machine. Look for where it was attached and re-bolt the part. If it was welded, it will require the same to fix the problem. Not a usual DIY fix.
Sep 14, 2009 | Frigidaire ATF6000ES Front Load Washer
Maytag Epic Z Washer has object between drum and tub.
did you ever find out how to separate the tub and basket on your maytag washer? I have exactly the same problem.
Jun 23, 2009 | Maytag EPIC MFW9700S Front Load Washer
Kenmore Front load washer model 3 970-c29042-00 The washer is making a loud noise and shakes like something is loose when the drum is turning..
I have a kenmore front load washer, model: 417 42042100
It makes loud noise and becomes louder during the spin cycle.
The drum is loose when I inspected through the front door.
My problem is how to open the cabinet and replace any broken parts.
Thanks.
Aug 04, 2008 | Kenmore 46462 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
61 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
