Question about Proscan PS50700 50" Rear Projection Television
Channels changing themselves
After warming up the channels incrimate in order without selecting.
    President:
  • 4,402 Answers
The channel up button broke
Posted on Feb 20, 2008
Hello, I somehow made it so I can only get channel 3.0 on my Proscan TV, I need to know how to get it on either channel 3 or 4, what do I need to do in order to change the channel?
Without knowing your model t.v. and other components, it's hard to say. For instance, if you have a cable box hooked up to it, then you would have to push the "cable" button on the remote to change the channels. If you have direct t.v. it would be the "sat" button. But without knowing, it's hard to say.
Sep 19, 2017 | Proscan Televison & Video
Is there any way to reset an rca j32l637 tv without the master remote? its stuck on channel 3 and stays on but then it cuts off and on if u try to change the volume or change the channel then stays on
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Sep 12, 2014 | Televison & Video
47LG50 channels change themselves
Do a reset to this TV, and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Nov 09, 2011 | LG 47LG50 47 in. LCD HDTV
How to i reset it it says its in a different region
Hi there angnkids2010 and welcome to FixYa. In order to change your consoles region you will need to follow these steps.
1- Go to your Wii Channel Menu and select the channel you wish to change the region settings on.
2- Once on the correct channel select the Settings option.
3- Go to the nearest location tab and celect Change.
4- Scroll down to your Locations List and select Choose From Other Regions.
5- Find the region closest to you and click it.
6- Next find the location closest to you and select that as well.
7- Click yes and you should be all set.
I hope you found this information useful and good luck. Thank you for visiting FixYa.
Apr 26, 2011 | Nintendo Wii Console
Need hep programming a new uniden bcd396xt scanner
Unfortunately, you didn't specify if you needed assistance with programming digital or conventional radio systems.. but here is the info for conventional systems. Since a conventional system is really a collection of frequencies, the first thing you need to know is the frequency for each channel you want to program.
  1. Go to the Program System menu and choose New System .
  2. The scanner will prompt you for the System Type. Select Conventional .
  3. When the scanner prompts you confirm, tap YES .
  4. The scanner creates the system with a default name. Select Edit Name if you want to change it.
  5. If you need to change any of the system properties, you can do that now. Unless a property is Required , you can operate the system without changing the default settings.
Create at least 1 channel group Each conventional system can contain up to 20 channel groups, and all systems must contain at least 1 channel group.
  1. On the Program System menu, select the system you just created.
  2. Go to the Edit Group menu and select New Group .
  3. If you need to change any of the channel group properties, you can do that now. Unless a property is Required , you can operate the system without changing the default settings.
Create at least 1 channel in each group Each conventional system can contain up to 1000 channels in each group, and all groups must contain at least 1 channel.
  1. On the Edit Group menu, select the channel group you just created.
  2. Go to the Edit Channel menu and select New Channel .
  3. Input the frequency for this channel in MHz.
  4. If you need to change any of the channel properties, you can do that now. Unless a property is Required , you can operate the system without changing the default settings.
Mar 04, 2011 | Uniden BCD396T Handheld Scanner
Need to change tv to channel 3 without remote!
go to menu and see if you have channel selection on go down thaT way. you should be able to program it in.
Feb 16, 2010 | Televison & Video
No signal on tv
Most of the time, replacing the Signal Board will fix the problem. You can order on from LG themselves at 1800-243-000.
I hope this helps,
Skyassoc
Nov 15, 2009 | LG 19LG30 19 in. LCD HDTV
Toshiba 42 lcd cannot delete channels I use the manual channel set and select Not Viewable for channels I don't want to see. Then as I click through the channels, the deleted channels show up again.
Also have a 42" Toshiba and had the same problem, then had issues moving the channel order while some channels were set to skip.
What I ended up doing was retuning the tv. Then went through the channel list (Menu -> Setup -> DTV Setting -> Channels) and changed the number of the channels I didn't want to 1000+ (using the red button, ie 1001, 1002, 1003...). This in itself does not change the channel order, but when I then move these channels to the end of the channel list and because they are numbered numerically I can be sure I don't miss any.
Next I went to the channel options (Menu -> Setup -> DTV Setting -> Channel Options) and marked all the channels I'd moved to the end of the list as channels to skip and locked. This does not remove the channels from the EPG but it does move them to the end of the list and when scrolling with the channel +/- buttons these channels will not be selected.
Ideally I would also like to delete channels such as QVC etc altogether and would love to know if anyone has a more effective solution to this issue.
Aug 15, 2009 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Tv needs to warm up?
I would suggest re-soldering your tuner connections and see if that helps. solder cracks tend to "fix" themselves after they warm up. Try the solder first but also look for evidence of a capacitor that may be swelled or leaking near the tuner.That is a possibility also.Hope this helps, let me know if you ned any further assistance.
Jan 23, 2008 | Sony KP-48V80 48" Rear Projection...
Input select function... without a remote?
Whew! Found the NE116UD replacement for the EWF2704 Emerson TV (there are other models on the list as well), it can be ordered here for 24.95:
http://www.emerson.newremotecontrol.com/catalog_item.php?catnum=NE116UD
Hope that helps. This problem is certainly very irritating. I have never heard of a remote for 24.95, nice job Emerson -- never again!
Nov 12, 2007 | Emerson EWF2704 TV
Proscan PS50700 50" Rear Projection Television Logo
32 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
