Question about Dell (002TR) Motherboard
Motherboard:OYC523-70821-5AS-G08S REV.A00 XPS 400 9150 Windows XP Error Code: 1,4 what is code 1,4 The system hangs before POST, during POST, after Post, while launching Windows, after booting in to Windows. Seems when system hasn't been turned on for a long time. It will boot to Windows and stay running for about 2 minutes. Then it seems something in the system gets hot and hangs, no mouse or keyboard function. All I can do is shut off the main power to the system. It seems that once the system is warmed up, the system hangs before before POST, during POST, Rarely making it to Windows before hanging. I have pulled out the expansion cards or swapped out cards. Disconnected peripherals, to no avail. I'm thinking its a CPU or motherboard problem.
  • ronwell pascual May 11, 2010
    Try running the hardware diagnostics that can help.
MysteryFCM
  • 187 Answers
SOURCE: no display when i turn on pc
You mentioned there were no beeps. Do you not even get the single beep (Post)? Did this issue only start after removing and reseating the CPU/Ram? If so, check they are seated properly.
Posted on May 25, 2008
  • 159 Answers
SOURCE: my system hangs after about 5mins after booting
If it happens at 'random' times, and won't restart immediately, most likley it's overheating due to dust blocked heat sink / fan (or a bad fan)
If it always happens at the some point in the boot up before you get the password prompt .. most likley it's s/w
Hit F8 during power up.. select 'last known good'
If that fails, F8 and select 'Safe Mode'
If you get into Safe Mode, uninstall whatever you last installed that is causing the lock up (most likley some hardware driver or some virus/root kit you got via email)
Posted on Nov 29, 2008
  • 5 Answers
SOURCE: Dell XPS 400 no power to usb
Cant remember the exact location for this, but you need to access the CMOS config when starting up. Dig around a little and you will find the settings that will allow you to start you system with a usb mouse and keyboard.
Hope this helps. If you have any idea where I can get drivers for my motherboard (EPoX EP-4PDA5) that would be great. I already tried EPOX's website, and no joy.
Cheers
Posted on Jan 08, 2009
preachw996
  • 1179 Answers
SOURCE: CPU Fan on my Dell P4 goes full speed when I boot up
It is a thermal problem. Try replacing the CPU fan & make sure you use a good thermal grease when reinstalling. Hope this helps.
Posted on Jan 13, 2009
  • 166 Answers
SOURCE: PC wont boot cpu fan runs extreemly loud and fast.
You may have a failed motherboard or bad/weak poswer supply unit (PSU) then. Failure of motherboards is usually due to breaking capacitors. A few years ago a capacitor company stole the "recipe" for making capacitors from another company and tried to make their own, unfortunately they did not get the ingredients right and the capacitors started breaking after 2-3 years of use. They sold these capacitors at very cheap prices and a lot of computer companies and power supply makers bought them. The DELL GX270 and GX 280 were the main DELL models affected by this situation. This is easy to diagnose. Look for capacitors (caps) (they look like little tiny soda cans) on your motherboard (mobo). They should be perfectly flat on top and not bulged or swelling or leaking anything. Make sure you look under the fan shroud. Most of the bad ones had either a plus + or X on the top - depending on your interpretation. There are a few companies that will repair broken capacitor issues. If it has recently gone out of warranty you could try to contact DELL to see if they will ship you another one. I was able to get them to fix a couple of mobos out of warranty, but that was two years ago. To eliminate some other stuff you could remove the memory and disconnect all the power plugs from the drives and then try to start it up. If it does not change the behavior at all (no beeps, no change in flashing lights) then you probably have motherboard or power supply issues. Make sure when disconnecting the memory chips (sticks) that you touch the metal on the inside of the case first to discharge static electricity. If it does change the behavior add 1 component or item back at a time to see what you can find out. Post back with what you find. And remember a bad PSU does not mean no power, just not enough to run the computer. If you change out the PSU, the one that you replace has to have the same or greater output watts?
Posted on Apr 30, 2009
Is there motherboard fuse? if so, location?
There are no motherboard fuses. Either the power supply is bad or the motherboard is. Based on your question, I would prefer you take it to a repair shop. Otherwise it may end up costing more for the same repair.
May 25, 2014 | Dell Studio 1555 laptop
Making a bench machine on the tyan dual core pentium III mother board
Rebooting is tipical of Windows XP when there is an important error. Most of the time this error is coming from the hardware.
There is a way to know the error code that make Windows XP mad, but you have to eliminate the automatic restart option.
With your mouse right click on My Computer, select properties, select advanced and you should see something similar:
deselect Automatically restart.
At this point next time you will have the error instead of rebooting you will see a blue screen with some message at the top and some code at the bottom, please write them down and post them here.
In case you cannot even enter in Windows XP because is keeping rebooting too fast, try to do the above steps in Safe mode.
To enter in Windows in Safe mode you have to press F8 as soon as you boot and before you see the windows logo on you screen, then select safe mode and repeat the steps above.
Last but not least, please send me the exact type of motherboard, processor and memory that you are using.
Oct 30, 2007 | Tyan Trinity 450 (S2507S) Motherboard
WHAT ARE THE SPECS ON THE TOROID INDUCTOR USED WITH THE (2) 6A 2700 CAPACITORS ON FOXCONN LS-36 REV A00 MOTHERBOARD IN MY DELL XPS 600 CPU?
lol
You need to contact the motherboard manufacturer. I could only guess and that would not be a solution.
Nov 23, 2013 | Dell XPS 600 PC Desktop
PC Freezes During Boot and at the BIOS Screen, EVGA P55 Classified 200
Beep Code Descriptions
1 short beep Normal POST - system is ok
2 short beeps POST Error - error code shown on screen
No beep Power supply or system board problem
Continuous beep Power supply, system board, or keyboard problem
Repeating short beeps Power supply or system board problem
1 long, 1 short beep System board problem
1 long, 2 short beeps Display adapter problem (MDA, CGA)
1 long, 3 short beeps Enhanced Graphics Adapter (EGA)
3 long beeps 3270 keyboard card
Aug 30, 2012 | Evga P55 Classified 200 (160LFE659KR)...
6 BEEPS ON DELL MOTHERBOARD REV A00
6 beeps on POST indicates a keyboard error. As virtually all BIOS require the keyboard, it is one error that cannot be bypassed in most BIOS. Is your keyboard connected properly?
Jan 18, 2012 | Computers & Internet
While loading windows it freezes
You are not saying what version of Windows you are trying to install. There is a common issue with WIN XP installation where at the "33 minutes to go" mark, during device installation, the system just hangs forever. This occurs when WINDOWS is trying to identify and load default drivers for all the motherboard components. If there is a defective component, the install will hang at that point. It is said that after a few successive attempts that WINDOWS will continue past the error, but my experience has not shown this to be true. In my case it was time for a new motherboard.
Jan 18, 2012 | EliteGroup GF7050VT-M Motherboard
Usb2.0 laptop tv tuner driver
http://www.inetbridge.net/forum/download/file.php?id=2295&sid=432f7c52d98676c2400b20b83f88c355
Dell Emuzed Angel USB TV Tuner Driver v.1.0.2.32 A00 Windows XP.
Supported Models: Inspiron 6000, Inspiron 9400/E1705, XPS/Inspiron XPS Gen 2, Inspiron 9300, XPS/Inspiron M170, XPS M1710.
Driver : Dell Emuzed Angel USB TV Tuner Driver v.1.0.2.32
Mar 01, 2011 | Computers & Internet
Intel cpu ucode loading error
You need to update the BIOS.
Go here to get the update, enter...
Product: motherboard
Series: Socket 775
Model: P5VD2-VM SE
Operating System
ASUS Download Link
Oct 16, 2008 | EliteGroup L7VMM2 Motherboard
Stop error
Visit this post on microsoft to resolve your problem.Your RAM may be the cause of the error.
Aug 22, 2008 | Microsoft Windows XP Professional With...
Beeps
Standard Original IBM POST Error Codes
Code Description
1 short beep System is OK
2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem
1 long, 3 short beeps Display adapter problem (EGA)
For more info go here: http://pulonangka.web.id/software/beep-codes-error-codes
Aug 16, 2008 | Dell XPS M1530 Notebook
Dell (002TR) Motherboard Logo
840 people viewed this question
Alun Cox
